Page 1 of 2
Update of Lua to version 5.3 in domoticz V4.11439. with potential effects on Lua and dzVents scripts
Posted: Thursday 31 October 2019 10:43
by waaren
Dear dzVents and Lua script users.
Lua version changed in domoticz V4.11439 from version 5.2 to 5.3
You can check what version is in use in your domoticz version with
domoticz.log('Lua version in use by domoticz ' .. domoticz.settings.domoticzVersion .. ' : ' .. _G._VERSION,domoticz.LOG_FORCE) -- in dzVents scripts
print('Lua version in use by domoticz : ' .. _G._VERSION) -- in Lua scripts
Some of the potential breaking changes:
math.max and math.min do no longer return a number when comparing strings. The now return the same type as the input parameters. Use tonumber to convert to a number if your script expects one.
deprecated functions: math.atan2, math.cosh, math.sinh, math.tanh, math.pow, math.frexp, and math.ldexp. You can replace math.pow(x,y) with x^y
Introduction of an integer subtype for numbers with as side effect that a conversion of a float to a string now adds a .0 suffix to
the result if it looks like an integer. (For instance, the float 2.0 will be printed as 2.0, not as 2 )
Some possible work-arounds if this change is causing problems for you are:
Easiest: use math.floor -- returns the integral part of any number
 print (math.floor(6/1.999999999999)) -- >> 3
 print (math.floor(6/2.000000000001)) -- >> 2
Modest: use math.tointeger -- returns an integer when convertible to an integer, Otherwise it returns nil.
 print (math.tointeger(5/2)) -- >> nil
 print (math.tointeger(6/1.999999999999999)) -- >> nil
 print (math.tointeger(6/1.9999999999999999)) -- >> 3
Complex: use math.modf -- returns the integral- and the fractional part of x in a table key [1] is the integer part, key[2] is the float part
  print( ({ math.modf(5/2)})[1]) -- >> 2
  print( ({ math.modf(5/2)})[2]) -- >> 0.5
If you need more background on Lua 5.3 have a look at the official manual
Re: Update of Lua in domoticz imminent with potential effects on Lua and dzVents scripts
Posted: Monday 04 November 2019 22:11
by kevster
Thanks for pointing this change out. I hit it on 4.11464 regarding lua scripts using the power function. Minor change fixed it.
Keep meaning to update the Wiki with my versions and solution but page at https://www.domoticz.com/wiki/Lua_-_Oil_Tank_Monitor now has the bug.
Posted: Monday 04 November 2019 22:28
by waaren
kevster wrote: Monday 04 November 2019 22:11 Keep meaning to update the Wiki with my versions and solution but page at https://www.domoticz.com/wiki/Lua_-_Oil_Tank_Monitor now has the bug.
Later domoticz /dzVents versions do prevent a breaking error, using a home made math.pow function but with a deprecate warning urging to update script.
Posted: Sunday 17 November 2019 22:48
by DutchHans
The virtual lux sensor and realtime solar script (lua version) has the bug aswell. Has somebody found a solution?. My altitude, azimuth and radiation work...but luxinfo is giving huge amounts...please help.
Regards Hans
Posted: Sunday 17 November 2019 22:57
by waaren
DutchHans wrote: Sunday 17 November 2019 22:48 The virtual lux sensor and realtime solar script (lua version) has the bug aswell. Has somebody found a solution?. My altitude, azimuth and radiation work...but luxinfo is giving huge amounts...please help.
Regards Hans
Can you share the script and the loglines with the error messages ?
Posted: Sunday 17 November 2019 23:06
by DutchHans
Good evening, i will do it tomorrow morning.
Regards, Hans
Posted: Monday 18 November 2019 8:14
by DutchHans
Here you go:
This script worked perfectly before the update to Lua 5.3
 --[[      Virtual Lux sensor and other real-time solar data
    ~/domoticz/scripts/lua/script_time_SolarSensor.lua
    -- Autors  ----------------------------------------------------------------
    V1.0 - Sébastien Joly - Great original work
    V1.1 - Neutrino - Adaptation to Domoticz
    V1.2 - Jmleglise - An acceptable approximation of the lux below 1° altitude for Dawn and dusk + translation + several changes to be more userfriendly.
