fotomann100
Posts: 16 Joined: Tuesday 27 August 2019 15:18
Domoticz version: 41017
Post
by fotomann100 » Sunday 08 September 2019 15:45
I try to write a script, that should send a Code via RFXcom over a specified time again and again. At the moment I solve this in dzvents with a simple for-loop (see below). It's working but it isn't very elegant. The mass of commands can not be processed at all.
It would be better to write a script that works in that way: It should send the code over 10 Seconds every 500 ms for example. I tryed to write this Code, but all previous attempts failed. Is somebody able to advice me?
devices = {
'TestMaster'
execute = function(domoticz, TestMaster)
domoticz.log('Programmablauf gestartet')
local TestSlave = domoticz.devices('TestSlave')
domoticz.log('Variable gesetzt. TestMaster-Status:')
domoticz.log(TestMaster.state)
for loop = 1, 750 ,1 do
if (TestMaster.state == 'On') then
TestSlave.switchOn()
domoticz.log('Abfrage erfolgt')
domoticz.log('else gelesen TestMaster Status:')
if (TestMaster.state == 'Off') then
TestSlave.switchOff()
domoticz.log(' 2. Abfrage erfolgt')
domoticz.log('Durchlauf beendet')
Devices in use:
several RFXtrx433XL
Sonoff Basic, Sonoff POW R2 / Tasmota
D1 mini / espeasy
switches and sensors from several china suppliers
Pollin wireless sockets
Renkforce smoke detectors
Posts: 6028 Joined: Tuesday 03 January 2017 14:18
Post
by waaren » Monday 09 September 2019 0:01
fotomann100 wrote: Sunday 08 September 2019 15:45
For these type of requirements the afterXXX() is a good method. I am not sure that the domoticz / RFXCom combination can deal with more then 1 command per second but the script below will send one every 500 milliseconds.
As always; please feel free to ask for clarification if something is not clear.
return
on = { devices = { 'TestMaster' }},
logging = { level = domoticz.LOG_DEBUG, marker = 'many commands'},
execute = function(dz, item)
local TestSlave = dz.devices('TestSlave')
dz.log('Variable gesetzt. TestMaster-Status: ' .. item.state ,dz.LOG_DEBUG)
for loop = 0, 20 do
if ( item.state == 'On' and TestSlave.switchOn().afterSec(0 + loop / 2 )) or TestSlave.switchOff().afterSec(0 + loop / 2 ) then
dz.log('Schedule switch command in ' .. ( loop * 50 ) .. ' mSec' ,dz.LOG_DEBUG)
Log when switching on
Spoiler: show Code: Select all
2019-09-08 23:52:58.883 Status: dzVents: Debug: many commands: Processing device-adapter for TestSlave: Switch device adapter
2019-09-08 23:52:58.884 Status: dzVents: Debug: many commands: Variable gesetzt. TestMaster-Status: On
2019-09-08 23:52:58.884 Status: dzVents: Debug: many commands: Constructed timed-command: On
2019-09-08 23:52:58.884 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 0 SECONDS
2019-09-08 23:52:58.885 Status: dzVents: Debug: many commands: Schedule switch command in 0 mSec
2019-09-08 23:52:58.885 Status: dzVents: Debug: many commands: Constructed timed-command: On
2019-09-08 23:52:58.885 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 0.5 SECONDS
2019-09-08 23:52:58.886 Status: dzVents: Debug: many commands: Schedule switch command in 50 mSec
2019-09-08 23:52:58.886 Status: dzVents: Debug: many commands: Constructed timed-command: On
2019-09-08 23:52:58.886 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 1 SECONDS
2019-09-08 23:52:58.886 Status: dzVents: Debug: many commands: Schedule switch command in 100 mSec
2019-09-08 23:52:58.887 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 1.5 SECONDS
2019-09-08 23:52:58.887 Status: dzVents: Debug: many commands: Schedule switch command in 150 mSec
2019-09-08 23:52:58.888 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 2 SECONDS
2019-09-08 23:52:58.888 Status: dzVents: Debug: many commands: Schedule switch command in 200 mSec
2019-09-08 23:52:58.888 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 2.5 SECONDS
2019-09-08 23:52:58.889 Status: dzVents: Debug: many commands: Schedule switch command in 250 mSec
2019-09-08 23:52:58.889 Status: dzVents: Debug: many commands: Constructed timed-command: On
2019-09-08 23:52:58.889 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 3 SECONDS
2019-09-08 23:52:58.889 Status: dzVents: Debug: many commands: Schedule switch command in 300 mSec
