Dimmer zwave zigbee no parameters (EcoDim Z-wave / Zigbee dimmers)
klaaspiet
Post by klaaspiet »
Hey,
i got a ecodim dimmer with zigbee and z wave protocol is it possible to add this to domoticz so i can use it.
i could pair the zwave and control it in domoticz but i can't change the parameters.
is it possible to add this device to domoticz.
link to the part
https://www.ecodim.nl/eco-dim07-zigbee- ... immer.html
greats Klaas
Last edited by klaaspiet on Tuesday 24 September 2019 11:39, edited 1 time in total.
klaaspiet
Re: Dimmer zwave zigbee no parameters
Post by klaaspiet »
i found on github the app for homey is there someone u can write this for domoticz.
Homey app for EcoDim Z-wave / Zigbee dimmers on github
https://github.com/EcoDimBV/nl.EcoDim
Nieka001
Re: Dimmer zwave zigbee no parameters (EcoDim Z-wave / Zigbee dimmers)
Post by Nieka001 »
Got the same problem with the new Ecodim-07 dimmer.
Can't control the dimmer with domoticz at all and no parameters visible.
How to solve this?
klaaspiet
Post by klaaspiet »
controlling is going fine only no parameters.
i am looking for a how to to add this dimmer into the open z-wave database.
this it the output in domoitcz. is there some one who wil help me getting this in a xml for the open z-wave.
herbod
Post by herbod »
Hello!
Has anyone got this dimmer working? It worked for a few minutes and after it keeps disconnecting.
Excluding / including does not make a differnce.
I use a Raspberry, a Synology user has it working with out problems....
gjwater
Post by gjwater »
I got the same issue here with the ECO_DIM.07 and AEOTEC Z-Wave USB stick. After 10 minutes or so the connection is lost and cannot be re-established. Did the previous writers send the dimmer back to the vendor? Is it working in Zigbee mode?
gjwater
Post by gjwater »
I got it running now for 2 days. I moved it closer to the USB z-wave hub and I did not change the "name" like I did the first time and left it to "unknown".
