wait for x seconds  [Solved]
pvklink
Domoticz version: latest b
wait for x seconds
Post by pvklink »
Hi, I build a small security system with domoticz as my professional system is becoming old and partially integrated in my domoticz.
I have two doorsensors as a test and use the security panel and a remote key.
My prof alarm system also switches the security panel after some soldering, so i have a working basis!
I bought two sensors, the wifi kerui works great with open and close, the other not, this is '$doorsensor_meterkast_2.
When i
a. switch off the alarm with a remote key it takes some time before the security panel is switch off
b. When i open the door and the doorsensor gives a message, it will trigger an alarm when the secpanel is armed
Question:
1. if the panel is still busy with switching to off is it possible that my door open message still activates the alarm? or is it queued?
2. do i have to create a wait timer before check the panel status? and how?
3. The cheaper sensor '$doorsensor_meterkast_2 sends only an on message i think, i attached a dump with:
http://192.168.20.35:82/json.htm?type=d ... ayhidden=1
when i open/close the sensors i see data and status change from Action, to ALarm etc. but when i use these values as item.state it does not work
Can you look at my datadump for an explanation
PM: i use 2 extra sensors that are copies off my real sensors because dashticz interpretates these sensors wrong and diferently...
--http://192.168.20.35:82/json.htm?type=devices&rid=1774&displayhidden=1
--kijk naar status en data
    on =        {
                	    devices         =   {'$doorsensor*'}
    logging =   {       level   =   domoticz.LOG_ERROR,      -- change to LOG_ERROR when script runs without problems otherwise LOG_DEBUG
    execute = function(dz,item,info)
    _G.logMarker = _G.moduleLabel -- marker wordt scriptnaam
    local securityPanel = dz.devices(1728) --security panel
    local messageTable = {}
    if item.name == '$doorsensor_meterkast_2' then
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SENSOREN: Beweging gedetecteerd op device: ' .. item.name .. ' om:' .. dz.time.rawTime .. item.state .. ' status: deur is:' .. item.state)
        if item.state == 'Alarm' then
            dz.devices('doorsensor_meterkast_2').open().checkFirst()
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SENSOREN: Beweging gedetecteerd op device: ' .. item.name .. ' om:' .. dz.time.rawTime .. item.state .. ' status: deur is alarm...')
        elseif item.state == 'Motion' then
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SENSOREN: Beweging gedetecteerd op device: ' .. item.name .. ' om:' .. dz.time.rawTime .. item.state .. ' status: deur is motion...')
            dz.devices('doorsensor_meterkast_2').close().checkFirst()
    -- function wilcard gebruiken om alle sensoren gelijk te behandeln
    elseif item.name == '$doorsensor_tuindeur_1' then
        if item.state == 'Open' then
            dz.devices('doorsensor_tuindeur_1').open().checkFirst()
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SENSOREN: Beweging gedetecteerd op device: ' .. item.name .. ' om:' .. dz.time.rawTime .. ' status: deur is open...')
            if (securityPanel.state ~= 'Disarmed') then
                dz.devices('Alarm_knop').switchOn().checkFirst()
            dz.devices('doorsensor_tuindeur_1').close().checkFirst()
            dz.helpers.globalMessage2(dz,item,info,messageTable,'add', ' SENSOREN: Beweging gedetecteerd op device: ' .. item.name .. ' om:' .. dz.time.rawTime .. ' status: deur is dicht...')
    dz.helpers.globalMessage2(dz,item,info,messageTable,'chg') -- dump
Jablotron connection, Ikea
Re: wait for x seconds
pvklink wrote: Wednesday 30 October 2019 15:41 when i open/close the sensors i see data and status change from Action, to ALarm etc. but when i use these values as item.state it does not work
Can you please include a dz.devices('devicename').dump in your script and share the resulting loglines ?
