MySensor, controlling valve and external contact from node
Posted: Monday 07 October 2019 21:23
by dzjr
Hello everybody
I made a node to control a water valve, the valve has its own status contact which I use as status signaling in the controller (Domoticz) of the valve,
The contact uses the same child ID as the control of the valve, in MYScontroller I see that this works well, I send the valve open, if the valve is open the status will also be set to 1, so exactly as I want it .
Only within Domoticz does the status of the control change immediately when the button is pressed, and when the valve is open I see the status getting a trigger again, so the berict will certainly come through.
In the Domoticz hardware settings I have already disabled ACT from this child ID.
Does anyone know how I can adjust this so that the status does not change until the valve has actually changed position?
thank you in advance
dzjr
