Fetch current electricity price for SE3, SE4, DK1, DK2, NO2
bjacobse
Post by bjacobse »
[EDIT 2022-11-07, to use the the API on the server as it was changed]
I have created this script as I have my electricity cost/price based on nordpools actual electricity proce.
The webservice I fetch data from only support the following areas: DK1, DK2, SE3, SE4, NO2, I assume it's due to it's a danish webservice, so unfortunately not usable for everyone
It gets price in EUR and I locally convert those to DKK (exchange rate 7,46), the dummy selector show a traffic light, green, yellow or red, depending on what you have set limits to in script
Note that price fetched are EUR per Mega What hour, (MWh) which are converted to kWh in the script
create one text dummy device, and one dummy switch selector, as shown in pictures below. Note that the most expensive price in selector is Red and have value 0, which is the switch set to OFF, so it should be fairly easy to check if lamp is off then don't use electricity
Author 		: Bjacobse
Description : Get current Electricity price for chosen area, set Electricity pric in text device and dummy switch.
Dummy switch selector show pricing as traffic light, to be used for enable/disable switches for heating
	-- optional active section,
	-- when left out the script is active
	-- note that you still have to check this script
	-- as active in the side panel
	active = {
		true,  -- either true or false, or you can specify a function
	-- trigger
		-- timer riggers
		--timer = { 'every minute' },
        	timer = { 'every hour' },
        httpResponses = { 'electricitycostresponse' }
	-- custom logging level for this script
	logging = {
        level = domoticz.LOG_DEBUG,
        marker = "Electricity Price"
	-- actual event code
	    -- execute when timer is trigger
        if (item.isTimer) then
            local myTimezone = 'HourDK'
            --area to chose between SE3, SE4, DK1, DK2, NO2
            -- The service provisder energidataservice.dk is only supporting above areas
            local myPricearea = 'DK2'
            -- ISO 8601 timestamp
            --Somehow only whole hour is giving results, so set min=00
            local myDateTime = (os.date("%Y-%m-%dT%H")..":00")
            -- Need end hour, which is next hour
            local myDateTimeEnd = (os.date("%Y-%m-%dT%H", os.time(os.date('*t')) + 3600)..":00")
            --domoticz.log(myDateTimeEnd)
            -- { = %7B
            -- " = %22
            -- } = %7D
		    -- https://api.energidataservice.dk/dataset/Elspotprices?start=2022-11-07T19:00&end=2022-11-07T20:00&filter={%22PriceArea%22:[%22DK1%22]}
            local url = string.format("https://api.energidataservice.dk/dataset/Elspotprices?start=%s&end=%s&filter={\"PriceArea\":[\"%s\"]}",myDateTime, myDateTimeEnd, myPricearea)
		    -- url to logfile
		    --domoticz.log(url)
		    domoticz.openURL({
                url = url,
                method = 'GET',
                callback = 'electricitycostresponse'
		-- execute after http response
		if (item.isHTTPResponse and item.ok) then
		    -- 0.03887 = 29øre
		    -- 0.0536= 40 øre
		    -- 0.0670 = 50øre
		    local greenCostEUR_kWh  = 0.0536
		    -- Yellow is interval between green and red
		    -- 0.08 = 60 øre
		    -- 0.10 = 75 øre
            local redCostEUR_kWh    = 0.08
		    --domoticz.log("http response ok")
            -- force to handle as json
            -- we know it is json but dzVents cannot detect this
            -- convert to Lua
            local json = domoticz.utils.fromJSON(item.data)
            -- json is now a Lua table
            --domoticz.log(json.records[1].SpotPriceEUR)
            local myCurrentpriceEUR = (json.records[1].SpotPriceEUR)
            myCurrentpriceEUR = myCurrentpriceEUR /1000
            --domoticz.log((myCurrentpriceEUR .. "EUR/kWh"))
            --Uncommnet below to get price in EUR/Kwh
            -- update text device with current electricity price
	        --domoticz.devices('Elprice now').updateText((myCurrentpriceEUR .. " EUR/MWh"))
            --convert to DKK, 7,46dkk/EUR. Change to 2 decimal points
            local convert = tostring(tonumber(string.format("%.2f", (json.records[1].SpotPriceEUR) * 7.46/10)))
            -- Denmark prefer to have comma as separator and not a dot (which in DK is a thousand separator)
            -- replace . with , Remember that . is special char and needs to be %.
