I was very impressed by Dashticz, since i build my own dashboard years ago, i never looked into this. I'm now setting up Domoticz on a new Pi so i wanted to see how this works as well. I've got it installed an my favorites from Domoticz appeared an work as expected.
Now i wanted to expand from here; have tried to add agenda, tv guide, etc. but none seem to appear. Do i need to make additional settings like router ports, file rights or should should Dashticz be in my webserver root for this?
I'm lost, maybe someone could give me a direction here?
I've pulled the V2, would the V3 be a better one to start withuc browser shareit appvn
Newbee... Domoticz works, but api's won't appear!!
Last edited by kimminpuples on Saturday 26 October 2019 5:12, edited 1 time in total.
- HansieNL
Re: Newbee... Domoticz works, but api's won't appear!!
Version 3 is latest version. The beta has all latest additions.
A webserver with PHP has to be installed. See Dashticz manual: https://dashticz.readthedocs.io/
Can you post your CONFIG.js file here so we can help you with what’s going wrong.
Blah blah blah
- pgielen
- Domoticz version: 2020.2
I installed Dashticz v3 today, using the automatic install option, see https://dashticz.readthedocs.io/en/mast ... stall.html
It works fine right out of the box (once you have set up the CONFIG.js).
https://robothuis.nl, RPi4B, RFXCOM XL, Aeotec Z-Stick, ESP Easy, Weatherstation, several switches and sensors, Ikea Trädfri, Philips Hue, Foscam, Reolink, Lyric T6, Ring
