Page 1 of 6
Python Plugin: Growatt Inverter
Posted: Sunday 11 August 2019 0:43
by sincze
Currently working on a plugin for Growatt Web.
Solved, Initial Release: https://github.com/sincze/Domoticz-Grow ... ver-Plugin
Looking at the API calls from the APP they have and it is unfortunately HTTP.
I have to post the password in md5 and the username to a url.
            sendData = { 'Verb' : 'POST',
                         'URL'  : '/newTwoLoginAPI.do',
                         'Headers' : self.apiRequestHeaders(),
                         'Data': "password="+password.hexdigest()+"&userName="+Parameters["Username"]
            Domoticz.Debug("SendData: "+str(sendData))
            Connection.Send(sendData)
It all seems to work fine however... the framework automatically creates a Authorization Basic now and the webserver does not like that offering me a 400 (Bad Request).
2019-08-11 00:36:53.666 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** POST./newTwoLoginAPI
2019-08-11 00:36:53.667 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** .do.HTTP/1.1..Author
2019-08-11 00:36:53.667 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ization:Basic.d2JsZX
2019-08-11 00:36:53.667 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ****************==..
Can I disable the Authorization Basic somehow?
Re: Python Plugin: Growatt Inverter
Posted: Sunday 11 August 2019 6:07
by Dnpwwo
@sincze,
It only injects that header if both the actual Username & Password Parameters have values. To prevent that you can use a different Parameter to collect the Username (e.g Mode1 with a label of "Username")
Posted: Sunday 11 August 2019 9:54
by sincze
Dnpwwo wrote: Sunday 11 August 2019 6:07 @sincze,
Thanks for your always quick replys to keep people motivated and going. :D
I would also think you are right indeed. The test setup: Domoticz was running on: V4.11062 now updated to: Domoticz V4.11079
Plugin Parameters setup like:
<param field="Address" label="Server Address" width="200px" required="true" default="server-api.growatt.com"/>
<param field="Mode2" label="Portal Username" width="200px" required="true" default="admin"/>
<param field="Password" label="Portal Password" width="200px" required="true" password="true"/>
<param field="Mode1" label="Protocol" width="75px">
That is as described in your answer, right?
Plugin thing that needs to happen:
        if (Status == 0):
            Domoticz.Debug("Google connected successfully.")
            password=Parameters["Password"]
            password=hashlib.md5(str.encode(password))
            Domoticz.Debug("Password_1 is now: "+password.hexdigest())
                         'Data': "password="+password.hexdigest()+"&userName="+Parameters["Mode2"]
        else:
            Domoticz.Log("Failed to connect ("+str(Status)+") to: "+Parameters["Address"]+":"+Parameters["Mode1"]+" with error: "+Description)
But the logging shows BasicAuth
[spoiler]2019-08-11 09:42:03.881 (Growatt via Google) Calling message handler 'onConnect'.
2019-08-11 09:42:03.881 (Growatt via Google) Google connected successfully.
2019-08-11 09:42:03.881 (Growatt via Google) Password_1 is now: ********************************************
2019-08-11 09:42:03.881 (Growatt via Google) SendData: {'URL': '/newTwoLoginAPI.do', 'Verb': 'POST', 'Headers': {'User-Agent': 'Domoticz/1.0', 'Connection': 'keep-alive', 'Content-Type': 'application/x-www-form-urlencoded; charset=utf-8'}, 'Data': 'password=********************************************&userName='******}
2019-08-11 09:42:03.881 (Growatt via Google) Pushing 'WriteDirective' on to queue
2019-08-11 09:42:03.882 (Growatt via Google) Processing 'WriteDirective' message
2019-08-11 09:42:03.882 (Growatt via Google) Sending 267 bytes of data
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** POST./newTwoLoginAPI
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** .do.HTTP/1.1..Author
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ization:Basic.******
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ****************==..
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** User-Agent:.Domoticz
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** /1.0..Connection:.ke
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ep-alive..Content-Ty
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** pe:.application/x-ww
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** w-form-urlencoded;.c
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** harset=utf-8..Conten
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** t-Length:.51....pass
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** word=***************
2019-08-11 09:42:03.882 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** *****************&us
2019-08-11 09:42:03.883 (Growatt via Google) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** erName=*************
2019-08-11 09:42:03.919 (Growatt via Google) Pushing 'ReadEvent' on to queue
2019-08-11 09:42:03.919 (Growatt via Google) Queued asynchronous read aborted (server-api.growatt.com:80), [2] End of file.