    V1.3 - Jmleglise - keep the time of black night in lasptUpdate
   V1.4 - use the API instead of updateDevice to update the data of the virtual sensor to be able of using devicechanged['Lux'] in our scripts. (Due to a bug in Domoticz that doesn't catch the devicechanged event of the virtual sensor)
    -- Variables to customize ------------------------------------------------
	   local localhost = '192.xxx.xxx.xxx:8080'  -- Set your port. (Not the universal IP).
       local city = "xxx"            -- Your city for Wunderground API
       local countryCode = "DE"            -- Your country code for Wunderground API
       local idxLux ='490'            -- Your virtual Lux Device ID
       local idxSolarAzimuth ='1307'       -- Your virtual Azimuth Device ID
       local idxSolarAltitude ='1308'       -- Your virtual Solar Altitude Device ID
       local idxUserVarOcta='6'           -- Your user variable ID , named octa
       local wuAPIkey = "xxxxxxxxxxxxxx" -- Your Weather Underground API Key
       local latitude = xxx        -- your home
       local longitude = xxx       -- your home
       local altitude = xxx               -- Your home altitude : run once in debug = 1 to found your altitude in Log and write it here
       local WMOID = 'xxx'    -- Your nearest SYNOP Station for ogimet (to get Cloud layer). Run once with debug=1 to get it in the log. (or, better, choose it there :   http://www.ogimet.com/gsynop_nav.phtml.en )
	   local DEBUG = 0             -- 0 , 1 for domoticz log , 2 for file log
       -- and customize the URL of api.wunderground around line 104 according to your country.
     -- Below , edit at your own risk ------------------------------------------
    function leapYear(year)
       return year%4==0 and (year%100~=0 or year%400==0)
    function split(s, delimiter)
       result = {};
       for match in (s..delimiter):gmatch("(.-)"..delimiter) do
         table.insert(result, match);
       return result;
    function round(num, dec)
       if num == 0 then
         return 0
         local mult = 10^(dec or 0)
         return math.floor(num * mult + 0.5) / mult
    --time = os.date("*t")
    --if  ((time.min % 5)==0)  then -- Run every 5 minutes. Check the wundergroud API limitation before changing this
       json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
       --json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")()  -- For Windows
       local arbitraryTwilightLux=6.32     -- W/m² egal 800 Lux     (the theoritical value is 4.74 but I have more accurate result with 6.32...)
       local constantSolarRadiation = 1361 -- Solar Constant W/m²
       if (uservariables['octa'] == nil) then print("Error : Did you create the Uservariable octa ?") end
       --  API Wunderground
       --local config=assert(io.popen('curl --connect-timeout 10 http://api.wunderground.com/api/'..wuAPIkey..'/conditions/q/'..countryCode..'/'..city..'.json'))
       --local location = config:read('*all')
       --config:close()
       --local jsonLocation = json:decode(location)
       --if( DEBUG == 1) then
       --   local latitude = jsonLocation.current_observation.display_location.latitude
       --   local longitude = jsonLocation.current_observation.display_location.longitude
       --   local altitude = jsonLocation.current_observation.display_location.elevation
       --   print('Lat: '..latitude..'Long: '..longitude..'Alt: '..altitude)
       --end
       --relativePressure = jsonLocation.current_observation.pressure_mb   -- if you have an another way to get the Pressure, (local barometer ...) then you may optimize the script and avoid the call to api.wunderground)
       relativePressure = uservariables['AirPressure']
       local year = os.date("%Y")
       local numOfDay = os.date("%j")
       if  leapYear(year) == true then
          nbDaysInYear = 366  -- How many days in the year ?
