I have bought recently two 8 relaysboards with temp measerments:
http://denkovi.com/snmp-eight-relay-boa ... ent-lm35dz
connect it to domoticz, all the switches, inputs and temp sensors are added.
but its not working complete, the inputs are working, the temprature sensors are also working well.
the outputs are not switchting, when i push the button in domoticz, he is given the fault:
2019-09-13 16:04:09.728 Status: User: Admin initiated a switch command (95/Digital IO 9 (P5.1)/On)
2019-09-13 16:04:09.849 Error:DAEnetIP2 8 Relay Module - LM35DZ : Error sending command to: 192.168.1.28
do i need to install some more software on my rpi or something?
hope somebody can help me with this
Denkovi 8 relays module outputs not switching
Hendrik
CubieTruck with Domoticz
RfxTrx 433Mhz Usb, Rfx Sensor, Z-Wave
Slave Raspberry Pi with Domoticz, Piface, P1 usb
Barry1980
Re: Denkovi 8 relays module outputs not switching
same problem here with DAEnetIP2 v2 and 8 relay module. After muliple requests sometimes switing on or off. But most of the time "Error sending switch command, check device/hardware !"
can't find the problem...who can help!
tomyc
I have same problem. Did you find solution? I use last version domoticz V2020.1 Thank you very much
Tomyc
Tomyc
denkoviaeltd
Hello guys,
We made recently update of Denkovi devices in domoticz and this should work fine with the last beta version.