Try the same after removing the $ from the name and if the resulting log is different than also share.
pvklink
Post by pvklink »
ok,
this is the code when removeing the $ and after open the sensor
2019-10-31 20:55:18.897 Status: dzVents: > urlDecode()
2019-10-31 20:55:18.897 Status: dzVents: > toCelsius()
2019-10-31 20:55:18.897 Status: dzVents: > print()
2019-10-31 20:55:18.897 Status: dzVents: > osExecute()
2019-10-31 20:55:18.897 Status: dzVents: > leftPad()
2019-10-31 20:55:18.897 Status: dzVents: > round()
2019-10-31 20:55:18.897 Status: dzVents: > rightPad()
2019-10-31 20:55:18.897 Status: dzVents: > centerPad()
2019-10-31 20:55:18.897 Status: dzVents: > urlEncode()
2019-10-31 20:55:18.897 Status: dzVents: > sceneExists()
2019-10-31 20:55:18.897 Status: dzVents: > yday: 304
2019-10-31 20:55:18.897 Status: dzVents: > ruleMatchesTime()
2019-10-31 20:55:18.898 Status: dzVents: > raw: 2019-10-31 20:54:47
2019-10-31 20:55:18.898 Status: dzVents: > ruleIsAtSunrise()
2019-10-31 20:55:18.898 Status: dzVents: > minutesAgo: 0
2019-10-31 20:55:18.898 Status: dzVents: > ruleIsAtCivilTwilightEnd()
2019-10-31 20:55:18.898 Status: dzVents: > wday: 5
2019-10-31 20:55:18.898 Status: dzVents: > compare()
2019-10-31 20:55:18.898 Status: dzVents: > seconds: 47
2019-10-31 20:55:18.898 Status: dzVents: > current:
2019-10-31 20:55:18.898 Status: dzVents: > sec: 18
2019-10-31 20:55:18.898 Status: dzVents: > month: 10
2019-10-31 20:55:18.898 Status: dzVents: > day: 31
2019-10-31 20:55:18.898 Status: dzVents: > min: 55
2019-10-31 20:55:18.898 Status: dzVents: > yday: 304
2019-10-31 20:55:18.898 Status: dzVents: > hour: 20
2019-10-31 20:55:18.898 Status: dzVents: > isdst: false
2019-10-31 20:55:18.898 Status: dzVents: > year: 2019
2019-10-31 20:55:18.898 Status: dzVents: > dDate: 1572551687
2019-10-31 20:55:18.898 Status: dzVents: > minutes: 54
2019-10-31 20:55:18.898 Status: dzVents: > getISO()
2019-10-31 20:55:18.898 Status: dzVents: > msAgo: 31778
2019-10-31 20:55:18.898 Status: dzVents: > rawDate: 2019-10-31
2019-10-31 20:55:18.898 Status: dzVents: > ruleIsAtCivilTwilightStart()
2019-10-31 20:55:18.898 Status: dzVents: > dayAbbrOfWeek: thu
2019-10-31 20:55:18.898 Status: dzVents: > secondsAgo: 31
2019-10-31 20:55:18.898 Status: dzVents: > ruleIsAfterSunrise()
2019-10-31 20:55:18.898 Status: dzVents: > updateWeight()
2019-10-31 20:55:18.898 Status: dzVents: > isDevice: true
2019-10-31 20:55:18.898 Status: dzVents: > updateTempHum()
2019-10-31 20:55:18.898 Status: dzVents: > nValue: 2
2019-10-31 20:55:18.899 Status: dzVents: > switchType: Door Contact
2019-10-31 20:55:18.899 Status: dzVents: > sValue: Open
2019-10-31 20:55:18.899 Status: dzVents: > updateRain()
2019-10-31 20:55:18.899 Status: dzVents: > setHex()
2019-10-31 20:55:18.899 Status: dzVents: > close()
2019-10-31 20:55:18.899 Status: dzVents: > updateUV()
2019-10-31 20:55:18.899 Status: dzVents: > setKelvin()
2019-10-31 20:55:18.899 Status: dzVents: > isScene: false
2019-10-31 20:55:18.899 Status: dzVents: > isTimer: false
2019-10-31 20:55:18.899 Status: dzVents: > startPlaylist()
2019-10-31 20:55:18.899 Status: dzVents: > _state: Open
2019-10-31 20:55:18.899 Status: dzVents: > setDiscoMode()
2019-10-31 20:55:18.899 Status: dzVents: > setWhiteMode()
2019-10-31 20:55:18.899 Status: dzVents: > name: doorsensor_meterkast_2x
2019-10-31 20:55:18.899 Status: dzVents: > icon: security
