Yeelights with selector Script not working  [Solved]
savage007
Post by savage007 »
Hi, my script for controlling several yeelights through a selector is not working correct, can anybody help me?
I found this script on some russian forum ( https://translate.googleusercontent.com ... ry58660929 ) and adapted it with my own yeelights, but i dont realy know what i am doing :lol:
When i select off it only shuts down the firs light in " local Light = domoticz.devices('Yeelight bank links', 'Yeelight tv links', 'Yeelight lantaarn', 'Yeelight bank rechts', 'Yeelight tv rechts')"
        devices = {
            'Lights-Selector',
            'Dimmer',
            'WhiteTemp',
            'Hue',
            'Sat',
            'Bri',
            'Duration'
    logging = {
        level = domoticz.LOG_DEBUG
         local Light  = domoticz.devices('Yeelight bank links', 'Yeelight tv links', 'Yeelight lantaarn', 'Yeelight bank rechts', 'Yeelight tv rechts') -- Yeelight Bulb
         local PORT   = '55443'
         local IPs    = {'192.168.179.88', '192.168.179.19','192.168.179.178','192.168.179.104','192.168.179.48'} -- group --> {'192.168.0.1', '192.168.0.2', '192.168.0.3'} -- group --> {'192.168.0.1', '192.168.0.2', '192.168.0.3'}
         local switch = domoticz.devices
         local sceneWhite = {}
          sceneWhite[#sceneWhite+1] = {'Energize', 99, 90}
          sceneWhite[#sceneWhite+1] = {'Concentrate', 77, 80}
          sceneWhite[#sceneWhite+1] = {'Reading', 44, 70}
          sceneWhite[#sceneWhite+1] = {'Normal', 37, 60}
          sceneWhite[#sceneWhite+1] = {'Movie',  100, 30}
          sceneWhite[#sceneWhite+1] = {'Relax', 16, 10}
          sceneWhite[#sceneWhite+1] = {'Romantic', 12, 10}
         local sceneRGB = {}
          sceneRGB[#sceneRGB+1] = {'Warm', 4, 60, 42}
          sceneRGB[#sceneRGB+1] = {'Warm-Dimmed', 99, 65, 19}
          sceneRGB[#sceneRGB+1] = {'NightBlue',  76, 65, 19}
         debug =  true
 function round(num, numDecimalPlaces)
    local mult = 10^(numDecimalPlaces or 0)
    return math.floor(num * mult + 0.5) / mult
 function YeelightOff()
    Light.switchOff().checkFirst()
    switch('Dimmer').switchOff().checkFirst().silent()
    switch('WhiteTemp').switchOff().checkFirst().silent()
    switch('Hue').switchOff().checkFirst().silent()
    switch('Sat').switchOff().checkFirst().silent()
    switch('Bri').switchOff().checkFirst().silent()
    switch('Lights-Selector').switchOff().checkFirst().silent()
 function YeelightTemperature(WhiteValue, DimValue, DurationYeeValue)
    Light.switchOn().checkFirst()
    for n, IP in pairs(IPs) do
       runcommandYeelight = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\",\"params\":[\"ct\", " .. WhiteValue .. "," .. DimValue .. "]}\\r\\n' | nc -w1 " ..IP.." " ..PORT..""
          if debug then print(runcommandYeelight) end
       os.execute(runcommandYeelight)
    switch('Dimmer').switchOn().checkFirst().silent()
    switch('WhiteTemp').switchOn().checkFirst().silent()
 function YeeHue(HueValue, SatValue, BriValue, DurationYeeValue)
       runcommandYeelight = "sudo echo -ne '{\"id\":"..n..", \"method\":\"set_hsv\", \"params\":[" .. HueValue .. ", " .. SatValue .. ", \"smooth\", "..DurationYeeValue.."]}\\r\\n' | nc -w1 " ..IP.." " ..PORT..""
       runcommandYeelight = "sudo echo -ne '{\"id\":"..n..", \"method\":\"set_bright\", \"params\":[" .. BriValue ..  ", \"smooth\", "..DurationYeeValue.."]}\\r\\n' | nc -w1 " ..IP.." " ..PORT..""
