wildcard in string  [Solved]
pvklink
Domoticz version: latest b
wildcard in string
Post by pvklink »
I have a the follwing equation
Can i make this line working for all doorsensors ?
if item.name == 'doorsensor_tuindeur_1' then -- kerui wifi devices kent open en dicht, generiek maken voor alle kerui's
<rest of the code>
something like:
if item.name == 'doorsensor*' then
Jablotron connection, Ikea
Re: wildcard in string
pvklink wrote: Saturday 26 October 2019 19:17 I have a the follwing equation. Can i make this line working for all doorsensors ?
<rest of the code>
Wildcards are handled a bit different in Lua then you might expect if you are used to other languages
You could use something like below function. It handles two types of wildcard chars
'*' wildcard for 0 or more chars.
'?' wildcard for 1 char
local function matchesWildCardedString(stringToMatch, wildCardedString)
    local magicalChars  =  '[^%w%s~{\\}:&(/)<>,?@#|_^*$]'  -- Lua 'magical chars'
    local regExpression = ('^' .. wildCardedString:gsub("[%^$]",".")) -- make it a valid regexpression
    if wildCardedString:find('*') and wildCardedString:find('?') then
        dz.log('Not possible to combine single char wildcard(s) "?" with multi char wildcard(s) "*"',dz.LOG_ERROR)
        return false
    elseif wildCardedString:find('*') then -- a * wild-card was used
        wildCardedString = (regExpression:gsub("*", ".*") .. '$'):gsub(magicalChars,'.') -- replace * with .* (Lua for zero or more of any char)
    elseif wildCardedString:find('?') then -- a ? wild-card was used
        wildCardedString = (regExpression:gsub("?", ".") .. '$'):gsub(magicalChars,'.') -- replace ? with . (Lua for single any char)
    return stringToMatch:match(wildCardedString) == stringToMatch
if matchesWildCardedString(item.name, 'doorsensor*') then
pvklink
Post by pvklink »
wow, i thought this would be easy!
thanks!
Do i use it like this:
if matchesWildCardedString(item.name,'doorsensor*) then OR
if matchesWildCardedString(item.name,'doorsensor_tuindeur_?) then
Re: wildcard in string  [Solved]
pvklink wrote: Saturday 26 October 2019 21:18 Do i use it like this:
You can use either one (if you add the closing quotes) so
if  matchesWildCardedString(item.name,'doorsensor*') then
OR
if  matchesWildCardedString(item.name,'doorsensor_tuindeur_?') then
pvklink
Post by pvklink »
Works great!
I placed it in global_data.lua
