i'm running now Domoticz V4.11403 (latest Beta)
and i changed the security code in settings so the Device should 'normally' be added to the device list.
But it is not added.
Someone else has this problem?
Thank you.
Security Panel
lost
Re: Security Panel
Did this in the past to allow device show-up... last stable migration did not show issue at least on this upgrade path.ropske wrote: Thursday 24 October 2019 8:29 i'm running now Domoticz V4.11403 (latest Beta)
If you device-script a quick test in Lua, linked to some dummy switch status change, are you able to change secpanel status (take care of arm delay)?
Would be a temporary workaround waiting for a fix, if there was a regression.
Well, on my side I use the sec panel but almost never directly: Everything is script driven and linked to a "global presence" dummy switch status that results from an "or" function of every family individuals presence changes (phones detection through bluetooth, less concerned by phones energy saving strategies than wifi, using a python service I wrote, that works well for me as my door is not too far from the PI ; Most of the times, I'm even radio-caught while parking my car).
ropske
- Domoticz version: V3_8394
Re: Security Panel
i didn't used it before, so it was not there yet.
my pi is just running for about 3weeks and still programming it