    switch('Hue').switchOn().checkFirst().silent()
    switch('Sat').switchOn().checkFirst().silent()
    switch('Bri').switchOn().checkFirst().silent()
        DimValue      = switch('Dimmer').level
        TempValue     = switch('WhiteTemp').level
        WhiteValue    = ((TempValue - 1) * 48) + 1700
        HueValue      = round(switch('Hue').level * 3.59),0
        SatValue      = switch('Sat').level
        BriValue      = switch('Bri').level
        DurationValue = switch('Duration').level
           if DimValue      == nil then DimValue = 0 end
           if TempValue     == nil then TempValue = 0 end
           if HueValue      == nil then HueValue = 0 end
           if SatValue      == nil then SatValue = 0 end
           if BriValue      == nil then BriValue = 0 end
           if DurationValue == nil then DurationValue = 0 end
           if debug then print("Temp = " ..TempValue.." Dim = "..DimValue.." Bri = "..BriValue.." Sat = "..SatValue.." Hue = "..HueValue.." Duration = "..DurationValue) end
           if DurationValue == 0 or DurationValue == nil then
              DurationYeeValue = 400
              DurationYeeValue = DurationValue * 1000
           if ((device.name == 'Dimmer' or device.name == 'WhiteTemp') and device.state ~= 'Off') then
           if ((device.name == 'Hue' or device.name == 'Sat' or device.name == 'Bri') and device.state ~= 'Off') then
           if ((device.name == 'Dimmer' or device.name == 'WhiteTemp' or device.name == 'Hue' or device.name == 'Sat' or device.name == 'Bri') and device.state == 'Off') then
                YeelightOff()
           if (device.name == 'Lights-Selector') then
                  if (device.levelName == 'Off') then
                      YeelightOff()
                  for i in pairs(sceneWhite) do
                     if (device.levelName == sceneWhite[i][1] ) then
                         switch('WhiteTemp').dimTo(sceneWhite[i][2])
                         switch('Dimmer').dimTo(sceneWhite[i][3])
                  for i in pairs(sceneRGB) do
                     if (device.levelName == sceneRGB[i][1] ) then
                         switch('Hue').dimTo(sceneRGB[i][2])
                         switch('Sat').dimTo(sceneRGB[i][3])
                         switch('Bri').dimTo(sceneRGB[i][4])
This is the debug log
2019-09-17 11:53:47.156 (Dummy) Light/Switch (Lights-Selector)
2019-09-17 11:53:47.641 (Yeelight) Color Switch (Yeelight bank links)
2019-09-17 11:53:47.653 (Dummy) Light/Switch (Dimmer)
2019-09-17 11:53:47.663 (Dummy) Light/Switch (WhiteTemp)
2019-09-17 11:53:47.155 Status: User: Admin initiated a switch command (108/Lights-Selector/Set Level)
2019-09-17 11:53:47.179 Status: dzVents: Info: Handling events for: "Lights-Selector", value: "Off"
2019-09-17 11:53:47.179 Status: dzVents: Info: ------ Start internal script: Yeelight: Device: "Lights-Selector (Dummy)", Index: 108
2019-09-17 11:53:47.179 Status: dzVents: Debug: Processing device-adapter for Yeelight bank links: RGB(W) device adapter
2019-09-17 11:53:47.179 Status: dzVents: Debug: Processing device-adapter for Yeelight bank links: Switch device adapter
2019-09-17 11:53:47.179 Status: dzVents: Debug: Processing device-adapter for Dimmer: Switch device adapter
2019-09-17 11:53:47.180 Status: dzVents: Debug: Processing device-adapter for WhiteTemp: Switch device adapter
2019-09-17 11:53:47.180 Status: dzVents: Debug: Processing device-adapter for Hue: Switch device adapter
2019-09-17 11:53:47.180 Status: dzVents: Debug: Processing device-adapter for Sat: Switch device adapter
2019-09-17 11:53:47.180 Status: dzVents: Debug: Processing device-adapter for Bri: Switch device adapter
2019-09-17 11:53:47.180 Status: dzVents: Debug: Processing device-adapter for Duration: Switch device adapter
2019-09-17 11:53:47.180 Status: dzVents: Temp = 12 Dim = 10 Bri = 0 Sat = 0 Hue = 0 Duration = 0
2019-09-17 11:53:47.180 Status: dzVents: Debug: Constructed timed-command: Off
2019-09-17 11:53:47.180 Status: dzVents: Debug: Constructed timed-command: Off NOTRIGGER
2019-09-17 11:53:47.180 Status: dzVents: Info: ------ Finished Yeelight
Last edited by savage007 on Tuesday 17 September 2019 12:34, edited 3 times in total.
Re: Yeelights with selector Script not working  [Solved]
savage007 wrote: Tuesday 17 September 2019 9:26 Hi, my script for controlling several yeelights through a selector is not working, can anybody help me?
I found this script on some russian forum and adapted it with my own yeelights.
Kind of hard to understand from your problem description
is not working :)
and from the log (where everything seems to work) what the issue(s) is / are.
I guess your main problem is the use of
This will not work as you might expect in dzVents when used in an action like Light.switchOn(). Because domoticz.devices is in fact a function with 1 parameter it will ignore the other 'parameters' and only act on the first one; being 'Yeelight bank links'
I modified the script to overcome this. I only checked syntax and did not test functionality so if something is not working as expected then please describe it in more detail and add some debug lines in the area where your issue occur.
        devices = {
            'Lights-Selector',
            'Dimmer',
            'WhiteTemp',
            'Hue',
            'Sat',
            'Bri',
            'Duration'
    logging = {
        local myLights  = { 'Yeelight bank links', 'Yeelight tv links', 'Yeelight lantaarn', 'Yeelight bank rechts', 'Yeelight tv rechts' }  -- Yeelight Bulb
         local sceneRGB = {}
         debug =  true
		local function switchAll(deviceNames, action)
			if action == 'Off' then
				for _, name in ipairs(deviceNames) do
					switch(name).switchOff().checkFirst()
					switch(name).switchOn().checkFirst()
			switchAll(myLights, 'Off' )
    switchAll(myLights, 'On' )
        HueValue      = domoticz.utils.round((switch('Hue').level * 3.59),0)
                YeelightOff()
                      YeelightOff()
savage007
Post by savage007 »
Yes, thank you, you are right on the spot about just switching the first item! :)
I will try your script and give you some feedback! :D
savage007
Post by savage007 »
your adaptations to the script are working! :)
I also figured out i had defined the wrong types of dimmers for the 'Dimmer','WhiteTemp','Hue','Sat','Bri','Duration' switches, now that i corrected those and added your script its all working.
For future reference : from the Yeelight/Domoticz wiki : "First You have to add a dummy selector switch, and set it as a dimmer on switch page ", this goes for the 'Dimmer','WhiteTemp','Hue','Sat','Bri','Duration' switches
Many Thanks!!!!!! ;)
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
