RGBW setcolbrightness impossible?
Posted: Tuesday 27 August 2019 18:53
Trying to set the RGBW color with setHex give me two effects here, they are the same with both Fibaro FRGB devices.
First the light comes up with 100% brightness, from just the setHex command. Second the device crashes out of the net and calls an failure email. Here first the dimmer is set to 90 percent, after that i like to set only the RGB color for the stripe. Do i have to use a combo of both commands? At the moment for brightness and color two different devices are in use.
Solderbro
2019-08-27 18:45:07.086 Status: EventSystem: Script event triggered: /home/domoticz/domoticz/dzVents/runtime/dzVents.lua
2019-08-27 18:45:07.100 Status: setcolbrightnessvalue: ID: 7e6, bri: 100, color: '{m: 1, RGB: f4fff9, CWWW: 0000, CT: 0}'
2019-08-27 18:45:07.100 Status: Incoming connection from: 127.0.0.1
2019-08-27 18:45:07.100 Error: OpenZWave: Internal Node Device not found! (NodeID: 41, 0x29)
local light = domoticz.devices('Kue LED RGB')
local pir = domoticz.devices('Kue PIR Sensor')
local color = domoticz.devices('Kue RGBW Color')
local nachtlicht = domoticz.variables("Nachtlicht")
local log = domoticz.log
if nachtlicht.value == 0 then
print('Taglicht einschalten')
light.dimTo(90)
color.setHex(0xF5,0xFF,0xFA)
