BOverdevest
Posts: 23 Joined: Wednesday 28 March 2018 20:56
Domoticz version: 4.11307
Post
by BOverdevest » Sunday 27 October 2019 23:39
As I have quit some devices connected via openzwave, my log fils up with messages on zwave actions/data transfer.
How do I change the logging to a ' error only' setting?
2019-10-27 23:34:24.788 (ZWave) Usage (Vaatwasser Verbruik)
2019-10-27 23:34:24.798 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:25.950 (ZWave) General/Voltage (Voltage)
2019-10-27 23:34:26.780 (ZWave) Current (Unknown)
2019-10-27 23:34:53.410 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:53.497 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:53.555 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:54.383 (ZWave) Usage (PS4 Verbruik)
2019-10-27 23:34:54.389 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:54.471 (ZWave) Usage (PS4 Verbruik)
2019-10-27 23:34:54.475 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:34:55.399 (ZWave) General/Voltage (Voltage)
2019-10-27 23:34:55.461 (ZWave) General/Voltage (Voltage)
2019-10-27 23:34:56.381 (ZWave) Current (Unknown)
2019-10-27 23:36:01.002 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:01.913 (ZWave) Usage (Qooker Verbruik)
2019-10-27 23:36:01.919 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:02.991 (ZWave) General/Voltage (Voltage)
2019-10-27 23:36:03.909 (ZWave) Current (Unknown)
2019-10-27 23:36:08.201 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:09.196 (ZWave) Usage (Pomp Vloerverwarming Verbruik)
2019-10-27 23:36:09.205 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:10.182 (ZWave) General/Voltage (Voltage)
2019-10-27 23:36:11.182 (ZWave) Current (Unknown)
2019-10-27 23:36:29.686 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:30.630 (ZWave) Usage (Droger Verbruik)
2019-10-27 23:36:30.643 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:31.673 (ZWave) General/Voltage (Voltage)
2019-10-27 23:36:32.924 (ZWave) Current (Unknown)
2019-10-27 23:36:33.463 (ZWave) General/kWh (kWh Meter)
2019-10-27 23:36:33.483 (ZWave) Current (Unknown)
2019-10-27 23:36:34.254 (ZWave) Usage (Wasmachine Verbruik)
HUE, Tradfri, Zwave, RFXCOM, rooted TOON, PS4
Posts: 6028 Joined: Tuesday 03 January 2017 14:18
Post
by waaren » Monday 28 October 2019 0:33
BOverdevest wrote: Sunday 27 October 2019 23:39
doing a
sudo cat -n /etc/init.d/domoticz.sh | more on my system give
1 #! /bin/sh
2 ### BEGIN INIT INFO
3 # Provides: domoticz
4 # Required-Start: $network $remote_fs $syslog $time
5 # Required-Stop: $network $remote_fs $syslog
6 # Default-Start: 2 3 4 5
7 # Default-Stop: 0 1 6
8 # Short-Description: Home Automation System
9 # Description: This daemon will start the Domoticz Home Automation System
10 ### END INIT INFO
11
12 # Do NOT "set -e"
13
14 PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
15 DESC="Domoticz Home Automation System"
16 NAME=domoticz
17 USERNAME=root
18 PIDFILE=/var/run/$NAME.pid
19 SCRIPTNAME=/etc/init.d/$NAME
20 DOMOTICZDIR=/opt/domoticz
21
22 DAEMON=$DOMOTICZDIR/$NAME
23 DAEMON_ARGS="-daemon"
24 DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
25 DAEMON_ARGS="$DAEMON_ARGS -www 8084"
26 DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
27 DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log"
28 DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error"
29 #DAEMON_ARGS="$DAEMON_ARGS -loglevel error"
30 DAEMON_ARGS="$DAEMON_ARGS -sslcert /opt/domoticz/letsencrypt_server_cert.pem"
31 #DAEMON_ARGS="$DAEMON_ARGS -debuglevel hardware, received, webserver, eventsystem "
32 #DAEMON_ARGS="$DAEMON_ARGS -syslog"
33
If you have the line like my line 28 then change this to
and if you don't then insert it after line 23
after that do a
sudo systemctl daemon-reload
sudo service domoticz restart
dzVents wiki
