Hello everybody
I made a node to control a water valve, the valve has its own status contact which I use as status signaling in the controller (Domoticz) of the valve,
The contact uses the same child ID as the control of the valve, in MYScontroller I see that this works well, I send the valve open, if the valve is open the status will also be set to 1, so exactly as I want it .
Only within Domoticz does the status of the control change immediately when the button is pressed, and when the valve is open I see the status getting a trigger again, so the berict will certainly come through.
In the Domoticz hardware settings I have already disabled ACT from this child ID.
Does anyone know how I can adjust this so that the status does not change until the valve has actually changed position?
thank you in advance
dzjr
MySensor, controlling valve and external contact from node
dzjr
- Domoticz version: 4.100xx
NUC Proxmox VM Stable & Raspberry Pi-3 Domoticz Beta
Tradfri Pluging by Moroen, Home made MySensors, Luftdaten, Home & Garden automatisation.
APC Back-UPS XS 700U, Modbus RTU & Janitza UMG103, RF-Link
Sonos plugins
Sonos plugins
