I am using the EUROtronic EUR_SPIRITZ Wall Radiator Thermostat+ for my heating and zone temperatures.
This type has the possibility to use an external temperature sensor reading rather than the internal sensor. To use this option you have to set parameter 8. Measured Temperature Offset: to 128. I have done this but I cannot find where to access or update the external sensor variable.
Does anyone has experience with this?
EUROtronic EUR_SPIRITZ external temperature
wouterlet
Re: EUROtronic EUR_SPIRITZ external temperature
You have to make an association with the temp sensor. It's done in hardware-zwavedeice-groups and networks.
