In the settings page on the system tab at the bottom there are Active Menus switches, I know what these are for however if the custom tab switch is on I never see an additional tab at the top, is this because I have to name it somewhere else before it will appear?
If so is it then possible to select devices, switches etc that are present in other tabs and move them to a different tab. I would really like a tab called security so I can put all my window and door sensors in it.
Dave
Additional Menu Tabs and moving devices to these.
- FireWizard
Re: Additional Menu Tabs and moving devices to these.
You can create your own custom page.
See: https://www.domoticz.com/forum/viewtopic.php?t=20503.
But, as far as I know, it is not possible to move devices from other tabs or create new devices and place them under the Custom tab.You can create your own page.
Last edited by FireWizard on Saturday 07 September 2019 22:22, edited 1 time in total.
Dave21w
- Domoticz version: Stable
Thanks for the info, it's a little bit pointless then if you can create a custom tab but move nothing to it, maybe it would be a good idea if when a new device was added it gave you the option of which tab you would like it in - one for the suggestions box maybe?