2019-08-11 09:42:03.919 (Growatt via Google) Pushing 'DisconnectedEvent' on to queue
2019-08-11 09:42:03.933 (Growatt via Google) Processing 'ReadEvent' message
2019-08-11 09:42:03.933 (Growatt via Google) Received 394 bytes of data
2019-08-11 09:42:03.933 (Growatt via Google) 48 54 54 50 2f 31 2e 31 20 34 30 30 20 42 61 64 20 52 65 71 HTTP/1.1.400.Bad.Req
2019-08-11 09:42:03.933 (Growatt via Google) 75 65 73 74 0d 0a 44 61 74 65 3a 20 53 75 6e 2c 20 31 31 20 [/spoiler]
Posted: Sunday 11 August 2019 10:12
by sincze
Changing both username and Password fields to 'ModeX' give me a result with HTTP protocol.
Maybe something not 100% in the code if both username and password fields are filled?
        <param field="Mode3" label="Portal Password" width="200px" required="true" password="true"/>
Posted: Sunday 11 August 2019 10:27
by Dnpwwo
@sincze,
You only had to change one to get the result. If you didn't delete and create the hardware again the old Parameter may have still been handed to the plugin?
Glad its sorted either way.
Posted: Sunday 11 August 2019 11:29
by sincze
Dnpwwo wrote: Sunday 11 August 2019 10:27 @sincze,
-> "If you didn't delete and create the hardware again the old Parameter may have still been handed to the plugin?"
That must be it did not DELETE the hardware ;-) I'll revert changes later back to your suggestions.
Currently trying to extract from HEADERS:
2019-08-11 11:25:53.593 (Growatt Test) --->'Headers (5):
2019-08-11 11:25:53.593 (Growatt Test) ------->'Connection':'keep-alive'
2019-08-11 11:25:53.593 (Growatt Test) ------->'Set-Cookie':'JSESSIONID=********************; Path=/; HttpOnly
2019-08-11 11:25:53.593 (Growatt Test) ------->'Date':'Sun, 11 Aug 2019 09:25:53 GMT'
2019-08-11 11:25:53.593 (Growatt Test) ------->'Content-Type':'application/json;charset=UTF-8'
2019-08-11 11:25:53.593 (Growatt Test) ------->'Transfer-Encoding':'chunked'
The session ID so I can submit that in the following request as a Cookie.
Any functions for that on your shelf ? :D
Posted: Sunday 11 August 2019 15:21
by sincze
The following is shown in the Domoticz log, for authentication I need:
Set-Cookie: JSESSIONID=*****
Set-Cookie: SERVERID=************
2019-08-11 15:13:14.611 (Growatt Test) 48 54 54 50 2f 31 2e 31 20 32 30 30 20 4f 4b 0d 0a 44 61 74 HTTP/1.1.200.OK..Dat
2019-08-11 15:13:14.611 (Growatt Test) 65 3a 20 53 75 6e 2c 20 31 31 20 41 75 67 20 32 30 31 39 20 e:.Sun,.11.Aug.2019.
2019-08-11 15:13:14.611 (Growatt Test) 31 33 3a 31 33 3a 31 34 20 47 4d 54 0d 0a 43 6f 6e 74 65 6e 13:13:14.GMT..Conten
2019-08-11 15:13:14.611 (Growatt Test) 74 2d 54 79 70 65 3a 20 61 70 70 6c 69 63 61 74 69 6f 6e 2f t-Type:.application/
2019-08-11 15:13:14.611 (Growatt Test) 6a 73 6f 6e 3b 63 68 61 72 73 65 74 3d 55 54 46 2d 38 0d 0a json;charset=UTF-8..
2019-08-11 15:13:14.611 (Growatt Test) 54 72 61 6e 73 66 65 72 2d 45 6e 63 6f 64 69 6e 67 3a 20 63 Transfer-Encoding:.c
2019-08-11 15:13:14.611 (Growatt Test) 68 75 6e 6b 65 64 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 hunked..Connection:.
2019-08-11 15:13:14.611 (Growatt Test) 6b 65 65 70 2d 61 6c 69 76 65 0d 0a 53 65 74 2d 43 6f 6f 6b keep-alive..Set-Cook
2019-08-11 15:13:14.611 (Growatt Test) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ie:.JSESSIONID=*****
2019-08-11 15:13:14.612 (Growatt Test) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** 24F0B5EF897CF3AD720A
2019-08-11 15:13:14.612 (Growatt Test) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** *******;.Path=/;.Htt
2019-08-11 15:13:14.612 (Growatt Test) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** pOnly..Set-Cookie:.S
2019-08-11 15:13:14.612 (Growatt Test) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ERVERID=************
2019-08-11 15:13:14.612 (Growatt Test) ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ** ********************
If I use a function like the following I am only able to see/extract the JSESSIONID, what do I miss.
