ECO-DEVICES
Posted: Tuesday 17 September 2019 8:37
by laco
Re: ECO-DEVICES
Posted: Tuesday 17 September 2019 9:32
by emme
uh... how dows it works? is that a sort of P1 ?
if so, you have to change the waterflow to a counter
Re: ECO-DEVICES
Posted: Tuesday 17 September 2019 10:37
by laco
I don't know where to change it.
The hardware selection is directly in domoticz.
Everything is set correctly.
It should show right Wh.
Picture from ECO-DEVICE:
Picture from Domoticz Devices:
Picture from Domoticz Hardware
Re: ECO-DEVICES
Posted: Tuesday 24 March 2020 13:58
by Destyny
I have the same problem.
l/min instead of kW/h
Re: ECO-DEVICES
Posted: Sunday 29 March 2020 16:42
by laco
Where is the file located in domoticz ECO-DEVICES hardware so I can do it manually?
Or where in domoticz I can modify the existing equipment and change the liter to Wh?
I was looking for it but I can't find it.
Re: ECO-DEVICES
Posted: Thursday 15 April 2021 21:45
by dyter
I have same problem !
I think you must modify sql database for this
Re: ECO-DEVICES
Posted: Thursday 15 April 2021 22:22
The code of this device is in the main source code
https://github.com/domoticz/domoticz/bl ... evices.cpp
It seems untouched functionally since 2017, only later some general code changes/fixes. The latest line shows a SendWaterflowSensor command that seems to be in the source code since the beginning.
So you can change this for new users. Someone needs to change the source code. There could be more files related to this hardware, see also
https://www.domoticz.com/wiki/Developin ... are_plugin
Re: ECO-DEVICES
Posted: Tuesday 07 September 2021 9:37
by laco
Nothing changed in this?
