ECO-DEVICES
laco
Domoticz version: 2021.1
ECO-DEVICES
Post by laco »
I bought an ECO-DEVICES device and connected it to a three-phase energy meter.
Everything works fine, only the flow rate in liters per minute is displayed.
Where can I change it?
emme
Domoticz version: latest
Re: ECO-DEVICES
Post by emme »
uh... how dows it works? is that a sort of P1 ?
if so, you have to change the waterflow to a counter
"We always done this way"
laco
Re: ECO-DEVICES
Post by laco »
I don't know where to change it.
The hardware selection is directly in domoticz.
Everything is set correctly.
It should show right Wh.
Picture from ECO-DEVICE:
Picture from Domoticz Devices:
Picture from Domoticz Hardware
Destyny
Re: ECO-DEVICES
Post by Destyny »
I have the same problem.
l/min instead of kW/h
laco
Re: ECO-DEVICES
Post by laco »
Where is the file located in domoticz ECO-DEVICES hardware so I can do it manually?
Or where in domoticz I can modify the existing equipment and change the liter to Wh?
I was looking for it but I can't find it.
dyter
Domoticz version: 8841
Re: ECO-DEVICES
Post by dyter »
I have same problem !
I think you must modify sql database for this :roll:
Domoticz v2024.1 on Synology Docker host, RFLink, ESPEasy wemos D1, Ecodevices, relays x8, dahua doorbell, reolink cameras ....
Re: ECO-DEVICES
The code of this device is in the main source code https://github.com/domoticz/domoticz/bl ... evices.cpp
It seems untouched functionally since 2017, only later some general code changes/fixes. The latest line shows a SendWaterflowSensor command that seems to be in the source code since the beginning.
So you can change this for new users. Someone needs to change the source code. There could be more files related to this hardware, see also https://www.domoticz.com/wiki/Developin ... are_plugin
laco
Re: ECO-DEVICES
Post by laco »
Nothing changed in this?
