Run script 10 sec after device changed
Posted: Wednesday 23 October 2019 21:03
by HFman
It seems that DZvents sometimes already trigger a script on device change BEFORE domoticz has already updated the value of the device.
In my case i run a script to see the gasflow, so in case when it misses the updated value i get a zero, and the next update a double value.
So i look for a way that i can let a script run 10 sec AFTER it is trigger on a device change e.g.:
devices = { 'Gas', after 10 sec }
Without having Domoticz stalled for 10 sec because it wait for the script....
Re: Run script 10 sec after device changed
Posted: Wednesday 23 October 2019 22:26
by elmortero
Have a look at the dzVents wiki.
Look for afterSec
Posted: Wednesday 23 October 2019 23:00
by BOverdevest
Look for afterSec
This will only work on a switch.
So, maybe use it a inbetween helper switch?
So use switchOn().AfterSec(10) to turn on a switch when the value you monitor changes
then use a 2nd event triggered by the helper switch?
[EDIT] see below, indeed a delay route via Uservariable is a cleaner solution vs adding another device
Posted: Wednesday 23 October 2019 23:06
by waaren
HFman wrote: Wednesday 23 October 2019 21:03
I never saw this. Can you show me the script and the domoticz log of an example and the version where you see this ? Maybe there is something else causing this.
You cannot code a delayed reaction to a device update in the on section. With a delayedURL function you can do this
[EDIT] or indeed using a helper uservariable of device like @BOverdevest suggests
-- Delayed Gas
local scriptVar = "delayedGas"
devices = { 'Gas' },
httpResponses = { scriptVar },
logging = {
level = domoticz.LOG_DEBUG,
marker = scriptVar
execute = function(dz, item)
local function delayedURL(delay, callback, logMessage)
callback = callback or scriptVar
logMessage = dz.utils.urlEncode(logMessage or scriptVar)
delay = delay or 60
local url= dz.settings['Domoticz url'] .. "/json.htm?type=command¶m=addlogmessage&message=" .. logMessage
dz.openURL({
url = url,
method = "GET",
callback = callback
}).afterSec(delay)
if item.isDevice then
delayedURL(10)
dz.log('The value of Gas: ' .. dz.devices('Gas').sValue )
Posted: Thursday 24 October 2019 20:14
by HFman
Yes.. this is the way to go.. I will try and check if it solves my flow issues (0 or double valvue)