          nbDaysInYear = 365
       angularSpeed = 360/365.25
       local Declinaison = math.deg(math.asin(0.3978 * math.sin(math.rad(angularSpeed) *(numOfDay - (81 - 2 * math.sin((math.rad(angularSpeed) * (numOfDay - 2))))))))
       timeDecimal = (os.date("!%H") + os.date("!%M") / 60) -- Coordinated Universal Time  (UTC)
       solarHour = timeDecimal + (4 * longitude / 60 )    -- The solar Hour
       hourlyAngle = 15 * ( 12 - solarHour )          -- hourly Angle of the sun
       sunAltitude = math.deg(math.asin(math.sin(math.rad(latitude))* math.sin(math.rad(Declinaison)) + math.cos(math.rad(latitude)) * math.cos(math.rad(Declinaison)) * math.cos(math.rad(hourlyAngle))))-- the height of the sun in degree, compared with the horizon
       local azimuth = math.acos((math.sin(math.rad(Declinaison)) - math.sin(math.rad(latitude)) * math.sin(math.rad(sunAltitude))) / (math.cos(math.rad(latitude)) * math.cos(math.rad(sunAltitude) ))) * 180 / math.pi -- deviation of the sun from the North, in degree
       local sinAzimuth = (math.cos(math.rad(Declinaison)) * math.sin(math.rad(hourlyAngle))) / math.cos(math.rad(sunAltitude))
       if(sinAzimuth<0) then azimuth=360-azimuth end
       sunstrokeDuration = math.deg(2/15 * math.acos(- math.tan(math.rad(latitude)) * math.tan(math.rad(Declinaison)))) -- duration of sunstroke in the day . Not used in this calculation.
       RadiationAtm = constantSolarRadiation * (1 +0.034 * math.cos( math.rad( 360 * numOfDay / nbDaysInYear )))    -- Sun radiation  (in W/m²) in the entrance of atmosphere.
       -- Coefficient of mitigation M
       absolutePressure = relativePressure - round((altitude/ 8.3),1) -- hPa
       sinusSunAltitude = math.sin(math.rad(sunAltitude))
       M0 = math.sqrt(1229 + math.pow(614 * sinusSunAltitude,2)) - 614 * sinusSunAltitude
       M = M0 * relativePressure/absolutePressure
       if (DEBUG == 1) then
          print('<b style="color:Blue"==============  SUN  LOG ==================</b>')
          print(os.date("%Y-%m-%d %H:%M:%S", os.time()))
          print(city .. ", latitude:" .. latitude .. ", longitude:" .. longitude)
          print("Home altitude = " .. tostring(altitude) .. " m")
          print("number Of Day = " .. numOfDay)
          if nbDaysInYear==366 then
             print(year .." is a leap year !")
             print(year.." is not a leap year")
          print("Angular Speed = " .. angularSpeed .. " per day")
          print("Declinaison = " .. Declinaison .. "°")
          print("Universel Coordinated Time (UTC)".. timeDecimal .." H.dd")
          print("Solar Hour ".. solarHour .." H.dd")
          print("Altitude of the sun = " .. sunAltitude .. "°")
          print("Angular hourly = ".. hourlyAngle .. "°")
          print("Azimuth of the sun = " .. azimuth .. "°")
          print("Duration of the sunstroke of the day = " .. round(sunstrokeDuration,2) .." H.dd")  -- not used
          print("Radiation max in atmosphere = " .. round(RadiationAtm,2) .. " W/m²")
          print("Local relative pressure = " .. relativePressure .. " hPa")
          print("Absolute pressure in atmosphere = " .. absolutePressure .. " hPa")
          print("Coefficient of mitigation M = " .. M .." M0:"..M0)
       -- Get  SYNOP  message from  Ogimet web  site
       hourUTCminus1 = os.date("!%H")-1
       if string.len(hourUTCminus1) == 1 then
          hourUTCminus1 = "0" .. hourUTCminus1
       UTC = os.date("%Y%m%d").. hourUTCminus1.."00" -- os.date("!%M")
local jsonResultOgimet = '/var/tmp/OgimetJson.json' -- Temporary file to store the servers response
local fetchIntervalMins = 5 -- (Integer) (Minutes, Range 5-60) How often the data shall be retrieved
local callUrl = false
  if (os.date('*t').min % fetchIntervalMins) == 0 then
     callUrl = true
  elseif ((os.date('*t').min -1) % fetchIntervalMins) ~= 0 then
    return end if callUrl then
	local urlOgimet ='http://www.ogimet.com/cgi-bin/getsynop?block='..WMOID..'&begin='..UTC..''
