I bougth 3x Digoo DG-RS8 sensors and have seen that they are temperature and Hygrometer in one package. I bought toen because they were listed in the RFXcom manual.
Now they do work but only the temperature part. They are not sending the moist %. Can i make it work somehow?
Digoo DG-RS8
b_weijenberg
- Target OS: -
Re: Digoo DG-RS8
If the humidity is also not displayed in RFXmngr contact support rfxcom.
RFX-433, RFX-433EMC, RFX-868
boekee
Re: Digoo DG-RS8
When you have the RFXtrx433E
Then flash to Pro1 Firmware version 1041
After I have done that, domoticz sees the Digoo DG-RS8
And works perfectly
Domoticz sees the RS8 as Alecto WS1700
And works perfectly
krizzz
Re: Digoo DG-RS8
You are the bestboekee wrote:When you have the RFXtrx433E
And works perfectly
