Curl bash Topic is solved
Apievuisy
Curl bash
Post by Apievuisy »
I have a Raspberry Pi with a motion sensor which when its tripped should visit the domoticz api to notify that it has been tripped.
I would like to visit this api via a shellscript.
This is what i came up with:
#!/bin/bash
VAR1=$(curl -v "http://192.168.1.9:8084/json.htm?type=command&param=switchLight&idx=3&switchcmd=On");
echo $VAR1;
exit 0
This results is Domoticz telling me something is wrong - ERR.
When i run the curl command from the commandline (without the VAR1 parameter), everything is working fine..
Could somebody pleasy help me, i have been searching for hours and i cant find the solution.
I think it has something to do with the variables in the URL (e.g. &idx=3)
Re: Curl bash
Apievuisy wrote: Tuesday 13 August 2019 20:29 VAR1=$(curl -v "http://192.168.1.9:8084/json.htm?type=c ... itchcmd=On");
[/code]
switchLight is not recognized by domoticz. It should be switchlight. (case matters)
Other problem could be that the user executing the bash script is not authorized for this action
Apievuisy
Re: Curl bash
Post by Apievuisy »
waaren wrote: Wednesday 14 August 2019 9:14
[/code]
Thanks, this did the trick!
