Page 1 of 5
Python Plugin: WLED
Posted: Tuesday 08 October 2019 10:19
by frustreerMeneer
If anyone interested, I've made a Python plugin for WLED integration into Domoticz.
It's the first version and still quite beta, but it works for me. (It's my first Python project and first GitHUB repository).
Curious to know if it works for you.
My plugin: https://github.com/frustreermeneer/domoticz-wled-plugin
I'm planning to extend it, to make full use of all WLED features.
WLED allows you to control RGB LEDs with an ESP8266/ESP32 over WiFi.
WLED: https://github.com/Aircoookie/WLED
Screenshot WLED in Domoticz
Re: Python Plugin: WLED
Posted: Tuesday 15 October 2019 22:00
by Cluedo
Hello!
I tried this tonight, i got some problem i cant understand.
Domoticz add the different light, but i got error in Domoticz logs..
019-10-15 20:48:55.033 Status: (WLED) Entering work loop.
2019-10-15 20:48:55.033 Status: (WLED) Initialized version 0.0.1, author 'frustreermeneer'
2019-10-15 20:48:55.129 Status: MQTT: Subscribed
2019-10-15 20:48:55.577 Status: (WLED) Entering work loop.
2019-10-15 20:48:55.578 Status: (WLED) Initialized version 0.0.1, author 'frustreermeneer'
2019-10-15 20:48:55.617 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to 'http://192.168.1.98:80'
2019-10-15 20:48:55.617 Error: (WLED) Transport is not connected, write directive to 'getWLEDStatusConn' ignored.
2019-10-15 20:50:44.732 (WLED) Connect directive received, action initiation failed.
2019-10-15 20:50:44.732 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to 'http://192.168.1.98:80'
2019-10-15 20:50:44.732 Error: (WLED) Transport is not connected, write directive to 'getWLEDStatusConn' ignored.
2019-10-15 20:50:45.183 (WLED) Connect directive received, action initiation failed.
2019-10-15 20:50:45.183 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to 'http://192.168.1.98:80'
2019-10-15 20:50:45.184 Error: (WLED) Transport is not connected, write directive to 'getWLEDStatusConn' ignored.
It is ESP8266-12F flashed with WLED version 0.8.5
i can connect direcly with webpage. working great!
domoticz
Version: 4.10717
Build Hash: b38b49e5
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
You got any clue what is wrong?
Probably something i don't understand during installation....
thanks in advance
//Cluedo
Posted: Tuesday 15 October 2019 22:15
by frustreerMeneer
I think you entered the IP address the wrong way.
Try filling out only 192.168.1.98
It should look like something like this:
Posted: Wednesday 16 October 2019 15:30
by frustreerMeneer
Update: changes made in WLED app or WLED web interface or now also reflected in Domoticz.
Posted: Wednesday 16 October 2019 19:53
by Cluedo
frustreerMeneer wrote: Tuesday 15 October 2019 22:15 I think you entered the IP address the wrong way.
Hello!
Of course i did wrong :)
I put http://192.168.1.98/ should be 192.168.1.98
Its working great know, thanks for your help!
First ledstrip i got to work with Domoticz !
Realy impressive work you have done!
Thanks again !
//Cluedo
Posted: Friday 25 October 2019 16:19
by vwtune
Lovely project!
I'm getting the follwing error after installing and restart domoticz and add the WLED hardware:
2019-10-25 16:16:07.126 Error: (WLED) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/wled/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload:/usr/local/lib/python3.4/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.4/dist-packages:/usr/lib/dist-python'.
2019-10-25 16:16:07.126 Error: (WLED) Module Import failed, exception: 'ImportError'
2019-10-25 16:16:07.127 Error: (WLED) Module Import failed: ' Name: requests'
2019-10-25 16:16:07.127 Error: (WLED) Error Line details not available.
2019-10-25 16:17:12.289 Error: WLED hardware (22) thread seems to have ended unexpectedly
2019-10-25 16:17:26.295 Error: WLED hardware (22) thread seems to have ended unexpectedly
How can i fix this?
Posted: Friday 25 October 2019 16:25
by frustreerMeneer
It seems to miss the requests module.
Maybe you can try to install it?
sudo apt-get install python-requests
Let me know if that works.
