Get time from xml file Topic is solved
sailmich
Post by sailmich »
I have two Rpi 3 running. First is running newest Domoticz beta on the other is weewx running connected to my personal weather station. I have some lua scripts running to get temperature, wind, UV .... Everything is running good but from time to time weewx is hanging and than the xml file from were I take all the data is old. I tried already everything on weewx to avoid this but still happening from time to time. What I would like to do is compare the time in my xml file with system time on my domoticz server and when bigger than 10 minutes than to a ssh sudo reboot the weewx server. I don't know how to get the time out of the xml file and how to compare it with os time.
Script how I get gust.
-- Title: script_device_weewx.lua
-- Date: 10-01-2016
-- this script reads the weewxpws xml file and uploads current data to virtual device
time = os.date("*t")
if ((time.min % 1)==0) then
os.execute('sudo wget http://MyweewxIP/weewx_pws.xml -O /path/to/weewx_pws.xml')
local filename = "/path/to/weewx_pws.xml"
local line = ''
local windGust = 0
local speeddevice = ''
for line in io.lines(filename) do
if string.find(line,"\"windGust\"") then
windGust=tonumber(string.match(line, "%d+.%d+"))
windGustKMH=windGust*3.6
-- Update virtual device id
speeddevice='148|0|'..windGustKMH..';0'
--print(speeddevice))
commandArray['UpdateDevice'] = speeddevice
My try but get stuck:(
-- Date: 10-01-2016
os.execute('sudo wget http://MYweewxIP/weewx_pws.xml -O /path/to/weewx_pws.xml')
local line = ''
local station_time = 0
if string.find(line,"\"station_time\"") then
station_time=tonumber(string.match(line, "%d+.%d+")) attempt to call a nil value
How to compare station_time with ostime?
"ssh MYweewxIP sudo reboot"
The xml where I would like to get the station time from.
<realtime><data realtime="station_time">12:26 CEST</data></realtime>
Thanks for any help.
ben53252642
Re: Get time from xml file
Post by ben53252642 »
Play with this on the weewx machine:
watchdog.sh
#!/bin/bash
while true; do
if (find /PATH/TO/XMLFILE -mmin +3 -type f | grep -q /); then
echo "$(date +%T) XML file not updating, potential fault detected, restarting the service..."
service NAME stop
service NAME start
fi
echo "$(date +%T) Sleeping for 30 seconds before next check"
sleep 30
done
If the xml file is not modified for more than 3 minutes then the restart command is executed, it checks every 30 seconds.
I suggest running it in a screen session in loop on boot. eg:
sudo -u root screen -dmS mywatchdogscript /scripts/watchdog.sh
Check how often the xml file is changed normally then set the minutes currently +3 accordingly to detect when its failing and restart the service.
Don't forget to make the watchdog file executable: sudo chmod 755 watchdog.sh
If restarting the service doesn't fix it, you could always just reboot the whole Pi when it detects data no longer going into the xml file, eg:
#!/bin/bash
while true; do
echo "$(date +%T) XML file not updating, potential fault detected, rebooting in 30 seconds..."
sleep 30
sudo reboot
fi
sleep 30
done
Last edited by ben53252642 on Wednesday 28 August 2019 15:14, edited 2 times in total.
sailmich
Post by sailmich »
Thanks, I will check this.
ben53252642
Re-check that code, had set +3 to -3 for testing.
Should be +3 (eg + x minutes)
Some one line testers if you want to play with it on the terminal:
create a file somewhere eg: /test
Run the below command and nothing should be output if its less than 3 minutes old and the message should echo if its older.
if (find /test -mmin +3 -type f | grep -q /); then echo "file is older than x minutes"; fi
ben53252642
Also consider running this on the weather Pi, I use it on all my sensor Pi's to auto reboot them if they can't see the main domoticz due to eg not auto reconnecting to the WiFi network.
It auto reboots the Pi if it can't see the target IP for 15 minutes.
#!/bin/bash
target="192.168.0.5"
# Wait for network to come up
sleep 120
while true; do
echo "Checking target $target every minute for 15 minutes"
ping -c15 -i900 "$target" > /dev/null
if [ $? != 0 ]
then
  sudo /sbin/shutdown -r now
fi
sleep 1
done
sailmich
Post by sailmich »
Watchdog service doesn't start after reboot. :o I use the watchdog.conf to check if the file is older than 3 minutes.
sudo service watchdog status
● watchdog.service - watchdog daemon
Loaded: loaded (/lib/systemd/system/watchdog.service; static)
Active: inactive (dead)
After starting the service manually.
Active: active (running) since Thu 2019-08-29 09:43:38 CEST; 9s ago
Process: 1074 ExecStart=/bin/sh -c [ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options (code=exited, status=0/SUCCESS)
Process: 1071 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, status=0/SUCCESS)
Main PID: 1076 (watchdog)
CGroup: /system.slice/watchdog.service
└─1076 /usr/sbin/watchdog
Aug 29 09:43:38 Wetterstation watchdog[1076]: int=1s realtime=yes sync=no so...0
Aug 29 09:43:38 Wetterstation watchdog[1076]: ping: no machine to check
Aug 29 09:43:38 Wetterstation watchdog[1076]: file: /var/www/weewx_pws.xml:300
Aug 29 09:43:38 Wetterstation watchdog[1076]: pidfile: no server process to ...k
Aug 29 09:43:38 Wetterstation watchdog[1076]: interface: no interface to check
Aug 29 09:43:38 Wetterstation watchdog[1076]: temperature: no sensors to check
Aug 29 09:43:38 Wetterstation watchdog[1076]: test=none(0) repair=none(0) al...o
Aug 29 09:43:38 Wetterstation watchdog[1076]: cannot set timeout 60 (errno =...)
Aug 29 09:43:38 Wetterstation watchdog[1076]: hardware watchdog identity: Br...r
Aug 29 09:43:38 Wetterstation systemd[1]: Started watchdog daemon.
Hint: Some lines were ellipsized, use -l to show in full.
sailmich
Post by sailmich »
Found in the www for Jessie it's necessary to add follow line in /lib/systemd/system/watchdog.service
[Install]
WantedBy=multi-user.target
Now watchdog is starting at boot:)
Thank you for your help!
