speedtest not showing in utilitytab
GrimReaper
Domoticz version: 4.10717
Post by GrimReaper »
I have followed this guide: https://www.domoticz.com/forum/viewtopic.php?t=13814
As i dont have a username and password (yet ;) ) i have removed the username and password
#!/bin/bash
#setup
host='http://***.***.***.***:8080'
#idx for download, upload and ping
idxdl=82024
idxul=82025
idxpng=82026
idxbb=1406B
# speedtest server number
serverst=7214
# no need to edit
# speedtest-cli --simple --server $serverst > outst.txt
speedtest-cli --simple > speedtest.txt
download=$(cat speedtest.txt | sed -ne 's/^Download: \([0-9]*\.[0-9]*\).*/\1/p')
upload=$(cat speedtest.txt | sed -ne 's/^Upload: \([0-9]*\.[0-9]*\).*/\1/p')
png=$(cat speedtest.txt | sed -ne 's/^Ping: \([0-9]*\.[0-9]*\).*/\1/p')
# output if you run it manually
echo "Download = $download Mbps"
echo "Upload = $upload Mbps"
echo "Ping = $png ms"
# Updating download, upload and ping ..
wget -q --delete-after "http://$host/json.htm?type=command&param=udev ice&idx=$idxdl&svalue=$download" >/dev/null 2>&1
wget -q --delete-after "http://$host/json.htm?type=command&param=udevice&idx=$idxul&svalue=$upload" >/dev/null 2>&1
wget -q --delete-after "http://$host/json.htm?type=command&param=udevice&idx=$idxpng&svalue=$png" >/dev/null 2>&1
# Reset Broadband switch
wget -q --delete-after "http://$host/json.htm?type=command&param=udevice&idx=$idxbb&svalue=0" >/dev/null 2>&1
# Domoticz logging
wget -q --delete-after "http://$host/json.htm?type=command&param=addlogmessage&message=speedtest.net-logging" >/dev/null 2>&1
When i do a manual trigger or via a cronjob i get a error in my log:
2019-09-10 19:45:04.764 Error: Error executing script command (/home/pi/script/speedtest.sh). returned: 1024
When i check my script via ssh ./speedtest.sh i get a valid result ( Download = 27.65 Mbps, Upload = 3.57 Mbps,Ping = 31.95 ms). So the script itself is fine.
I dont have a clue what could be the issue any more. Anyone a idea?
