PS4 Monitoring  [SOLVED]
Posted: Thursday 24 October 2019 0:33
by BOverdevest
To monitor a certain family member :ugeek: using a PS4 , I had a long wish to do this via Domoticz.
1) Log the status of the device
2) Measure how much time it is on
3) Do a remote shut down
I started with a Coolcam Plug, perfect for monitoring the power and switching it off.
Not so good for family relations; the PS4 does not like to lose power. :?
So researched a software solution:
For Linux PS4-waker is available: https://github.com/dhleong/ps4-waker
I combined this with ping to check first if the machine can be reached.
Step 1 is installing PS4-waker and making sure it work on the CLI (Command Line Interface
> PS4-waker check should give a JSON in return
I set up two bash scripts, placed in ~/domoticz/scripts (see below)
These are used to start and stop (stand by) the PS4, via PS4-waker
There is a dummy Selector Switch with 4 states (0=OFF, 10=Standby, 20=On, 30=Gaming)
The level 0 and 10 have "script://stopps4.sh" as action
The level 20 and 30 have "script://startps4.sh" as action
So using this the playstation can be started/ put in stand by.
Also, I made an Alert device. This one also holds the status of the PS4 as per above (including changing the color)
When it is in gaming mode, the game being played will be logged as well in the alert text as well.
And of course a timer. I have not been able to get the counter to work on 'time' itself, so i simply count the minutes.
There are two timers; 1 is incremented by 1 every minute, the other has the GameTIme.counterToday pushed in.
As I reset the timer back to zero at the end of the day, all data is lost --> needs to be improved to have just 1 timer....
Further improvement:
- Making the counter work, with a single counter based on time. Any examples?
- decide between using Alert device or selector switch, any opinions?
- notification to the parent when the game time goes beyond acceptable levels
- Expand the selector switch with actual games. (these could be started via ps4-waker as well)
- biggest wish: move the whole thing to a python plug in...
other ideas? improvements?
local TimerSetting = "every minute" local n=1
-- local TimerSetting = "every 10 minutes" local n=10
      on = {timer = {TimerSetting}},
      	logging = { level = domoticz.LOG_INFO
                ,marker = "PS4"},
	execute = function(domoticz, trigger)
        local PS4Switch      = domoticz.devices("PS4 Selector Switch") -- To see status and change status
        local PS4Alert       = domoticz.devices("PS4 Status")  -- General / Alert
        local GameTime       = domoticz.devices("PS4 Uptime") -- General /Incremental Counter
        local GameTimeToday  = domoticz.devices("PS4 Uptime Today") -- RFXMeter/RFXMeter counter
        local PS4StatusOld   = PS4Switch.state
        local grey          = domoticz.ALERTLEVEL_GREY
        local green         = domoticz.ALERTLEVEL_GREEN
        local yellow        = domoticz.ALERTLEVEL_YELLOW
        local json = require "JSON"
        local level = 0
        local handle2 = assert(io.popen("ping -c 1 192.168.1.241 | grep -q 'Destination Host Unreachable' && echo 'Off Line'"))
        local PS4status = handle2:read("*all")
        handle2:close()
        if string.sub(PS4status,1,8) == "Off Line" then
            if PS4Switch.level ~= level then PS4Switch.switchSelector(0).silent() end
            if GameTime.counter ~= 0 then GameTime.updateCounter(0) end
            if PS4Alert.text ~= "Off" then PS4Alert.updateAlertSensor(grey, "Off") end
        else -- Playstation should be reachable. Time to use ps4-waker
            local handle = assert(io.popen("ps4-waker check"))
                local PS4status = string.gsub(handle:read("*all"), "-", "") -- remove the "-"
            handle:close()
           jsonPS4status = json:decode(PS4status)            -- Turn JSON into LUA table
            if jsonPS4status.status == "Standby" then
                print("Standby")
                level = 10
                if PS4Switch.level ~= level then PS4Switch.switchSelector(level).silent() end-- Set selector to Standby
                if PS4Alert.text ~= "Standby" then PS4Alert.updateAlertSensor(grey, "Standby") end
            elseif jsonPS4status.runningappname then
                level = 30
                GameTime.incrementCounter(n)
                GameTimeToday.updateCounter( GameTime.counterToday)
                local Game = jsonPS4status.runningappname
                if PS4Alert.text ~= Game then PS4Alert.updateAlertSensor(green, Game) end
            else -- jsonPS4status.status == "OK" then
                level = 20
                PS4Alert.updateAlertSensor(yellow, "No Game")
Below two shell scripts. Put these in ~/domoticz/scripts
The '&' is important. it makes the line run in a separate background process and Domoticz will not wait for it to finish.
