version dashticz Topic is solved
pvklink
- Domoticz version: latest b
version dashticz
My dashticz gives 2.5.11 in the info tab, and a remark that this is the latest version.
On the internet i see a more recent version, beta 3.05, https://github.com/Dashticz/dashticz.
Is the 3 version another fork, and if so, are both versions supported and updated?
Can i do a fresh install of the 3.05 , and copy my current custom.js, custom.css and config.js ?
Jablotron connection, Ikea
- HansieNL
Re: version dashticz
Version 3 is the new version. The fork was at an other address, but is now at the old address.pvklink wrote: Sunday 18 August 2019 20:44 Hi,
For fresh install:
1st make a backup of your custom folder. Remove that folder if named dashticz. You then can do the install in a new folder dashticz:
git clone https://github.com/Dashticz/dashticz dashticz --branch betaTo update just do the following in the dashticz folder to update:
git pullBlah blah blah
pvklink
ok thanks HansiNL, i will update with the latest beta...
pvklink
Ok, installed latest beta and removed old dashticz_v2 folder.
I get an error when i want to remove the old symbolic link that the folder does not exist... (it does exist!)
sudo unlink /var/www/html/dashticz_v2 or
sudo rm /var/www/html/dashticz_v2
Lokonli
Yes, that will work.pvklink wrote: Monday 19 August 2019 19:36 Ok, installed latest beta and removed old dashticz_v2 folder.
I get an error when i start dashticz, so i renamed the dashticz folder to dashticz_v2 and working!
I think it is easier to have no version in the folder name so is this the way to do it?:
1) rename the folder back to dashticz
2) sudo ln -s /home/pi/dashticz/ /var/www/html
3) how do i remove the old sudo ln -s /home/pi/dashticz_v2/ /var/www/html symbolic link ?
For 3:
pvklink
everything works! thanks!
pvklink
have two small errors with the latest version
1. my buienradar does not work anymore... i had a live screen at my dashboard (without a click)
buttons.buienradar = {width:9, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =338&h=297', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
2. in the old version i had a blinds_closed.png changed in yellow in the /img folder. I changed it again but dashticz keeps on showing the old png also after a f5
Lokonli
For 1:pvklink wrote: Wednesday 21 August 2019 16:57 have two small errors with the latest version
Which buienradar link do you use? In a button or in a frame? buienradar changed something which blocks showing their site in a frame.
for 2:
I recommend to save the new image with a new name, and use the recently added imageOff (or imageOn) parameter to select your new image.
pvklink
1. Hi lokonli, i use the link in a button but any other solution or better solution is welcome...
i sometimes see nice koloms with days with a forecats
2. ok clear, will try that!
can dis be a png file and do i put this in the img folder?
pvklink
I tried, but my block stays empty
added:
//Configuring the OWM parameters
config['owm_api'] = 'my new api key';
config['owm_city'] = 'Rijswijk';
config['owm_name'] = '';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_cnt'] = '3';
config['owm_min'] = true;
config['owm_days'] = true;
changed my column
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [3,1248,1423,1303,1049,1018,1025,'currentweather_big_owm','weather_owm','455_1','982_1','457_1',1163,1285,1305,1250,calendars.fam]
columns[1]['width'] = 3;
etc.
added:
changed my column
var columns = {}
columns[1] = {}
etc.
- Naamloos.png (21.12 KiB) Viewed 2909 times
- HansieNL
If you wanna keep your own images in the custom folder you can make a sub folder named img if you like. In the block section you then can use ../custom/img/image.png.pvklink wrote: Wednesday 21 August 2019 17:40 2. ok clear, will try that!
Yes, best is to use a png.
Blah blah blah
pvklink
ok, both problems solved as you advised!
thanks lokonli!
it took some time before the api was operational...
thanks lokonli!
pvklink
Last one little problem, there are 2 Rijswijk in Holland.
The config setting only offers city name.
I think city ID is in my case a better option, because i get the wrong Rijswijk and cant adjust it...
see the city list on the website of own
- EdwinK
- Domoticz version: BETA
There are even three Rijswijk's (South Holland, Brabant, Gelre)
pvklink
Yes, indeed!
- HansieNL
I see Open Weather Map Station (City or Code) in the config menu. Did you already try to fill in your city code?pvklink wrote: Wednesday 21 August 2019 18:53 Last one little problem, there are 2 Rijswijk in Holland.
Blah blah blah
pvklink
config['owm_city'] = 'Rijswijk'; works
config['owm_city'] = '2748075'; not
config['owm_city'] = 2748075; not
- HansieNL
Bug reported: https://github.com/Dashticz/dashticz/issues/35pvklink wrote: Wednesday 21 August 2019 20:33 config['owm_city'] = 'Rijswijk'; works
Blah blah blah
pvklink
I saw that the bug was solved in a new beta
so i did a git pull....
do i use the location id as following:
instead off
i use:
config['owm_name'] = 'Rijswijk (zh)';
instead off
i use:
Lokonli
Yes, that should work