            convert = convert:gsub("%.", ",")
            --domoticz.log(convert)
            --comment below to reomve price in øre/kWh
            local myCurrentpriceDKK = (convert)
            domoticz.devices('Elprice now').updateText((myCurrentpriceDKK .. " Øre/kWh"))
            --Set traffic light colour
            if tonumber(myCurrentpriceEUR) >= redCostEUR_kWh then
                domoticz.devices('Elprice').switchSelector(0)
                --domoticz.log("Red")
            --if tonumber(myCurrentpriceEUR) < yellowCostEUR_kWh then
            if ((tonumber(myCurrentpriceEUR) < redCostEUR_kWh) and (tonumber(myCurrentpriceEUR) > greenCostEUR_kWh)) then
                --domoticz.devices('Elprice').switchSelector("Yellow")
                domoticz.devices('Elprice').switchSelector(10)
                --domoticz.log("yellow")
            if tonumber(myCurrentpriceEUR) <= greenCostEUR_kWh then
                domoticz.devices('Elprice').switchSelector(20)
                --domoticz.log("Green")
Last edited by bjacobse on Monday 07 November 2022 23:45, edited 5 times in total.
bjacobse
Re: Fetch current electricity price for SE3, SE4, DK1, DK2, NO2
Post by bjacobse »
Somehow I can't attach 4 pictures so here are the switches as they appear in Domoticz
marin849
Domoticz version: 2.4xxx
Post by marin849 »
Nice! I will test this.
insippo
Post by insippo »
Please help with this. Not working.
2021-10-18 02:17:00.588 Error: EventSystem: Lua script Elprice did not return a commandArray
bjacobse
Post by bjacobse »
Maybe you have some empty variables, and then won't get an reply and command array is empty
Find this in your code
    --domoticz.log(url)
and change to this:
    domoticz.log(url)
Now you will have your command path in the domoticz logfile, then you can verify if something is missing in your code
norlin
Post by norlin »
Before I make an effort, is it still possible to get price info from the place the script use?
Domoticz version: 2025.1
Play a little bit with the url and you will know
"https://api.energidataservice.dk/datastore_search?resource_id=elspotprices&filters={\"%s\":\"%s\",\"PriceArea\":\"%s\"}"
Szwuntex
Post by Szwuntex »
insippo wrote: Monday 18 October 2021 1:16 Please help with this. Not working.
Choose dzVents as script language instead :)
kimhav
Domoticz version: 2023.2
Post by kimhav »
Well, looked simple enough and nothing shows and based on the above I placed the scrip in the /dzVents/scripts as placing in /lua/scripts generated the same error as the above post. This is how the devices shows currently:
Not sure what went wrong here.
kimhav
Post by kimhav »
Right, found the error... :oops: typo in device name so instead of 'Elprice now' I used 'Elprice Now'. So works just fine. Nice function request for the script would be to include currency converter directly based on EUR as base currency and convert to currency of choice and of course to find a free currency converter service.
kimhav
Post by kimhav »
Noticed today that the current way of fetching the pricing data via the API has changed and it's necessary to tweak the API call in accordance with the updated API guide: https://www.energidataservice.dk/guides/api-guides
jvonzastrow
Post by jvonzastrow »
kimhav wrote: Wednesday 07 September 2022 14:56 Noticed today that the current way of fetching the pricing data via the API has changed and it's necessary to tweak the API call in accordance with the updated API guide: https://www.energidataservice.dk/guides/api-guides
@kimhav Have you updated it? Can you share?
bjacobse
Post by bjacobse »
Hi I have been absent from here (due to house building activities)
I hope I can look into this during the weekend
kimhav
Post by kimhav »
Hi Bjacobse, stumbled over this fork of your script on facebook which I used for my own tweaking but surely this would provide you input the original script
bjacobse
Post by bjacobse »
Now I have updated the script, and it looks like it's working again on my Domoticz,
Author 		: Bjacobse
	active = {
	-- trigger
		-- timer riggers
	logging = {
            -- { = %7B
            -- " = %22
            -- } = %7D
		    -- url to logfile
		    --domoticz.log(url)
		    domoticz.openURL({
                url = url,
                method = 'GET',
		    -- 0.03887 = 29øre
		    -- 0.0536= 40 øre
		    -- 0.0670 = 50øre
		    -- 0.08 = 60 øre
		    -- 0.10 = 75 øre
            -- convert to Lua
bjacobse
Post by bjacobse »
kimhav wrote: Friday 28 October 2022 13:32 Hi Bjacobse, stumbled over this fork of your script on facebook which I used for my own tweaking but surely this would provide you input the original script
Thank you, I looked at the code after I have updated my own script, good that it could be forked to help others
bjacobse
Post by bjacobse »
Something seems not be working from the data provider
as this date seems to give an empty result 20 Nov,
https://api.energidataservice.dk/datase ... 22DK2%22]}
but same request 19 Nov is ok