2019-10-31 20:55:18.899 Status: dzVents: > kodiPlayPlaylist()
2019-10-31 20:55:18.899 Status: dzVents: > updateHumidity()
2019-10-31 20:55:18.899 Status: dzVents: > dimTo()
2019-10-31 20:55:18.899 Status: dzVents: > setIcon()
2019-10-31 20:55:18.899 Status: dzVents: > kodiPlayFavorites()
2019-10-31 20:55:18.899 Status: dzVents: > kodiSetVolume()
2019-10-31 20:55:18.899 Status: dzVents: > description:
2019-10-31 20:55:18.899 Status: dzVents: > hardwareId: 2
2019-10-31 20:55:18.899 Status: dzVents: > rename()
2019-10-31 20:55:18.899 Status: dzVents: > kodiPlay()
2019-10-31 20:55:18.899 Status: dzVents: > changed: true
2019-10-31 20:55:18.899 Status: dzVents: > kodiSwitchOff()
2019-10-31 20:55:18.899 Status: dzVents: > play()
2019-10-31 20:55:18.899 Status: dzVents: > updateLux()
2019-10-31 20:55:18.899 Status: dzVents: > updateMode()
2019-10-31 20:55:18.899 Status: dzVents: > _nValue: 2
2019-10-31 20:55:18.900 Status: dzVents: > updateVisibility()
2019-10-31 20:55:18.900 Status: dzVents: > activate()
2019-10-31 20:55:18.900 Status: dzVents: > isHTTPResponse: false
2019-10-31 20:55:18.900 Status: dzVents: > stop()
2019-10-31 20:55:18.900 Status: dzVents: > quietOn()
2019-10-31 20:55:18.900 Status: dzVents: > dump()
2019-10-31 20:55:18.900 Status: dzVents: > cancelQueuedCommands()
2019-10-31 20:55:18.900 Status: dzVents: > updateTempBaro()
2019-10-31 20:55:18.900 Status: dzVents: > quietOff()
2019-10-31 20:55:18.900 Status: dzVents: > setLevel()
2019-10-31 20:55:18.900 Status: dzVents: > updateCustomSensor()
2019-10-31 20:55:18.900 Status: dzVents: > switchOn()
2019-10-31 20:55:18.900 Status: dzVents: > onkyoEISCPCommand()
2019-10-31 20:55:18.900 Status: dzVents: > incrementCounter()
2019-10-31 20:55:18.900 Status: dzVents: > isSecurity: false
2019-10-31 20:55:18.900 Status: dzVents: > setHue()
2019-10-31 20:55:18.900 Status: dzVents: > updateCounter()
2019-10-31 20:55:18.900 Status: dzVents: > kodiExecuteAddOn()
2019-10-31 20:55:18.900 Status: dzVents: > updatePressure()
2019-10-31 20:55:18.900 Status: dzVents: > switchSelector()
2019-10-31 20:55:18.900 Status: dzVents: > active: true
2019-10-31 20:55:18.900 Status: dzVents: > signalLevel: 5
2019-10-31 20:55:18.900 Status: dzVents: > kodiPause()
this is the code when removeing the $ and after close the sensor
2019-10-31 20:58:31.237 Status: dzVents: > sec: 31
2019-10-31 20:58:31.238 Status: dzVents: > min: 58
2019-10-31 20:58:31.238 Status: dzVents: > wday: 5
2019-10-31 20:58:31.238 Status: dzVents: > year: 2019
2019-10-31 20:58:31.238 Status: dzVents: > yday: 304
2019-10-31 20:58:31.238 Status: dzVents: > month: 10
2019-10-31 20:58:31.238 Status: dzVents: > hour: 20
2019-10-31 20:58:31.238 Status: dzVents: > isdst: false
2019-10-31 20:58:31.238 Status: dzVents: > day: 31
2019-10-31 20:58:31.238 Status: dzVents: > ruleIsAtSunrise()
2019-10-31 20:58:31.238 Status: dzVents: > ruleMatchesTimeRange()
2019-10-31 20:58:31.238 Status: dzVents: > ruleIsAtNight()
2019-10-31 20:58:31.238 Status: dzVents: > ruleIsAtSunset()
2019-10-31 20:58:31.238 Status: dzVents: > ruleIsInWeek()
2019-10-31 20:58:31.238 Status: dzVents: > ruleMatchesTime()
2019-10-31 20:58:31.239 Status: dzVents: > msAgo: 193112
2019-10-31 20:58:31.239 Status: dzVents: > milliSeconds: 0
2019-10-31 20:58:31.239 Status: dzVents: > isUTC: false
2019-10-31 20:58:31.239 Status: dzVents: > ruleMatchesMinuteSpecification()
2019-10-31 20:58:31.239 Status: dzVents: > ruleIsAtDayTime()
