Setting starttime Switch
Posted: Wednesday 30 October 2019 20:33
by michelb
My wife has to start on differtent times in the morging on differtent days with no reoccurence. Therefore I would like te let her set the time she has to wake up. Depending on that time various devices will activate. What kind of Switch do I need? I tried a dummy switch with a preset of values, but I can't compare the actual time with the value set in the switch. The logic should eventually be something like below.
if [time set in switch <> "0:00"
If actual time >= [time set in switch]
do actions..
[time set in switch] = "0:00"
endif
endif
The only thing my wife needs to do is setting the time in the timer
Re: Setting starttime Switch
Posted: Wednesday 30 October 2019 22:22
by waaren
michelb wrote: Wednesday 30 October 2019 20:33
For the dzVents script below you will need a selector switch. Level 0 should be named 'Off' and other levels can be times in hh:mm format.
- Selectorswitch for alarmclock times
- alarm.png (25.8 KiB) Viewed 1617 times
When not yet familiar with dzVents please start with reading
Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
-- Alarm clock [ dzVents >= 2.4 ]
scriptVar = '20191030 Alarmclock'
return
on =
timer = { "at 00:07" }, -- daily run once to pick up target time
httpResponses = { scriptVar }, -- Trigger the handle Json part
logging = { level = domoticz.LOG_DEBUG },
execute = function(dz, item)
local alarmTime = dz.devices('Alarm clock').levelName
local minutesIn24Hours = 24 * 60
local now = dz.time -- Get current time into time object
local Time = require('Time')
local targetTime = Time(dz.time.rawDate .. ' ' .. alarmTime .. ':00') -- Create target time object
local function triggerAlarm(delay)
local message = 'tring, trrring, trrring alarmclock ringing now. Was set on '.. dz.time.rawDate .. ', at ' .. dz.time.rawTime
local url = dz.settings['Domoticz url'] .. "/json.htm?type=command¶m=addlogmessage&message=" .. dz.utils.urlEncode(message)
dz.openURL({ url = url, callback = scriptVar }).afterMin(math.floor(delay))
if not(item.isHTTPResponse) then
dz.log('Alarm time is set at : ' .. alarmTime)
local deltaMinutes = math.floor(now.compare(targetTime).minutes)
if now.compare(targetTime).compare < 1 then -- targetTime is in future
deltaMinutes = minutesIn24Hours - deltaMinutes
dz.log('Alarmactions will be triggered in ' .. deltaMinutes .. ' minutes' ,dz.LOG_DEBUG)
triggerAlarm(deltaMinutes)
-- do wakeup actions.. here
dz.log('wake up actions here....' ,dz.LOG_DEBUG)
Posted: Thursday 31 October 2019 19:27
by pvklink
Nice!
when alarm, switch a device and when the device is on, then play a wav file !
or
use dashtic that can speak when a device is on or off !
Other Options:
When
pushing the alarm switch off, kill the current alarm and dont set it again..
pushing an selector item other then 0ff set's the alarm (calls the json), then you dont need the On... and you can adjust the alarm anytime also for a short time before the on triggers...
Posted: Saturday 31 October 2020 14:18
by Dutchsea
I got the script working and know have an alarm clock that activates a lights scene, my Sonos player at my bedroom and the heater in my bathroom.
Only get a error when the alarm is set to "Off" via the selector switch:
2020-10-31 14:05:00.484 Error: dzVents: Error: (3.0.2) sDate was invalid. Reset to 2020-10-31 14:5:0.320
I expect this is because the alarmtime input is a string "Off" while it expects a time. Or did i miss something in the code of the alarm clock?
return
{ active = true,
on =
timer = { 'every hour' }, -- hourly run once to pick up target time
local alarmTime = dz.devices('Wekker').levelName
dz.devices('Kachel badkamer').switchOn()
dz.devices('Kachel badkamer').switchOff().afterMin(15)
dz.openURL('http://192.xxx.x.xxx:5005/Slaapkamer/volume/10')
dz.openURL('http://192.xxx.x.xxx:5005/Slaapkamer/unmute')
dz.openURL('http://192.xxx.x.xxx:5005/Slaapkamer/favorite/ClassicFM')
dz.scenes('Awaken').switchOn()
Posted: Saturday 31 October 2020 19:07
by waaren
Dutchsea wrote: Saturday 31 October 2020 14:18
That seems indeed to be the issue. Should be fixed in below modified script.
return
{ active = true,
on =
if alarmTime ~= 'Off' then
Posted: Saturday 31 October 2020 23:01
by Dutchsea
Yes, no more error! Thank you.
