Z-stick gen5 on raspberry not functional on PI-4 Topic is solved
ThomasD
- Domoticz version: V4.10717
Dear all,
I have a raspberry pi 4 model b 2gb and a usb z-wave controller Z-Stick gen5 Aeonlabs
The domoticz verzin is V4.10717.
Now I do not succeed in getting the Stick functional. Also I cannot define Devices.
I do not know which serial port to select for the Z-stick, when defining HARDWARE in Domoticz, I have the following options:
/dev/ttyUSB0
/dev/serial1
/devttyAMA0
/dev/serial/by-id/usb/FTDI_FT232RUSB_UART_AK49Q2IV-if00-port0
Can anybody help me?
Thank you in advance!
/dev/ttyUSB0
/dev/serial1
/devttyAMA0
Skippiemanz
- Domoticz version: 4.10233
Re: Z-stick gen5 on raspberry not functional
The stick is not listed. Looks like kot recognized.
Perhaps a reboot or different port? Are you using a sufficient power supply? Min 2 or 3 amp
ThomasD
Re: Z-stick gen5 on raspberry not functional PI-4
The power supply is 5,1 V 3,0 A
I rebooted but with no success...
ThomasD
The log says:
2019-08-12 19:56:28.997 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2019-08-12 19:56:29.000 Status: OpenZWave: Starting...
2019-08-12 19:56:29.000 Status: OpenZWave: Version: 1.4-3335-g74e05982-dirty
2019-08-12 19:56:29.001 Error: OpenZWave: Driver Failed!!
Can anybody help me with this issue?
Thanks,
Thanks,
- Solderbro
- Domoticz version: 2020.1
Possible that the battery is empty and the USB port will break down from the load.
But first have a look if the stick is detected by USB at all, it should appear here.
domoticz@domosys:~$ lsusb
Bus 001 Device 005: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Have a look for the USB power, it should be in the /boot/config.txt
#USB-Current
max_usb_current=1
I have to use that, because the gen5 stick, webcam and 1.8" harddisc exceeds the USB limit on the 3b+
Last guess: Some USB2 devices won't work on USB3 ports under linux, try a black USB port.
Solderbro
#USB-Current
max_usb_current=1
Solderbro
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
cmartens75
I have had the same issue a few days ago when I tried to use the Aeotec stick on a Raspberry 4. There is something strange with this stick. The Raspberry thinks it is a USB3 device, however the device is only USB2 capable.
To solve the issue, I have bought the cheapest USB 2.0 hub i could find (https://www.action.com/nl-nl/p/usb-poort-/). I have connected the USB 2.0 hub on one of the black USB2 ports of the Raspberry, the extra device was immediately connected via dmesg. After that, I have connected the Aeotec Z-wave stick in the USB 2.0 hub. The device is now visible also and gets ttyACM0 port assigned. So the problem is solved. Good luck!
ThomasD
gonna try it thanks a lot
Snowtiger
- Domoticz version: 4.10915
This problem only exists on a PI 4 - i suggest you change the title of the problem by adding PI 4 to it
Also see - https://www.raspberrypi.org/forums/view ... p?t=245031 for more details why it fails on a USB 3 port
lost
Like temp problems, looks PI team is never faulty...Snowtiger wrote: Tuesday 13 August 2019 9:35 This problem only exists on a PI 4 - i suggest you change the title of the problem by adding PI 4 to it
This version really looks ill-conceived so far.
ThomasD
cmartens75 wrote: Monday 12 August 2019 21:23 Hi,
ThomasD
Re: Z-stick gen5 on raspberry not functional on PI-4
Skippiemanz wrote: Monday 12 August 2019 19:32 The stick is not listed. Looks like kot recognized.
splodge
This also worked for me. I plugged in a USB Hub (USB3.0 as it happens) and I was able to see the Zstick S5 which I hadn't been able to see before.cmartens75 wrote: Monday 12 August 2019 21:23 Hi,
My wife said don't overcomplicate the heating. oops..
JacKok
This was also the solution for mecmartens75 wrote: Monday 12 August 2019 21:23 Hi,
it takes 2 days to search for the problem, but now it works. thanks!
Did you do anything else? I did those steps and I see the port assigned but when I put that value in it still says its invalid.
ronald1827
same here.
used a usb 2.0 hub and the aeotec gen5 zwave stick was listed, the same problem i had with de P1 smart meter serial port , i ordered a extra 1, i already had a second gen 5 aeotec stick to test with , i also gonna attach the p1 serial usb adapter to the same usb 2 hub and see if it works
it's strange.
it's strange.
tiga
same issue here.
you use a non powered usb hub??
on the wiki they say to use a powered usb hub.
does it realy matter?
non powered are cheaper so........
- sincze
- Domoticz version: 2024.4
I use a non powered USB hub Cheap as hell, it just works.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
