Denkovi 8 relays module outputs not switching
Posted: Sunday 15 September 2019 9:52
by Hendrik
I have bought recently two 8 relaysboards with temp measerments:
http://denkovi.com/snmp-eight-relay-boa ... ent-lm35dz
connect it to domoticz, all the switches, inputs and temp sensors are added.
but its not working complete, the inputs are working, the temprature sensors are also working well.
the outputs are not switchting, when i push the button in domoticz, he is given the fault:
2019-09-13 16:04:09.728 Status: User: Admin initiated a switch command (95/Digital IO 9 (P5.1)/On)
2019-09-13 16:04:09.849 Error:DAEnetIP2 8 Relay Module - LM35DZ : Error sending command to: 192.168.1.28
do i need to install some more software on my rpi or something?
hope somebody can help me with this
Re: Denkovi 8 relays module outputs not switching
Posted: Sunday 01 December 2019 23:20
by Barry1980
same problem here with DAEnetIP2 v2 and 8 relay module. After muliple requests sometimes switing on or off. But most of the time "Error sending switch command, check device/hardware !"
can't find the problem...who can help!
Posted: Tuesday 24 March 2020 12:10
by tomyc
I have same problem. Did you find solution? I use last version domoticz V2020.1 Thank you very much
Tomyc
Posted: Friday 23 October 2020 9:02
by denkoviaeltd
Hello guys,
We made recently update of Denkovi devices in domoticz and this should work fine with the last beta version.