	--print('Ogimet URL used: '..urlOgimet)
	os.execute('curl -s --connect-timeout 5 "'..urlOgimet..'" > '..jsonResultOgimet..'&')
    return -- Nothing more to do for now, we'll be back in a minute to read the data!
    local f = assert(io.open(jsonResultOgimet, "rb"))
    local synop = f:read("*all")
	--print(synop)
    f:close()
       if( DEBUG == 1) then print('ogimet:'..synop) end
       if string.find(synop,"Status: 500") == nil
       then
          rslt = split(synop,",")
		  if rslt ~= nil then
		     CodeStation = rslt[1]
             rslt = split(synop, " "..CodeStation.. " ")
               if rslt[2] ~= nil then
             Trame = string.gsub(rslt[2], "=", "")
             Trame = CodeStation .." ".. Trame
             rslt = split(Trame, " ")
             Octa = string.sub(rslt[3], 1, 1)  -- 3rd char is the cloud layer.  0=no cloud , 1-8= cloudy from 1 to 8 max , 9 =Fog , / = no data
             if Octa == "/" or Octa==nil then   -- not defined ? take the previous value
                Octa = uservariables['octa']
             elseif Octa == "9" then
                Octa = 8
      -- os.execute('curl --connect-timeout 10 -s "http://192.168.188.58:8080/json.htm?type=command&param=updateuservariable&idx='..idxUserVarOcta..'&vname=octa&vtype=0&vvalue='..tostring(Octa)..'"&')
       commandArray[#commandArray + 1] = {['Variable:octa'] = tostring(Octa)}
       Kc=1-0.75*math.pow(Octa/8,3.4)  -- Factor of mitigation for the cloud layer
       if sunAltitude > 1 then -- Below 1° of Altitude , the formulae reach their limit of precision.
          directRadiation = RadiationAtm * math.pow(0.6,M) * sinusSunAltitude
          scatteredRadiation = RadiationAtm * (0.271 - 0.294 * math.pow(0.6,M)) * sinusSunAltitude
          totalRadiation = scatteredRadiation + directRadiation
          Lux = totalRadiation / 0.0079  -- Radiation in Lux. 1 Lux = 0,0079 W/m²
          weightedLux = Lux * Kc   -- radiation of the Sun with the cloud layer
       elseif sunAltitude <= 1 and sunAltitude >= -7  then -- apply theoretical Lux of twilight
          directRadiation = 0
          scatteredRadiation = 0
          arbitraryTwilightLux=arbitraryTwilightLux-(1-sunAltitude)/8*arbitraryTwilightLux
          totalRadiation = scatteredRadiation + directRadiation + arbitraryTwilightLux
       elseif sunAltitude < -7 then  -- no management of nautical and astronomical twilight...
          directRadiation = 0
          totalRadiation = 0
          Lux = 0
          weightedLux = 0  --  should be around 3,2 Lux for the nautic twilight. Nevertheless.
