Reduce logging for Zwave
Posted: Sunday 27 October 2019 23:39
by BOverdevest
As I have quit some devices connected via openzwave, my log fils up with messages on zwave actions/data transfer.
How do I change the logging to a ' error only' setting?
2019-10-27 23:34:24.788 (ZWave) Usage (Vaatwasser Verbruik)
2019-10-27 23:34:24.798 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:25.950 (ZWave) General/Voltage (Voltage)
2019-10-27 23:34:26.780 (ZWave) Current (Unknown)
2019-10-27 23:34:53.410 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:53.497 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:53.555 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:54.383 (ZWave) Usage (PS4 Verbruik)
2019-10-27 23:34:54.389 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:54.471 (ZWave) Usage (PS4 Verbruik)
2019-10-27 23:34:54.475 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:55.399 (ZWave) General/Voltage (Voltage)
2019-10-27 23:34:55.461 (ZWave) General/Voltage (Voltage)
2019-10-27 23:34:56.381 (ZWave) Current (Unknown)
2019-10-27 23:36:01.002 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:01.913 (ZWave) Usage (Qooker Verbruik)
2019-10-27 23:36:01.919 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:02.991 (ZWave) General/Voltage (Voltage)
2019-10-27 23:36:03.909 (ZWave) Current (Unknown)
2019-10-27 23:36:08.201 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:09.196 (ZWave) Usage (Pomp Vloerverwarming Verbruik)
2019-10-27 23:36:09.205 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:10.182 (ZWave) General/Voltage (Voltage)
2019-10-27 23:36:11.182 (ZWave) Current (Unknown)
2019-10-27 23:36:29.686 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:30.630 (ZWave) Usage (Droger Verbruik)
2019-10-27 23:36:30.643 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:31.673 (ZWave) General/Voltage (Voltage)
2019-10-27 23:36:32.924 (ZWave) Current (Unknown)
2019-10-27 23:36:33.463 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:33.483 (ZWave) Current (Unknown)
2019-10-27 23:36:34.254 (ZWave) Usage (Wasmachine Verbruik)
Re: Reduce logging for Zwave
Posted: Monday 28 October 2019 0:33
by waaren
BOverdevest wrote: Sunday 27 October 2019 23:39 As I have quit some devices connected via openzwave, my log fils up with messages on zwave actions/data transfer.
doing a
sudo cat -n /etc/init.d/domoticz.sh | more
on my system give
     1  #! /bin/sh
     2  ### BEGIN INIT INFO
     3  # Provides:          domoticz
     4  # Required-Start:    $network $remote_fs $syslog $time
     5  # Required-Stop:     $network $remote_fs $syslog
     6  # Default-Start:     2 3 4 5
     7  # Default-Stop:      0 1 6
     8  # Short-Description: Home Automation System
     9  # Description:       This daemon will start the Domoticz Home Automation System
    10  ### END INIT INFO
    11
    12  # Do NOT "set -e"
    13
    14  PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
    15  DESC="Domoticz Home Automation System"
    16  NAME=domoticz
    17  USERNAME=root
    18  PIDFILE=/var/run/$NAME.pid
    19  SCRIPTNAME=/etc/init.d/$NAME
    20  DOMOTICZDIR=/opt/domoticz
    21
    22  DAEMON=$DOMOTICZDIR/$NAME
    23  DAEMON_ARGS="-daemon"
    24  DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
    25  DAEMON_ARGS="$DAEMON_ARGS -www 8084"
    26  DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
    27  DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log"
    28  DAEMON_ARGS="$DAEMON_ARGS -loglevel  normal,status,error"
    29  #DAEMON_ARGS="$DAEMON_ARGS -loglevel  error"
    30  DAEMON_ARGS="$DAEMON_ARGS -sslcert /opt/domoticz/letsencrypt_server_cert.pem"
    31  #DAEMON_ARGS="$DAEMON_ARGS -debuglevel hardware, received, webserver, eventsystem "
    32  #DAEMON_ARGS="$DAEMON_ARGS -syslog"
    33
If you have the line like my line 28 then change this to
and if you don't then insert it after line 23
after that do a
sudo systemctl daemon-reload
sudo service  domoticz restart
