Open Weather Map
Posted: Sunday 27 October 2019 14:57
by Dave47
I use Open Weather Map for the weather
when i go to the settings in Dashticz, the weather
I try to change and save settings there.
Nothing changes in the settings
I also tried changing the settings in CONFIG.JS
what am I doing wrong?
Re: Open Weather Map
Posted: Wednesday 30 October 2019 11:18
by Dave47
Nobody?
Posted: Wednesday 30 October 2019 12:50
by Lokonli
Dave47 wrote: Sunday 27 October 2019 14:57
If you want to save the settings from Dashticz then:
1) PHP must be enabled
2) The WWW user (normally root) must have write permission to the file config/CONFIG.js
See the documentation:
https://dashticz.readthedocs.io/en/mast ... stall.html
Manually changing CONFIG.js should of course work as well.
What is the current situation, and what are you trying to achieve? No solution in the documentation?
https://dashticz.readthedocs.io/en/mast ... ather.html
Posted: Wednesday 30 October 2019 14:27
by Dave47
Ok i found it.
