Script editor Topic is solved
Script editor
Here's an idea.
I don't know if it is even possible but it would be uber cool if we had a script editor built into the Domoticz web gui.
Any text (and filename) entered in here could be written directly to the lua folder on the host device.
-theolsen.
-theolsen.
Re: Script editor
+1
good idea
good idea
pepijn
Re: Script editor
-1
The eventsystem (Blocky) is designed to create events (lua) scripts for regular users. The scripts are saved in the Domoticz database witch can be backed up through the gui.
- Dynamic
- Target OS: -
Re: Script editor
+1.
I do not always have SSH-access to my Pi, but the web-interface is always available. Would be great to have a webbased editor. But I think it should be hidden for 'normal' users (checkbox in settings?).
Re: Script editor
Dynamic wrote:+1.
Exactly my reasoning.
Moreover it would enable scripting from a tablet device.
Re: Script editor
I would also add that blocky does not give the same flexibility as LUA.
For instance, and IF/DO/ELSE/DO/END statement embedded into another IF/DO/ELSE/DO/END is not possible in blocky.
So having a web-based LUA editor would be a very welcome new functionality.
so +1.
bistoury.
so +1.
bistoury.
pepijn
Re: Script editor
Try installing shellinabox this gives you full web based ssh access. All you need is a webserver running. If you use the Domoticz SD card it comes with nginx installed for secure https access.Dynamic wrote:+1.
simonrg
- Domoticz version: 3.8807
Re: Script editor
-1
While I think having a LUA IDE built into Domoticz would be neat and potentially platform independent. I would prefer the skilled programming effort was put into extending / supporting the core capabilities of Domoticz.
Pepijn's suggestion of Shellinabox sounds like a good approach. Even more so having set it and played with it all in 5 minutes.
I would like to suggest a compromise, based on pepijn's suggestion, to include Shellinabox configured on the Domoticz SD card and to explain how to set it up on the Wiki.
In fact using Shellinabox seems to be very easy on Raspberry Pi simply two commands:
Now in a web browser http://192.168.1.111:4201 opens a shell in my web browser which allows me to modify LUA scripts.
This means that Domoticz does the automation it's good at and Shellinabox plus all the command line tools looks after all the security issues etc..
sudo apt-get install shellinabox
shellinaboxd --port=4201 -t -s /:AUTH:HOME:/bin/bashThis means that Domoticz does the automation it's good at and Shellinabox plus all the command line tools looks after all the security issues etc..
Re: Script editor
Just installed Shellinabox - very nice indeed!
Thanks for the suggestions.
-theolsen.
-theolsen.
sdh
Re: Script editor
Sorry for opening an old thread, but it would be great if we could enter the LUA script for the device directly in domoticz, similar to Fibaro HC2.
- pipersw
Re: Script editor
+1 for a LUA text editor integrated to Domoticz.
The problem with shellinabox is that it not only allowed to edit text, but also allow ssh command and others stuff.
I prefer to use my own SSH tool for admin commands, and let only a simple text editor integrated in Domoticz for users.
I think it's more secure
for example: http://foicica.com/textadept/ is a lightweight text editor
Domoticz server : Raspberry + RFXCOM433 USB + Razberry
Server : Windows Home Server 2011
Weather : Oregon temperature sensor + Weather Underground
Energy: OWL119
3x plug Chacon DIO
1x Fibaro FDG-211
1x Fibaro FGWPE-101
1x Karotz with OpenKarotz firmware
Energy: OWL119
3x plug Chacon DIO
1x Fibaro FDG-211
1x Fibaro FGWPE-101
- remb0
Re: Script editor
I was also thinking about that (when I was @ work where all ports except 80 are blocked)
But the comments in this thread are fair, the mainstrain users and options are more important.
a LUA settings page
script status versie test edit
script1 active 1.0 check edit
script2 disabled 2.0 check edit
script3 active 0.2 check edit
options: upload script globale variables
script editor:
- velden als:
versie,
opmerking
status
- syntax checker (http://www.lua.org/demo.html)
- testen met test variablen
a LUA settings page
script editor:
- velden als:
versie,
opmerking
status
commodore white
Re: Script editor
I mostly use an android tablet to prrewardrd ogram my raspi domoticz so i thought i'd try this.simonrg wrote:
In fact using Shellinabox seems to be very easy on Raspberry Pi simply two commands:Now in a web browser http://192.168.1.111:4201 opens a shell in my web browser which allows me to modify LUA scripts.Code: Select all
sudo apt-get install shellinabox shellinaboxd --port=4201 -t -s /:AUTH:HOME:/bin/bash
Everything went well until I typed in my raspi username and password (pi/raspberry) at which point I was rewarded by a Session Closed message.
What might I have forgotten to do?
- galadril
- Domoticz version: latest
Re: Script editor
+1 would love a script editor within Domoticz
alfred_j_kwak
- Domoticz version: 2.3530
Re: Script editor
Maybe this link can go under script editor thread?
In Digital Ocean website there is guide how to use sshfs. It is possible to mount like Domoticz script folder in your programming PC and use it like a local folder.
I use Sublime Text for editing scripts and with sshfs I can edit scripts straight from /domoticz/scripts/ folder.
Link to Digital Ocean page: https://www.digitalocean.com/community/ ... s-over-ssh
Like so:
Like so:
- Sublime.png (25.1 KiB) Viewed 9744 times
- Dnpwwo
Re: Script editor
I'm working on putting an editor (see https://ace.c9.io/#nav=about) into Domoticz that will handle Lua (& Python if enabled). It will have code highlighting and and collapsing.
Should be in the Beta release within a week and will need some testers. It will be backwards compatible with old file based scripts but will store new scripts in the database like Blockly does.
It will look a bit like this:will allow users to choose their langauge and when the scripts will be called (device, time, security or uservariable).
- jvdz
- Domoticz version: 4.107
Re: Script editor
I wouldn't mind doing testing on LUA scripts, but would like to understand first why you opted to put the scripts into the database in stead of the regular file systems like it is today?
It feels like you are then totally limited to use the internal editor only, which is not something I would want for myself.
Jos
Jos
- remb0
Re: Script editor
Very nice!! I will test it when released. When de scripts are I the db. It would be great to have extra options like.:
- version
- option to enable/disable
- export to file
- script checker: are variables valid?
- version
- export to file
Dnpwwo wrote:I'm working on putting an editor (see https://ace.c9.io/#nav=about) into Domoticz that will handle Lua (& Python if enabled). It will have code highlighting and and collapsing.
- Dnpwwo
Re: Script editor
You don't have to use it at all if you don't want to. If you want to develop scripts outside Domoticz you can, then store the final version in the database if you want to.It will be backwards compatible with old file based scripts
Enable/disable will work for scripts the same way it does for Blockly currently.
Wasn't going to do an export because you can cut and paste directly in and out of the editor.
Might do syntax checker and 'run now' functionality later but want to get a first version merged
tlpeter
Re: Script editor
I agree on not putting the scripts in the database but in the folder where it belongs.
Otherwise you have two locations where such a script is.
Sometimes i copy the script out, change it and put it back for different kind of reasons.
I do like the effort being put in to this for sure.
