Log what's inside a variable  [Solved]
Solderbro
Domoticz version: 2020.1
Post by Solderbro »
This normally should be simple, for debugging i like to see what's inside a variable.
Here the variable "Heizmodus" in domoticz is filled with "Heizen" from another script by outer temp, while the if statement NEVER occurs true an id never get the loglines at the end.
                local heizpause = domoticz.variables("Heizmodus").state
                local t = domoticz.time
                local spirit = domoticz.devices('Stube HZG Thermostat')
                local spirith = domoticz.devices('Stube HZG Heizpunkt')
                local spirite = domoticz.devices('Stube HZG Ecopunkt')
                if heizpause == 'Heizen' then
                    print('Modus Stube setzen')
                    domoticz.log('Hey! I am on!')
So the simple question, so the next user get a result from google: How to print a variable into the log?
Solderbro
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
boum
Domoticz version: 4.10717
Re: Log what's inside a variable
Post by boum »
To print a variable, just use domoticz.log(tostring(variable)) or you can concatenate using the .. operator the value to have a more meaningful output:
domoticz.log('Hey! my value is ' .. variable .. '!')
In you case, you take the wrong element of the user variable object to get the value. You should use:
local heizpause = domoticz.variables("Heizmodus").value
See https://www.domoticz.com/wiki/DzVents:_ ... riables.29
Solderbro
Re: Log what's inside a variable  [Solved]
Post by Solderbro »
Yes that's it, now it is clean at hand why the heating scripts failed. Has become cold here, only 4° at night and 10°C at day.
Thanks, solved and can be closed:-)
Solderbro