2019-10-31 20:58:31.239 Status: dzVents: > ruleIsAtCivilDayTime()
2019-10-31 20:58:31.239 Status: dzVents: > ruleIsAfterSunset()
2019-10-31 20:58:31.239 Status: dzVents: > ruleIsBeforeSunset()
2019-10-31 20:58:31.239 Status: dzVents: > ruleIsBeforeSunrise()
2019-10-31 20:58:31.239 Status: dzVents: > dDate: 1572551718
2019-10-31 20:58:31.239 Status: dzVents: > hour: 20
2019-10-31 20:58:31.239 Status: dzVents: > rawTime: 20:55:18
2019-10-31 20:58:31.239 Status: dzVents: > ruleIsAfterCivilTwilightEnd()
2019-10-31 20:58:31.240 Status: dzVents: > ruleIsBeforeCivilTwilightEnd()
2019-10-31 20:58:31.240 Status: dzVents: > secondsAgo: 193
2019-10-31 20:58:31.240 Status: dzVents: > minutes: 55
2019-10-31 20:58:31.240 Status: dzVents: > ruleIsBeforeCivilTwilightStart()
2019-10-31 20:58:31.240 Status: dzVents: > week: 44
2019-10-31 20:58:31.240 Status: dzVents: > ruleIsOnDate()
2019-10-31 20:58:31.240 Status: dzVents: > minutesAgo: 3
2019-10-31 20:58:31.240 Status: dzVents: > ruleIsOnDay()
2019-10-31 20:58:31.240 Status: dzVents: > getISO()
2019-10-31 20:58:31.240 Status: dzVents: > year: 2019
2019-10-31 20:58:31.240 Status: dzVents: > isToday: true
2019-10-31 20:58:31.240 Status: dzVents: > rawDateTime: 2019-10-31 20:55:18
2019-10-31 20:58:31.240 Status: dzVents: > millisecondsAgo: 193112
2019-10-31 20:58:31.241 Status: dzVents: > compare()
2019-10-31 20:58:31.241 Status: dzVents: > isdst: false
2019-10-31 20:58:31.241 Status: dzVents: > utils:
2019-10-31 20:58:31.241 Status: dzVents: > log()
2019-10-31 20:58:31.241 Status: dzVents: > centerPad()
2019-10-31 20:58:31.241 Status: dzVents: > hsbToRGB()
2019-10-31 20:58:31.241 Status: dzVents: > deviceExists()
2019-10-31 20:58:31.241 Status: dzVents: > LOG_DEBUG: 4
2019-10-31 20:58:31.241 Status: dzVents: > leadingZeros()
2019-10-31 20:58:31.241 Status: dzVents: > urlDecode()
2019-10-31 20:58:31.241 Status: dzVents: > rgbToHSB()
2019-10-31 20:58:31.241 Status: dzVents: > toCelsius()
2019-10-31 20:58:31.241 Status: dzVents: > groupExists()
2019-10-31 20:58:31.242 Status: dzVents: > numDecimals()
2019-10-31 20:58:31.242 Status: dzVents: > leftPad()
2019-10-31 20:58:31.242 Status: dzVents: > LOG_MODULE_EXEC_INFO: 2
2019-10-31 20:58:31.242 Status: dzVents: > LOG_ERROR: 1
2019-10-31 20:58:31.242 Status: dzVents: > urlEncode()
2019-10-31 20:58:31.243 Status: dzVents: > cameraExists()
2019-10-31 20:58:31.243 Status: dzVents: > round()
2019-10-31 20:58:31.243 Status: dzVents: > LOG_FORCE: 0.5
2019-10-31 20:58:31.243 Status: dzVents: > dumpTable()
2019-10-31 20:58:31.243 Status: dzVents: > variableExists()
2019-10-31 20:58:31.243 Status: dzVents: > fromJSON()
2019-10-31 20:58:31.243 Status: dzVents: > LOG_INFO: 3
2019-10-31 20:58:31.243 Status: dzVents: > toJSON()
2019-10-31 20:58:31.243 Status: dzVents: > print()
2019-10-31 20:58:31.243 Status: dzVents: > inTable()
2019-10-31 20:58:31.243 Status: dzVents: > osExecute()
2019-10-31 20:58:31.243 Status: dzVents: > rightPad()
2019-10-31 20:58:31.243 Status: dzVents: > stringSplit()
2019-10-31 20:58:31.243 Status: dzVents: > DZVERSION: 2.4.29
2019-10-31 20:58:31.244 Status: dzVents: > sceneExists()
2019-10-31 20:58:31.244 Status: dzVents: > fileExists()
2019-10-31 20:58:31.244 Status: dzVents: > seconds: 18
2019-10-31 20:58:31.244 Status: dzVents: > name: doorsensor_meterkast_2x
2019-10-31 20:58:31.244 Status: dzVents: > id: 1774
2019-10-31 20:58:31.244 Status: dzVents: > updateVisibility()
