Execution scripts problem
Posted: Monday 07 October 2019 20:50
by czasas
Hello could you tell me what Im doing wrong? When I rotate cube in right there should be executed specific scripts, the same for left. Scripts is recognising left and right (printing proper value, but scripts are not executed). Could you help ?
on ={devices ={'Cube_kat'}},
execute = function(dz,item)
local kat = item.nValue
print(kat)
if kat > 0 then
print("Zwiekszam glosnosc")
os.execute ('sh /home/pi/domoticz/scripts/radio/volume_plus.sh')
if kat < 0 then
print("Zmniejszam glosnosc")
os.execute ('sh /home/pi/domoticz/scripts/radio/volume_minus.sh')
Re: Execution scripts problem
Posted: Monday 07 October 2019 23:04
by waaren
czasas wrote: Monday 07 October 2019 20:50
Hard to tell but cannot see anything wrong. Maybe something with domoticz user not having enough authorisation to access the sh script?
I use something similar
return
on =
devices =
'cubeSwitch'
local cubeState = item.levelName
dz.log('cube state: ' .. cubeState,dz.LOG_FORCE)
os.execute ('/bashdir/argtest.sh ' .. cubeState)
Log
2019-10-07 22:57:03.093 Status: dzVents: Info: ------ Start external script: Xcube.lua: Device: "cubeSwitch (Xiaomi)", Index: 1739
2019-10-07 22:57:03.093 Status: dzVents: !Info: cube state: clock_wise
2019-10-07 22:57:03.108 Status: dzVents: Info: ------ Finished Xcube.lua
bash script
cat /bashdir/argtest.sh
#!/bin/bash
echo $(date) $@ >> /usr/local/domotica/data/test$$
created file
cat /usr/local/domotica/data/test14324
Mon 07 Oct 2019 10:57:03 PM CEST clock_wise
- devices.png (47.13 KiB) Viewed 382 times
- cubeSwitch.png (16.65 KiB) Viewed 382 times
Posted: Monday 07 October 2019 23:30
by czasas
Hmmm , I have also 'shake' for one script, the first one below and its working . My permission looks like here:
drwxrwxrwx 2 pi pi 4096 Oct 7 23:24 .
drwxr-xr-x 13 pi pi 4096 Oct 7 18:21 ..
-rwxrwxrwx 1 pi pi 74 Oct 7 18:21 radiozet.sh
-rwxrwxrwx 1 root root 21 Oct 7 18:30 stop.sh
-rwxrwxrwx 1 root root 38 Oct 7 23:24 volume_minus.sh
-rwxrwxrwx 1 root root 38 Oct 7 23:21 volume_plus.sh
Posted: Tuesday 08 October 2019 1:01
by waaren
czasas wrote: Monday 07 October 2019 23:30
Do you have to use sh as shell for these scripts ?
You might get a better indication in the log on what happens if you use this.
return
on =
devices =
'Cube_kat'
dz.log("nValue of " .. item.name .. ': ' .. item.nValue,dz.LOG_FORCE)
local function osExecute(cmd)
local fileHandle = assert(io.popen(cmd, 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
dz.log("commandOutput: " .. commandOutput,dz.LOG_FORCE)
dz.log("returncode : " .. returnTable[3],dz.LOG_FORCE)
if kat > 0 then
dz.log("Zwiekszam glosnosc",dz.LOG_FORCE)
osExecute ('sh /home/pi/domoticz/scripts/radio/volume_plus.sh')
elseif kat < 0 then
dz.log("Zmniejszam glosnosc",dz.LOG_FORCE)
osExecute ('sh /home/pi/domoticz/scripts/radio/volume_minus.sh')
dz.log("Nic nie robie",dz.LOG_FORCE)
