Domoticz Pi3B+ - SSD drive, which OS?
Posted: Tuesday 15 October 2019 23:19
by scannie
I want to install an OS on the PI3B+ with x850 board and SSD.
Which version can be installed and is compatible with Domoticz?
Noobs doesn't startup after copying to an SSD.
Who can me advice?
Re: Domoticz Pi3B+ - SSD drive, which OS?
Posted: Wednesday 16 October 2019 0:49
by HansieNL
Raspbian is the official operating system for all models of the Raspberry Pi.
The lite version is ok to run Domoticz. You can install additional software later if you need it.
Don’t forget to create a ssh file in the boot part, otherwise it’s not possible to connect via ssh.
Posted: Wednesday 16 October 2019 3:39
by ben53252642
Its possible the SSD is using a USB interface to connect to the Pi in which case you should make sure the USB boot mode is programmed on the Pi, see:
https://www.raspberrypi.org/documentati ... des/msd.md