          print("Station SYNOP = " .. WMOID)
          print( Octa .. " Octa")
          print("Kc = " .. Kc)
          print("Direct Radiation = ".. round(directRadiation,2) .." W/m²")
          print("Scattered Radiation = ".. round(scatteredRadiation,2) .." W/m²")
          print("Total radiation = " .. round(totalRadiation,2) .." W/m²")
          print("Total Radiation in lux = ".. round(Lux,2).." Lux")
          print("and at last, Total weighted lux  = ".. round(weightedLux,2).." Lux")
	if tonumber(otherdevices_svalues['Lux'])+round(weightedLux,0)>0   -- No update if Lux is already 0. So lastUpdate of the Lux sensor will keep the time when Lux has reached 0. (Kind of timeofday['SunsetInMinutes'])
	then
		commandArray[#commandArray + 1] = {['UpdateDevice'] = idxLux..'|0|'..tostring(round(weightedLux,0))}    --  THis form is not recommended. due to limitation of the eventsystem of Domoticz
		--commandArray[#commandArray + 1]={['OpenURL']="http://"..localhost.."/json.htm?type=command&param=udevice&idx="..idxLux.."&nvalue=0&svalue="..tostring(round(weightedLux,0)) }
     commandArray[#commandArray + 1] = {['UpdateDevice'] = idxSolarAzimuth..'|0|'..tostring(round(azimuth,0))}
 	--commandArray[#commandArray + 1]={['OpenURL']="http://"..localhost.."/json.htm?type=command&param=udevice&idx="..idxSolarAzimuth.."&nvalue=0&svalue="..tostring(round(azimuth,0)) }
     commandArray[#commandArray + 1] = {['UpdateDevice'] = idxSolarAltitude..'|0|'..tostring(round(sunAltitude,0))}
 	--commandArray[#commandArray + 1]={['OpenURL']="http://"..localhost.."/json.htm?type=command&param=udevice&idx="..idxSolarAltitude.."&nvalue=0&svalue="..tostring(round(sunAltitude,0)) }
       if (DEBUG == 2) then
          logDebug=os.date("%Y-%m-%d %H:%M:%S",os.time())
          logDebug=logDebug.." Azimuth:" .. azimuth .. " Height:" .. sunAltitude
          logDebug=logDebug.." Octa:" .. Octa.."  KC:".. Kc
          logDebug=logDebug.." Direct:"..directRadiation.." inDirect:"..scatteredRadiation.." TotalRadiation:"..totalRadiation.." LuxCloud:".. round(weightedLux,2)
          os.execute('echo '..logDebug..' >>logSun.txt')  -- compatible Linux & Windows
    --end
now it gives this error:
2019-11-18 08:03:00.227 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_SolarSensor.lua: /home/pi/domoticz/scripts/lua/script_time_SolarSensor.lua:106: attempt to call a nil value (field 'pow')
I found out that math.pow(x,y) is depreciated in LUA 5.3 so changed it to x^y.
Azimuth and Altitude work correct but LUX gives huge amouts eg.: 9 223 372 036 854 776 000 lx
I have tried several things but can't figure out why...
Thanks for your help.
Regards, Hans
Posted: Monday 18 November 2019 8:54
by waaren
DutchHans wrote: Monday 18 November 2019 8:14
Can you try with this and if still produce errors, execute after changing line 29 to
local DEBUG = 1
    V1.5 -- waaren - add local function math.pow as this function has been deprecated in Lua 5.3
	function math.pow(x, y)
		-- Function math.pow(x, y) has been deprecated in Lua 5.3. Please consider changing code to x^y
		return x^y
       result = {};
       return result;
       if num == 0 then
         return 0
       --  API Wunderground
       --config:close()
       --end
          nbDaysInYear = 365
     callUrl = true
	--print(synop)
    f:close()
       then
		  if rslt ~= nil then
                Octa = 8
          directRadiation = 0
          directRadiation = 0
          totalRadiation = 0
          Lux = 0
	then
    --end
Posted: Monday 18 November 2019 9:56
by DutchHans
this error occurs now:
2019-11-18 09:55:00.858 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_SolarSensor.lua: /home/pi/domoticz/scripts/lua/script_time_SolarSensor.lua:34: '(' expected near '.'
Posted: Monday 18 November 2019 10:08
by DutchHans
deleted the "local" ...seems to be working now.
Thanks a lot.
Hans
Posted: Thursday 30 January 2020 19:35
by EddyG
I switched from the latest stable to the lastest beta.