#!/bin/sh
ps4-waker --skip-login &
Don't forget to do a "sudo chmod +x startps4.sh"
#!/bin/bash
ps4-waker standby &
Don't forget to do a "sudo chmod +x stopps4.sh"
Schermafbeelding 2019-10-24 om 00.28.01.png (309.59 KiB) Viewed 4121 times
Schermafbeelding 2019-10-24 om 00.22.35.png (115.07 KiB) Viewed 4121 times
Schermafbeelding 2019-10-24 om 00.22.26.png (86.84 KiB) Viewed 4121 times
Re: PS4 Monitoring
Posted: Friday 13 March 2020 14:06
by Tiempie
seems to me that with the use of ps4-waker you don't need the Coolcam Plug?
Re: PS4 Monitoring
Posted: Friday 17 April 2020 1:02
by Larsoss
And how do you name it?
Re: PS4 Monitoring
Posted: Friday 21 August 2020 16:27
by rononline
I just installed domoticz, and i can't figure out how to use the lua script.
Can you help me in dummy steps? :-D
Re: PS4 Monitoring
Posted: Friday 21 August 2020 17:00
by rononline
I put the script in /home/pi/domoticz/scripts/lua/script_device_PS4.lua, and created a Dummy hardware called PS4, and then the virtual sensors:
PS4 Uptime Today, PS4 Uptime, PS4 Status and PS4 Selector Switch. But that is not working.
And in the logging i get:
2020-08-21 16:59:08.276 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_PS4.lua: /home/pi/domoticz/scripts/lua/script_device_PS4.lua:8: attempt to index a nil value (global 'domoticz')
2020-08-21 16:59:08.310 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_PS4.lua: /home/pi/domoticz/scripts/lua/script_device_PS4.lua:8: attempt to index a nil value (global 'domoticz')
2020-08-21 16:59:08.337 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_PS4.lua: /home/pi/domoticz/scripts/lua/script_device_PS4.lua:8: attempt to index a nil value (global 'domoticz')
2020-08-21 16:59:08.375 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_PS4.lua: /home/pi/domoticz/scripts/lua/script_device_PS4.lua:8: attempt to index a nil value (global 'domoticz')
2020-08-21 16:59:08.396 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_PS4.lua: /home/pi/domoticz/scripts/lua/script_device_PS4.lua:8: attempt to index a nil value (global 'domoticz')
Re: PS4 Monitoring
Posted: Friday 21 August 2020 17:49
by waaren
rononline wrote: Friday 21 August 2020 17:00 I put the script in /home/pi/domoticz/scripts/lua/script_device_PS4.lua, and created a Dummy hardware called PS4, and then the virtual sensors:
You saved it as a Lua script but should save it as a dzVents script.
Re: PS4 Monitoring
Posted: Sunday 15 November 2020 14:48
by pkessels
I configured domoticz with the script and so on, but now i receive every time the following error:
2020-11-15 14:41:18.111 Error: dzVents: Error: (3.0.16) PS4: ------ Finished script_PS4_Status.lua after >18 seconds. (using 0.570 seconds CPU time !)
2020-11-15 14:42:10.123 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-11-15 14:42:18.147 Error: dzVents: Error: (3.0.16) PS4: An error occurred when calling event handler script_PS4_Status
2020-11-15 14:42:18.147 Error: dzVents: Error: (3.0.16) PS4: ...i/domoticz/scripts/dzVents/scripts/script_PS4_Status.lua:40: attempt to index a nil value (global 'jsonPS4status')
Does anybody have a clue?
Re: PS4 Monitoring
Posted: Sunday 15 November 2020 16:42
by waaren
pkessels wrote: Sunday 15 November 2020 14:48 Does anybody have a clue?
There are two places in the script where it needs to wait for an OS call (that could take forever) to return control.
I will leave it to the OP to correct it but using io.popen without putting the OS command in the background or force it to return control within a reasonable time leaves room for improvement...