2019-10-31 20:58:31.244 Status: dzVents: > updateAirQuality()
2019-10-31 20:58:31.244 Status: dzVents: > updateTemperature()
2019-10-31 20:58:31.244 Status: dzVents: > isDevice: true
2019-10-31 20:58:31.244 Status: dzVents: > updateHumidity()
2019-10-31 20:58:31.244 Status: dzVents: > kodiPlayPlaylist()
2019-10-31 20:58:31.244 Status: dzVents: > updateSoundLevel()
2019-10-31 20:58:31.244 Status: dzVents: > maxDimLevel: 0
2019-10-31 20:58:31.244 Status: dzVents: > updateCustomSensor()
2019-10-31 20:58:31.245 Status: dzVents: > timedOut: false
2019-10-31 20:58:31.245 Status: dzVents: > quietOff()
2019-10-31 20:58:31.245 Status: dzVents: > updateWind()
2019-10-31 20:58:31.245 Status: dzVents: > switchSelector()
2019-10-31 20:58:31.245 Status: dzVents: > setIcon()
2019-10-31 20:58:31.245 Status: dzVents: > cancelQueuedCommands()
2019-10-31 20:58:31.245 Status: dzVents: > dimTo()
2019-10-31 20:58:31.245 Status: dzVents: > protectionOn()
2019-10-31 20:58:31.245 Status: dzVents: > updateP1()
2019-10-31 20:58:31.245 Status: dzVents: > updateAlertSensor()
open state is _State: Open, nvalue=2, Svalue = Open
close state of this device is .... nothing
and when i do this a couple of times i also get _State: Open when closing it...
so not relyable, look likes a cheap device with no on/off or open/close
Think i use this as a toggle... and buy kerui ones, those gives open and close for $7
PROBLEM:
Only need to solve my problem that
1. when i put my domoticz security panel to not armed with an remote when i am outside and then
2. quickly open the door with the kerui sensor my alarm goes off. So after action 1 the command to disactivate the panel is to late to change the state because the door open gives an alarm when the security panel is armed.....
pvklink wrote: Thursday 31 October 2019 20:46 this is the code when removeing the $ and after pushing this the sensor gives Normaal
this is the code when removeing the $ and after pushing this the sensor gives Alarm
Sorry but these dumps only contain 100 lines each and do not contain the information I need. If you enable logging to an OS file (you can enable this in /etc/init.d/domoticz.sh) you can copy / paste the complete dump.
pvklink
Post by pvklink »
ahh, sorry i grabbed them from domoticz . i do it again... For understanding how it works this is a nice exercise!
i did enabled, so it must be there also!
pvklink
Post by pvklink »
ok,
I included the logfile.
I only took the last hour for the named device and some open and close logs...
I removed all the other devices and other stuff...
domoticz.txt
(195.16 KiB) Downloaded 25 times
Re: wait for x seconds  [Solved]
pvklink wrote: Thursday 31 October 2019 21:38 I included the logfile.
OK. What I see in the dumps is that the state can be 'Normal' or 'Open' (I guess 'Open' is "Alarm')
So if you change the
to
and
to
if item.state == 'Normal'
this part should work
pvklink
Post by pvklink »
Thanks i will try that, and learned that with the dump() i can do this myself the next time !
pvklink
Post by pvklink »
open, close, motion and alarm did not work, lots of times is sends open instead of close.. this var is not stable
i tried another var, nvalue (with your dump-advise), that did the trick!
if item.name == 'doorsensor_meterkast_2x' then
if dz.devices('doorsensor_meterkast_2x').nValue == 2 then
elseif dz.devices('doorsensor_meterkast_2x').nValue == 4 then
