Page 1 of 2
iframe no scrolling
Posted: Sunday 15 September 2019 9:40
by Gianni
I have created a mediaplayer that streams my music from my nas.
The only problem now is that the frame must be fixed.
I try html,js ,css but nothing disabled the scrollbar.
Can you help me with a code to disable the scrollbar.
Re: iframe no scrolling
Posted: Sunday 15 September 2019 13:41
by Gianni
i can fix it in the inspector like it should be
<iframe src="../player/music.htm" scrolling="no" style="width:100%;border:0px;height:586px;"></iframe>
but where do i need to put this in the code.
it's not in the html itself so this is beyond my scope
Posted: Sunday 15 September 2019 22:53
by Lokonli
Gianni wrote: Sunday 15 September 2019 13:41 i can fix it in the inspector like it should be
That indeed works. I'll add a parameter for the block definition:
frames.yourplayer {
	scrollbars: false,		// default: auto
	frameurl: '....'
Posted: Monday 16 September 2019 1:36
by Gianni
hey Lokonoli
Thx i was searching on scrolling and overflow .
If i got another problem how can i search for this?
is this jquery or angular or js,.....(its not html and css :-) )
How can i implement this parameter?
for now it's not working is still see the scrollbar.
frames.mediaplayer = {
	refreshiframe:1000000,
	height:600,
	frameurl:'../player/music.htm',
	width:12,
	scrollbars: false,
Posted: Monday 16 September 2019 9:36
by Lokonli
It's not implemented yet :)
Dashticz is mainly written in Javascript, making use of jquery.
The iframe scrolling setting needs to be implemented in the function loadFrame, starting line 928 in the file js/main.js (in the beta branch)
Posted: Monday 16 September 2019 17:40
by Gianni
thx i hard coded it for the moment :-)
Posted: Monday 16 September 2019 18:15
by Lokonli
Gianni wrote: Monday 16 September 2019 17:40 thx i hard coded it for the moment :-)
Can you test the latest beta?
Posted: Monday 16 September 2019 19:46
by Gianni
how do i update to the latest brance?
if i git pull then i get
gianni@domotic:/var/www/html/homecontrol $ git pull
Already up-to-date.
but if i check the version txt i get 3.0.3 and not 3.0.6
gianni@domotic:/var/www/html/homecontrol $ cat version.txt
"version": "3.0.3",
"branch": "beta",
"last_changes": "Fix for Spotify block; layout improvements",
"changelog" : {
            "3.0.2": "Add imageOn/Off, iconOn/Off and textOn/Off block parameters",
            "3.0.1": "Update install script",
            "3.0.0": "Dashticz V3"
Posted: Monday 16 September 2019 20:01
by HansieNL
You installed the beta from the old Dashticz_v3 address.
Dashticz has been moved to https://github.com/Dashticz/dashticz.
Backup your custom folders and delete the old Dashticz files. Then you can clone the new version git clone https://github.com/Dashticz/dashticz --branch beta and restore your backup.
Posted: Monday 16 September 2019 20:05
by Gianni
so i need to git clone instead of git pull first?
Posted: Monday 16 September 2019 20:11
by HansieNL
Gianni wrote: Monday 16 September 2019 20:05 so i need to git clone instead of git pull first?
You have to clone the new version first. Your pull refers to the old address. That's why there's no new version.
Posted: Monday 16 September 2019 20:14
by Gianni
thx hansie.
i downloaded the beta brance and ftp it to my pi :-)
@Lokonli
So default there are no scrollbars.
what are the parameters for the config js to test?
Posted: Monday 16 September 2019 22:25
by Lokonli
Gianni wrote: Monday 16 September 2019 20:14 thx hansie.
@Lokonli
By default the frame shows scrollbars if the content of the frame is bigger than then the size of frame.
Add the following to your block definition to show the frame without scrollbars:
frames.yourframe = {
  frameurl: '....',
  scrollbars: false
Posted: Monday 16 September 2019 22:57
by Gianni
by default no scrollbar even if the frame is smaller.
same setup but replace the main.js from the master version scrollbar ok
grts gianni
Posted: Tuesday 17 September 2019 8:52
by Lokonli
Gianni wrote: Monday 16 September 2019 22:57 by default no scrollbar even if the frame is smaller.
grts gianni
Indeed. Silly mistake :(
Should be fixed in latest beta.
Thanks for testing :)
Posted: Tuesday 17 September 2019 16:56
by Gianni
now it's working :-)
But i notice something else in the frame.
i dont know if it's your or my code but i think its the iframe self.
when you look at the pic you notice a dark bar next to the scrollbar.
this is actulie a div behind the frame.
when i look in the inspector i see ths.
<div data-id="frames.UNKNOWN" class="col-xs-12 hover transbg swiper-no-swiping imgblock imgblock77419" style="height:600px;padding:0px !important;">
<div class="col-xs-12 col-no-icon" style="padding:0px !important;">
<iframe src="../player/music.htm" style="width:100%;border:0px;height:586px;"></iframe></div></div>
when i remove this
then its gone and my frame is ok.
my config js
var frames = {}
	height:600,
	frameurl:"../player/music.htm",
	width:12,
	//scrollbars: false,
//sreen 2
columns[22] = {}
columns[22]['blocks'] = [frames.mediaplayer]
columns[22]['width'] = 12;
var screens = {}
screens[2] = {}
screens[2]['background'] = 'brushed_metal.jpg';
screens[2]['columns'] = [22]
Posted: Tuesday 17 September 2019 20:29
by Lokonli
Yes, the code can use some clean-up. Styling is not really consistent.
I've made some changes to the latest beta.
Posted: Tuesday 24 September 2019 14:30
by Vomera
Can i make the background of the frame to black?
I have a little small white space on the right side of the frame.
The width of the frame is not 10 (ander before the update it was 10 also). When i set it to 9 it cuts of the image/frame.
frames.buienradar = {
  frameurl:"https://gadgets.buienradar.nl/gadget/zoommap/?lat=50.82535&lng=5.72597&overname=2&zoom=8&naam=6228CN&size=2b&voor=0",
  height: 360,     //height of the block in pixels
  width: 10,
  scrollbars: false,
  refreshiframe:60000,
  forcerefresh: 2
Edit:
With some inspecting the code I could change some color (yellow for example):
.transbg[data-id='frames.UNKNOWN']
background-color: yellow !important;
Seems it is the iframe from that website it self, then i think you can not change it ?
edit again:
I solved to make an own html page and put the iframe in it and make the background black :)
edit again again :
I took the solution of Lokonli and works also, better then host your own file of an iframe
Posted: Tuesday 24 September 2019 18:17
by Lokonli
yes, you can :)
First add a key to the block definition to be able to identify the frame:
  width: 10,
  scrollbars: false,
  forcerefresh: 2,
  key: 'test'
Then add the following to custom.css to set the width of the iframe:
div[data-id='frames.test'] iframe {
    width: 325px !important
Posted: Wednesday 25 September 2019 9:38
by Vomera
Lokonli wrote: Tuesday 24 September 2019 18:17 yes, you can :)
  width: 10,
  scrollbars: false,
  forcerefresh: 2,
  key: 'test'
Thank this is a better solution !! :D
