Run script 10 sec after device changed
HFman
Domoticz version: V4.1174
Post by HFman »
It seems that DZvents sometimes already trigger a script on device change BEFORE domoticz has already updated the value of the device.
In my case i run a script to see the gasflow, so in case when it misses the updated value i get a zero, and the next update a double value.
So i look for a way that i can let a script run 10 sec AFTER it is trigger on a device change e.g.:
devices = { 'Gas', after 10 sec }
Without having Domoticz stalled for 10 sec because it wait for the script....
Raspberry PI 3 - Opentherm Gateway + ESP8826 - EvoHome - ESPEasy CO2 + Fancontrol - RF-Link - zigbee2mqqt -
elmortero
Domoticz version: 3.9639
Re: Run script 10 sec after device changed
Post by elmortero »
Have a look at the dzVents wiki.
Look for afterSec
BOverdevest
Domoticz version: 4.11307
Post by BOverdevest »
Look for afterSec
This will only work on a switch.
So, maybe use it a inbetween helper switch?
So use switchOn().AfterSec(10) to turn on a switch when the value you monitor changes
then use a 2nd event triggered by the helper switch?
[EDIT] see below, indeed a delay route via Uservariable is a cleaner solution vs adding another device
Last edited by BOverdevest on Wednesday 23 October 2019 23:26, edited 1 time in total.
HUE, Tradfri, Zwave, RFXCOM, rooted TOON, PS4
HFman wrote: Wednesday 23 October 2019 21:03 It seems that DZvents sometimes already trigger a script on device change BEFORE domoticz has already updated the value of the device.
I never saw this. Can you show me the script and the domoticz log of an example and the version where you see this ? Maybe there is something else causing this.
You cannot code a delayed reaction to a device update in the on section. With a delayedURL function you can do this
[EDIT] or indeed using a helper uservariable of device like @BOverdevest suggests
-- Delayed Gas
local scriptVar = "delayedGas"
    on      =   {
                    devices      =      { 'Gas' },
                    httpResponses   =   { scriptVar },
    logging =   {
                    level     =   domoticz.LOG_DEBUG,
                    marker    =   scriptVar
    execute = function(dz, item)
        local function delayedURL(delay, callback, logMessage)
            callback = callback or scriptVar
            logMessage = dz.utils.urlEncode(logMessage or scriptVar)
            delay = delay or 60
            local  url= dz.settings['Domoticz url'] .. "/json.htm?type=command&param=addlogmessage&message=" .. logMessage
            dz.openURL({
                            url = url,
                            method = "GET",
                            callback = callback
                      }).afterSec(delay)
        if item.isDevice then
            delayedURL(10)
            dz.log('The value of Gas: ' .. dz.devices('Gas').sValue )
HFman
Post by HFman »
Yes.. this is the way to go.. I will try and check if it solves my flow issues (0 or double valvue)
