Trying to get URL data and load it to a text sensor
svanni
Domoticz version: 4.10693
Post by svanni »
My goal is to update a text sensor with my most recent Public IP Address.
I am currently using the RPi's CRON to email myself the info...
4 * * * * wget http://api.ipify.org -O latest_ip.txt
5 * * * * mpack -s "Latest IP Address" /home/pi/latest_ip.txt [email protected]
However, I'd rather do this using a Lua script in Domoticz, and load the data into a text sensor.
Any suggestions ?
Thanks in advance.
emme
Domoticz version: latest
Re: Trying to get URL data and load it to a text sensor
Post by emme »
there is a much easier way to obtain in within Domoticz using a dzVents Script.
I use a script with a Http request ans response (async mode) with the plus of updating my IPv6 Tunnel from HE:
here is it...
local getIp    = 'https://api.ipify.org/?format=json'
local ipv6UPD  = 'https://<userID>:<token>@ipv4.tunnelbroker.net/nic/update?hostname=<TunnelID>'
		timer =         { 'every 6 hours' },
		httpResponses = { 'wanIP' }
	logging = {
        level = domoticz.LOG_FORCE,
        marker = '[WAN IP]'
	execute = function(dz, devNil)
		local actIP = dz.devices('Wan IP').text
		local newIP = 'Impossibile recuperare IP'
        if (devNil.isTimer) or (devNil.isDevice) then
            dz.log("Invio Richiesta WanIP")
            dz.openURL({
                url = getIp,
                method = 'GET',
                callback = 'wanIP'
        elseif (devNil.isHTTPResponse) then
            dz.log("Ritorno Richiesta WanIP")
            if (devNil.ok) then -- statusCode == 2xx
                newIP = devNil.json.ip
            if newIP ~= actIP then
                dz.openURL({
                    url = ipv6UPD ,
                    method = 'GET',
                    callback = 'updIPv6Tunnel'
                dz.devices('Wan IP').updateText(newIP)
"We always done this way"
svanni
Post by svanni »
Thanks emme, I'll give that a try later this week.
