Dummy to see Fritzbox call log
naitsirhc
Post by naitsirhc »
My question is as simple as the title should cover.
Is there a way to create a dummy switch (text) which can show the Fritzbox call monitor log? It should be great to implement such a thing in domoticz.
I have already the device implemented, but before you can see the call log, you should push the log button.
I would like to see the log at once. (It also can be expressed in Dashticz ;) )
Kind regards
Und Tschjuß
ben53252642
Re: Dummy to see Fritzbox call log
Post by ben53252642 »
You can already display HTML within Domoticz text devices, I do this to show the currently playing internet radio station.
Write a PHP script that gets the call log, formats it and outputs it as HTML for the text device.
felix63
Domoticz version: 2020.1
Post by felix63 »
Did you have a look at https://www.domoticz.com/wiki/Fritzbox? This will create two devices. One switch that goes on when receiving a call and another text switch showing the last line in the call log.
Very simple and very reliable.
naitsirhc
Post by naitsirhc »
@Felix
You only see ID and time, but you don't see the number.
@ben
Unfortunately I don't know how to program in PHP...
So this is a bridge to far, for now....but I will keep trying
Thanks all....
Und Tschjuß
felix63
Post by felix63 »
Hi naitsirhc,
if I look at the history of the log field that is generated by the fritzbox plugin I see the following entries:
2019-11-01 20:00:58 Disconnect ID: 0 Duration: 39 seconds
2019-11-01 20:00:20 Connected ID: 0 Number: 3161xxxxxxx
2019-11-01 20:00:08 Received From: 3161xxxxxxx to: 018xxxxxxx
2019-11-01 13:19:13 Disconnect ID: 0 Duration: 5 seconds
2019-11-01 13:19:09 Connected ID: 0 Number:
2019-11-01 13:18:54 Received From: to: 018xxxxxxx
So in my configuration I am getting number information pushed to domoticz...
Cheers,
Lex
naitsirhc
Post by naitsirhc »
Hi Lex,
you're right. I also see the numbers, but I have to push the log button first. I don't know how to push it to domoticz (or dummy with a certain IDX), so I can present it in Dashticz
My button shows:
Und Tschjuß