Now I got these LUA errors.
2020-01-30 19:34:40.850 Error: dzVents: Error: (2.5.7) ...i/domoticz/scripts/dzVents/scripts/electricity usage.lua:25: module 'socket.http' not found:
2020-01-30 19:34:40.850 no field package.preload['socket.http']
2020-01-30 19:34:40.850 no file '/usr/local/share/lua/5.3/socket/http.lua'
2020-01-30 19:34:40.850 no file '/usr/local/share/lua/5.3/socket/http/init.lua'
2020-01-30 19:34:40.850 no file '/usr/local/lib/lua/5.3/socket/http.lua'
2020-01-30 19:34:40.850 no file '/usr/local/lib/lua/5.3/socket/http/init.lua'
2020-01-30 19:34:40.850 no file './socket/http.lua'
2020-01-30 19:34:40.850 no file './socket/http/init.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/scripts/dzVents/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/dzVents/runtime/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/scripts/dzVents/dzVents/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/scripts/dzVents/scripts/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/scripts/dzVents/../lua/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/scripts/dzVents/data/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/scripts/dzVents/modules/socket/http.lua'
2020-01-30 19:34:40.850 no file '/home/pi/domoticz/scripts/lua/socket/http.lua'
2020-01-30 19:34:40.850 no file '/usr/local/lib/lua/5.3/socket/http.so'
2020-01-30 19:34:40.850 no file '/usr/local/lib/lua/5.3/loadall.so'
2020-01-30 19:34:40.850 no file './socket/http.so'
2020-01-30 19:34:40.850 no file '/usr/local/lib/lua/5.3/socket.so'
2020-01-30 19:34:40.850 no file './socket.so'
What do I need to install to get 5.3 running?
Posted: Thursday 30 January 2020 23:33
by waaren
EddyG wrote: Thursday 30 January 2020 19:35 I switched from the latest stable to the lastest beta.
the file socket.http is not included in domoticz, dzVents or Lua. Probably your dzVents script use this external library. If you share the script I will have a look if it really needs this or that it can use native domoticz / dzVents commands.
Also have a look at this post where is explained how to install lua-socket ( sudo apt-get install lua-socket ) and how to make sure your script can find it.
Re: Update of Lua to version 5.3 in domoticz V4.11439. with potential effects on Lua and dzVents scripts
Posted: Friday 31 January 2020 8:55
by EddyG
It is this part of the script which uses that lib
        b, c, h = http.request(PVoutputURL .. PVoutputApi .. "&sid=".. PVoutputSystemID .. "&d=" .. os.date("%Y%m%d") .$
Is a http request to upload my P1-meter output to pvoutput.org
I only need b as a return value, which should be "OK 200: Added Status" from pvoutput.org
Posted: Friday 31 January 2020 9:15
by waaren
EddyG wrote: Friday 31 January 2020 8:55 It is this part of the script which uses that lib
Please share the complete script. If needed you can obscure user-id / password. I don't need those
Posted: Friday 31 January 2020 9:31
by waaren
EddyG wrote: Friday 31 January 2020 8:55 Is a http request to upload my P1-meter output to pvoutput.org
Maybe this example can already put you on the right track.
I use this script to send my energy data to pvoutput every 5 minutes. I stored my user-id / password in a domoticz uservariable.
local scriptVar = 'PVOutput'
            on =    {
                        timer = { 'every 5 minutes'},
                        httpResponses = { scriptVar },
       logging =    {
                        level   =   domoticz.LOG_DEBUG, -- set to error when all OK
                        marker  =   "pvOutput"
    execute = function(dz, item)
        local function post2PVOutput(PVSettings, postData)
            -- dz.utils.dumpTable(PVSettings, 'PVSettings > ')
            -- dz.log('postData: ' .. postData,dz.LOG_FORCE)
            dz.openURL({
                url = PVSettings.url,
                method = 'POST',
                headers = {
                    ['X-Pvoutput-Apikey'] = PVSettings.api,
                    ['X-Pvoutput-SystemId'] = PVSettings.id
                callback = scriptVar,
                postData = postData
        local function makepostData()
            local P1 = dz.devices('Power')
            local Youless = dz.devices('Youless')
            local temperature = dz.devices('temperatuur Rotterdam')
            local voltage = dz.devices('Synology UPS - UPS AC Input')
            local round = dz.utils.round
            local postdDataAsString =
            'd=' .. os.date("%Y%m%d") ..