2019-09-08 23:52:58.890 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 3.5 SECONDS
2019-09-08 23:52:58.890 Status: dzVents: Debug: many commands: Schedule switch command in 350 mSec
2019-09-08 23:52:58.891 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 4 SECONDS
2019-09-08 23:52:58.891 Status: dzVents: Debug: many commands: Schedule switch command in 400 mSec
2019-09-08 23:52:58.891 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 4.5 SECONDS
2019-09-08 23:52:58.892 Status: dzVents: Debug: many commands: Schedule switch command in 450 mSec
2019-09-08 23:52:58.892 Status: dzVents: Debug: many commands: Constructed timed-command: On
2019-09-08 23:52:58.892 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 5 SECONDS
2019-09-08 23:52:58.892 Status: dzVents: Debug: many commands: Schedule switch command in 500 mSec
2019-09-08 23:52:58.893 Status: dzVents: Debug: many commands: Constructed timed-command: On
2019-09-08 23:52:58.893 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 5.5 SECONDS
2019-09-08 23:52:58.893 Status: dzVents: Debug: many commands: Schedule switch command in 550 mSec
2019-09-08 23:52:58.894 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 6 SECONDS
2019-09-08 23:52:58.894 Status: dzVents: Debug: many commands: Schedule switch command in 600 mSec
2019-09-08 23:52:58.894 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 6.5 SECONDS
2019-09-08 23:52:58.895 Status: dzVents: Debug: many commands: Schedule switch command in 650 mSec
2019-09-08 23:52:58.895 Status: dzVents: Debug: many commands: Constructed timed-command: On
2019-09-08 23:52:58.895 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 7 SECONDS
2019-09-08 23:52:58.895 Status: dzVents: Debug: many commands: Schedule switch command in 700 mSec
2019-09-08 23:52:58.896 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 7.5 SECONDS
2019-09-08 23:52:58.896 Status: dzVents: Debug: many commands: Schedule switch command in 750 mSec
2019-09-08 23:52:58.897 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 8 SECONDS
2019-09-08 23:52:58.897 Status: dzVents: Debug: many commands: Schedule switch command in 800 mSec
2019-09-08 23:52:58.897 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 8.5 SECONDS
2019-09-08 23:52:58.898 Status: dzVents: Debug: many commands: Schedule switch command in 850 mSec
2019-09-08 23:52:58.898 Status: dzVents: Debug: many commands: Constructed timed-command: On
2019-09-08 23:52:58.898 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 9 SECONDS
2019-09-08 23:52:58.898 Status: dzVents: Debug: many commands: Schedule switch command in 900 mSec
2019-09-08 23:52:58.899 Status: dzVents: Debug: many commands: Constructed timed-command: On
2019-09-08 23:52:58.899 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 9.5 SECONDS
2019-09-08 23:52:58.899 Status: dzVents: Debug: many commands: Schedule switch command in 950 mSec
2019-09-08 23:52:58.900 Status: dzVents: Debug: many commands: Constructed timed-command: On AFTER 10 SECONDS
2019-09-08 23:52:58.900 Status: dzVents: Debug: many commands: Schedule switch command in 1000 mSec
2019-09-08 23:52:58.903 Status: dzVents: Info: many commands: ------ Finished (dzVents) manyCommands
Log when switching off
2019-09-08 23:53:29.469 Status: dzVents: Info: many commands: ------ Start internal script: (dzVents) manyCommands: Device: "TestMaster (Virtual)", Index: 2382
2019-09-08 23:53:29.474 Status: dzVents: Debug: many commands: Processing device-adapter for TestSlave: Switch device adapter
2019-09-08 23:53:29.474 Status: dzVents: Debug: many commands: Variable gesetzt. TestMaster-Status: Off
2019-09-08 23:53:29.474 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.475 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 0 SECONDS
2019-09-08 23:53:29.475 Status: dzVents: Debug: many commands: Schedule switch command in 0 mSec
2019-09-08 23:53:29.475 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 0.5 SECONDS
2019-09-08 23:53:29.475 Status: dzVents: Debug: many commands: Schedule switch command in 50 mSec
2019-09-08 23:53:29.476 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.476 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 1 SECONDS
