Z-stick gen5 on raspberry not functional on PI-4
Posted: Monday 12 August 2019 19:26
by ThomasD
Dear all,
I have a raspberry pi 4 model b 2gb and a usb z-wave controller Z-Stick gen5 Aeonlabs
The domoticz verzin is V4.10717.
Now I do not succeed in getting the Stick functional. Also I cannot define Devices.
I do not know which serial port to select for the Z-stick, when defining HARDWARE in Domoticz, I have the following options:
/dev/ttyUSB0
/dev/serial1
/devttyAMA0
/dev/serial/by-id/usb/FTDI_FT232RUSB_UART_AK49Q2IV-if00-port0
Can anybody help me?
Thank you in advance!
Re: Z-stick gen5 on raspberry not functional
Posted: Monday 12 August 2019 19:32
by Skippiemanz
The stick is not listed. Looks like kot recognized.
Perhaps a reboot or different port? Are you using a sufficient power supply? Min 2 or 3 amp
Re: Z-stick gen5 on raspberry not functional PI-4
Posted: Monday 12 August 2019 19:47
by ThomasD
The power supply is 5,1 V 3,0 A
I rebooted but with no success...
Posted: Monday 12 August 2019 19:58
by ThomasD
The log says:
2019-08-12 19:56:28.997 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2019-08-12 19:56:29.000 Status: OpenZWave: Starting...
2019-08-12 19:56:29.000 Status: OpenZWave: Version: 1.4-3335-g74e05982-dirty
2019-08-12 19:56:29.001 Error: OpenZWave: Driver Failed!!
Can anybody help me with this issue?
Thanks,
Posted: Monday 12 August 2019 20:28
by Solderbro
Possible that the battery is empty and the USB port will break down from the load.
But first have a look if the stick is detected by USB at all, it should appear here.
domoticz@domosys:~$ lsusb
Bus 001 Device 005: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Have a look for the USB power, it should be in the /boot/config.txt
#USB-Current
max_usb_current=1
I have to use that, because the gen5 stick, webcam and 1.8" harddisc exceeds the USB limit on the 3b+
Last guess: Some USB2 devices won't work on USB3 ports under linux, try a black USB port.
Solderbro
Posted: Monday 12 August 2019 21:23
by cmartens75
I have had the same issue a few days ago when I tried to use the Aeotec stick on a Raspberry 4. There is something strange with this stick. The Raspberry thinks it is a USB3 device, however the device is only USB2 capable.
To solve the issue, I have bought the cheapest USB 2.0 hub i could find (
https://www.action.com/nl-nl/p/usb-poort-/). I have connected the USB 2.0 hub on one of the black USB2 ports of the Raspberry, the extra device was immediately connected via dmesg. After that, I have connected the Aeotec Z-wave stick in the USB 2.0 hub. The device is now visible also and gets ttyACM0 port assigned. So the problem is solved. Good luck!
Posted: Monday 12 August 2019 21:51
by ThomasD
gonna try it thanks a lot
Posted: Tuesday 13 August 2019 9:35
by Snowtiger
This problem only exists on a PI 4 - i suggest you change the title of the problem by adding PI 4 to it
Also see -
https://www.raspberrypi.org/forums/view ... p?t=245031 for more details why it fails on a USB 3 port
Posted: Tuesday 13 August 2019 18:37
by lost
Like temp problems, looks PI team is never faulty...
This version really looks ill-conceived so far.
Posted: Tuesday 13 August 2019 19:28
by ThomasD
cmartens75 wrote: Monday 12 August 2019 21:23
Re: Z-stick gen5 on raspberry not functional on PI-4
by ThomasD
Skippiemanz wrote: Monday 12 August 2019 19:32
Posted: Thursday 24 October 2019 15:51
by splodge
This also worked for me. I plugged in a USB Hub (USB3.0 as it happens) and I was able to see the Zstick S5 which I hadn't been able to see before.
Posted: Friday 13 December 2019 0:10
by JacKok
This was also the solution for me
it takes 2 days to search for the problem, but now it works. thanks!
Posted: Tuesday 02 June 2020 5:08
by antibound
Did you do anything else? I did those steps and I see the port assigned but when I put that value in it still says its invalid.
Posted: Saturday 14 November 2020 15:46
by ronald1827
same here.
used a usb 2.0 hub and the aeotec gen5 zwave stick was listed, the same problem i had with de P1 smart meter serial port , i ordered a extra 1, i already had a second gen 5 aeotec stick to test with , i also gonna attach the p1 serial usb adapter to the same usb 2 hub and see if it works
it's strange.
Posted: Saturday 16 September 2023 21:38
by tiga
same issue here.
you use a non powered usb hub??
on the wiki they say to use a powered usb hub.
does it realy matter?
non powered are cheaper so........
Posted: Sunday 17 September 2023 17:46
by sincze
I use a non powered USB hub Cheap as hell, it just works.