            '&t=' .. os.date("%H:%M") ..
            '&v1=' .. P1.return1 + P1.return2 ..
            '&v2=' .. P1.usageDelivered ..
            '&v3=' .. P1.usage1 + P1.usage2 ..
            '&v4=' .. P1.usage ..
            '&v5=' .. round(temperature.temperature,1) ..
            '&v6=' .. round(voltage.sValue,1) ..
            '&c1=1'
                v1 - energy generation
                v2 - power generation            W from
                v3 - energy consumption
                v4 - power consumption
                v5 - temperature
                v6 - voltage
            '&c1= ..  c1
            '&n= .. n
                                            Donation mode only parms
            '&delay=' .. Delay
            '&v7=' .. WaterConsumption
            '&v8=' .. InverterFrequency
            '&v11=' .. InverterTemp
            '&v12=' .. GasConsumption
            return postdDataAsString
        if item.isHTTPResponse then
            dz.log("Return from PVOutput ==>> " .. item.data,dz.LOG_FORCE)
            PVSettings =
            url = 'HTTPS://pvoutput.org/service/r2/addstatus.jsp',
            api = dz.variables('PVoutput_API').value,
            id  = dz.variables('PVoutput_ID').value,
            post2PVOutput(PVSettings, makepostData())
Posted: Friday 31 January 2020 10:01
by EddyG
Tnx, I converted my script to openURL, but I will look into your script because it looks more simple then my script. :D
Posted: Wednesday 25 March 2020 11:54
by hansonexperience
EddyG wrote: Friday 31 January 2020 10:01 Tnx, I converted my script to openURL, but I will look into your script because it looks more simple then my script. :D
Hi I have the same issue. How did you convert your script to openURL? Could you share your script so I can use it? I have the same script.
Posted: Wednesday 25 March 2020 13:12
by hansonexperience
waaren wrote: Friday 31 January 2020 9:31
            on =    {
       logging =    {
                        marker  =   "pvOutput"
            dz.openURL({
                method = 'POST',
                headers = {
                postData = postData
            '&c1=1'
                v5 - temperature
                v6 - voltage
            '&c1= ..  c1
            '&n= .. n
            '&delay=' .. Delay
            PVSettings =
Seems like a great script. I am using lua script now and want to use this script in dzvents. Never did that. I have solar power in a device coming in how can I change the script so that this also uploaded?
And were exactly do I have to store the api and password?
Posted: Wednesday 25 March 2020 13:51
by waaren
hansonexperience wrote: Wednesday 25 March 2020 13:12 I am using lua script now and want to use this script in dzVents. Never did that. I have solar power in a device coming in how can I change the script so that this also uploaded?
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
The solar power can be entered in parm v1 (Where I use P1.return1 + P1.return2)
The password and API are to be entered in the domoticz uservariables PVoutput_API and PVoutput_ID (both string types)
Posted: Wednesday 25 March 2020 16:05
by hansonexperience
waaren wrote: Wednesday 25 March 2020 13:51
Great!
Could you please help me out. I have these devices as seen on the picture now which were fine for uploading to pvoutput.
Zonnepanelen=solarpanels (youless)
Power=P1 (youless)
Elektra=calculation (zonnepanelen-power)
Gas=P1 (youless) Where do I have to enter them in the dzevent script?
I let temperature coming in pvoutput from wunderground (filled by my meteobridge nanosd). No voltage.
Devices setup in domoticz
Schermafbeelding 2020-03-25 om 15.52.55.png (224.72 KiB) Viewed 3981 times