Posted: Friday 25 October 2019 16:34
by vwtune
same problem after i did sudo apt-get install python-requests
:cry:
Posted: Friday 25 October 2019 21:12
by vwtune
Do you have an other solution maybe? I really want to use your plugin :-)
Posted: Thursday 14 November 2019 19:51
by JohnnySK
vwtune wrote: Friday 25 October 2019 21:12 Do you have an other solution maybe? I really want to use your plugin :-)
Try to install correct version.
Your domoticz use propably python v 3.5
So you need to install package python3-requests
Posted: Thursday 14 November 2019 21:04
by snellejellep
i made a video installing it, maby it helps some people: https://www.youtube.com/watch?v=umVpBED7hpo
Posted: Thursday 14 November 2019 21:43
by frustreerMeneer
snellejellep wrote: Thursday 14 November 2019 21:04 i made a video installing it, maby it helps some people: https://www.youtube.com/watch?v=umVpBED7hpo
Cool video!
Glad you like my plugin. :D
Posted: Monday 25 November 2019 23:11
by Ankan
I try to control my WLED with a Nexa 433 Mhz wall switch. I made a Blocky event handler that turn on WLED - Color & Brightness when I press ON and tour off same WLED when I press OFF on my wall switch.
This works but I get this error:
2019-11-25 22:52:28.240 Error: (CDevice_update) WLED - Color & Brightness: Failed to parse parameters: 'nValue', 'sValue', 'Image', 'SignalLevel', 'BatteryLevel', 'Options', 'TimedOut', 'Name', 'TypeName', 'Type', 'Subtype', 'Switchtype', 'Used', 'Description', 'Color' or 'SuppressTriggers' expected.
2019-11-25 22:52:28.240 Error: (WLED) 'CDevice_update' failed 'TypeError':'argument 15 must be str, not dict'.
When I try to dim the device by use the blocky set dim % it doesn't work at all. Maybe I'am using wrong device. I havent used RGB lights before with Domoticz.
I think your plugin is a great idea. It only need some fixes.
My plan is to use it as a wake up light in the bedroom and use a wall switch to turn it on and off manualy. I know Aircoookie is working on a sunset effect, but else it schouldn't be that hard to implement the logic in Domoticz. But first, I need to be able to control my WLED device with Blocky.
Keep up the good work!
Posted: Tuesday 26 November 2019 23:19
by Ankan
By the way, I'am running Domoticz 4.10717
Posted: Tuesday 26 November 2019 23:36
by frustreerMeneer
You are using the right device.
I've only tried a script with Dzvents.
I'll try with blockly.
Can you post what your script looks like?
Posted: Wednesday 27 November 2019 0:04
by Ankan
My blocky script is very simple and it looks like this..
If Button = On
	Set WLED = On
Else if Button = Off
	Set WLED = Off
From time to time I get two other errors also
No transport, write directive to 'getWLEDStatusConn' ignored.
The dim problem where a limitations in blocky. You can't check dim level in blocky so I have to do it in Python or something else. The idea is to make the wall switch smart. If you press on it toggle dim level if the strip is already on. Off just switch off the strip.
Posted: Wednesday 27 November 2019 15:09
by pablo79
I would like to thank you for the script.
At the beginning I also had errors, but I installed:
sudo apt-get install python3-requests
and now everything works great.
Thanks so much
Posted: Wednesday 27 November 2019 16:35
by frustreerMeneer
Ankan wrote: Wednesday 27 November 2019 0:04 My blocky script is very simple and it looks like this..
If Button = On
	Set WLED = On
	Set WLED = Off
I will try to replicate your script to see if i get the same error and hopefully i can fix it then.
Ankan wrote: Wednesday 27 November 2019 0:04 From time to time I get two other errors also
This indicates that Domoticz could not reach your WLED installation.
by frustreerMeneer
pablo79 wrote: Wednesday 27 November 2019 15:09 I would like to thank you for the script.
Thanks so much
Glad you like it ;)
Posted: Wednesday 27 November 2019 20:50
by frustreerMeneer
frustreerMeneer wrote: Wednesday 27 November 2019 16:35 I will try to replicate your script to see if i get the same error and hopefully i can fix it then.
I made the following script in blockly and it works. Maybe it's because you used ON/OFF in stead of Set Level?
WLED Blockly Example