2019-09-08 23:53:29.476 Status: dzVents: Debug: many commands: Schedule switch command in 100 mSec
2019-09-08 23:53:29.476 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 1.5 SECONDS
2019-09-08 23:53:29.477 Status: dzVents: Debug: many commands: Schedule switch command in 150 mSec
2019-09-08 23:53:29.477 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.477 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 2 SECONDS
2019-09-08 23:53:29.477 Status: dzVents: Debug: many commands: Schedule switch command in 200 mSec
2019-09-08 23:53:29.478 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 2.5 SECONDS
2019-09-08 23:53:29.478 Status: dzVents: Debug: many commands: Schedule switch command in 250 mSec
2019-09-08 23:53:29.478 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 3 SECONDS
2019-09-08 23:53:29.478 Status: dzVents: Debug: many commands: Schedule switch command in 300 mSec
2019-09-08 23:53:29.479 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.479 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 3.5 SECONDS
2019-09-08 23:53:29.479 Status: dzVents: Debug: many commands: Schedule switch command in 350 mSec
2019-09-08 23:53:29.479 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 4 SECONDS
2019-09-08 23:53:29.480 Status: dzVents: Debug: many commands: Schedule switch command in 400 mSec
2019-09-08 23:53:29.480 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.480 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 4.5 SECONDS
2019-09-08 23:53:29.480 Status: dzVents: Debug: many commands: Schedule switch command in 450 mSec
2019-09-08 23:53:29.481 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.481 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 5 SECONDS
2019-09-08 23:53:29.481 Status: dzVents: Debug: many commands: Schedule switch command in 500 mSec
2019-09-08 23:53:29.482 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 5.5 SECONDS
2019-09-08 23:53:29.482 Status: dzVents: Debug: many commands: Schedule switch command in 550 mSec
2019-09-08 23:53:29.482 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 6 SECONDS
2019-09-08 23:53:29.482 Status: dzVents: Debug: many commands: Schedule switch command in 600 mSec
2019-09-08 23:53:29.483 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.483 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 6.5 SECONDS
2019-09-08 23:53:29.483 Status: dzVents: Debug: many commands: Schedule switch command in 650 mSec
2019-09-08 23:53:29.483 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 7 SECONDS
2019-09-08 23:53:29.484 Status: dzVents: Debug: many commands: Schedule switch command in 700 mSec
2019-09-08 23:53:29.484 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.484 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 7.5 SECONDS
2019-09-08 23:53:29.484 Status: dzVents: Debug: many commands: Schedule switch command in 750 mSec
2019-09-08 23:53:29.485 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 8 SECONDS
2019-09-08 23:53:29.485 Status: dzVents: Debug: many commands: Schedule switch command in 800 mSec
2019-09-08 23:53:29.485 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 8.5 SECONDS
2019-09-08 23:53:29.485 Status: dzVents: Debug: many commands: Schedule switch command in 850 mSec
2019-09-08 23:53:29.486 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.486 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 9 SECONDS
2019-09-08 23:53:29.486 Status: dzVents: Debug: many commands: Schedule switch command in 900 mSec
2019-09-08 23:53:29.486 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 9.5 SECONDS
2019-09-08 23:53:29.487 Status: dzVents: Debug: many commands: Schedule switch command in 950 mSec
2019-09-08 23:53:29.487 Status: dzVents: Debug: many commands: Constructed timed-command: Off
2019-09-08 23:53:29.487 Status: dzVents: Debug: many commands: Constructed timed-command: Off AFTER 10 SECONDS
2019-09-08 23:53:29.487 Status: dzVents: Debug: many commands: Schedule switch command in 1000 mSec
2019-09-08 23:53:29.490 Status: dzVents: Info: many commands: ------ Finished (dzVents) manyCommands
dzVents wiki