def ProcessHTTPHeaders(httpDict):
    if isinstance(httpDict, dict):
        Domoticz.Debug("ProcessHTTPHeaders ("+str(len(httpDict))+"):")
        for x in httpDict:
            if isinstance(httpDict[x], dict):
                if (x == "Headers"):
                    Domoticz.Debug("---> ProcessHTTPHeaders: Headers found")
                    for y in httpDict[x]:
                        if (y == "Set-Cookie"):
                            Domoticz.Debug("---> ProcessHTTPHeaders Cookies found "+ str(httpDict[x][y]))
                            self.cookieAvailable = True
                            self.cookie=str(httpDict[x][y])
                        else:
                            Domoticz.Debug("---> ProcessHTTPHeaders No Set-Cookies something else "+ str(httpDict[x][y]))
                    else:
                        Domoticz.Debug("---> ProcessHTTPHeaders Set Cookies 2 something else "+ str(httpDict[x][y]))
                else:
                    Domoticz.Debug("---> ProcessHTTPHeaders No Headers something else "+ str(httpDict[x]))
        else:
            Domoticz.Debug("---> ProcessHTTPHeaders What did I find... "+ str(httpDict[x]))
2019-08-11 15:23:42.400 (Growatt Test) Calling message handler 'onMessage'.
2019-08-11 15:23:42.400 (Growatt Test) HTTP Details (3):
2019-08-11 15:23:42.400 (Growatt Test) --->'Headers (5):
2019-08-11 15:23:42.400 (Growatt Test) ------->'Content-Type':'application/json;charset=UTF-8'
2019-08-11 15:23:42.400 (Growatt Test) ------->'Connection':'keep-alive'
2019-08-11 15:23:42.400 (Growatt Test) ------->'Transfer-Encoding':'chunked'
2019-08-11 15:23:42.400 (Growatt Test) ------->'Set-Cookie':'JSESSIONID=*****************; Path=/; HttpOnly
2019-08-11 15:23:42.400 (Growatt Test) ------->'Date':'Sun, 11 Aug 2019 13:23:42 GMT'
2019-08-11 15:23:42.400 (Growatt Test) --->'Status':'200'
Posted: Monday 12 August 2019 23:28
by Dnpwwo
@sincze,
The framework currently treats http headers as a simple dictionary of strings which may need to change. Duplicates should probably be handled via a list.
I'm travelling at the moment but can have a look later in the week.
Posted: Tuesday 13 August 2019 18:06
by sincze
Dnpwwo wrote: Monday 12 August 2019 23:28 @sincze,
That would be appreciated as I can only use existing functionalities. :lol:
I am not a (python) developer at all I study other peoples products, to learn, figure out how their plugin works and create my 'own'.
Posted: Sunday 18 August 2019 13:32
by Dnpwwo
@sincze,
I pushed an upgrade tonight that allows headers to be strings, bytes, bytearrays or lists. When a list is supplied all the list values are injected as separate headers of the specifed type.
e.g:
            sendData = { 'Verb' : 'GET',
                         'URL'  : '/',
                         'Headers' : { 'Content-Type': 'text/xml; charset=utf-8', \
                                       'Connection': 'keep-alive', \
                                       'Accept': 'Content-Type: text/html; charset=UTF-8', \
                                       'Host': Parameters["Address"]+":"+Parameters["Mode1"], \
                                       'User-Agent':'Domoticz/1.0',
				       'Cookie': ['CONSENT=WP.278be6',
						  b'ANID=AHWqTUkA63jkRUDy98OeQlgB2tzyyYqKWCHPADiSGOGc5ZVtduyCgaMVgzonI3Rn'] }
will create 2 'Cookie' headers in the request.
Response Headers will also have List objects when multiple headers are returned
Posted: Sunday 18 August 2019 14:15
by sincze
@Dnpwwo, Wow nice. Let me upgrade tonight or tomorrow to latest beta version and give it a try.
Just finished a Shelly1 project.
Now on to Sonoff at my parents place. :D
Posted: Monday 19 August 2019 21:02
by sincze
Currently on: Domoticz V4.11214
This is the request I need to make :lol:
I extracted the sessionId and serverId into 2 separate variables. :D
    def ProcessCookie(self, httpDict):
            Domoticz.Debug("Analyzing Data ("+str(len(httpDict))+"):")
            for x in httpDict:
                        Domoticz.Debug("---> Headers found")
                                Domoticz.Debug("---> Process Cookie Started")
                                self.sessionId = re.search(r"(?<=JSESSIONID=).*?(?=;)", str(httpDict[x][y])).group(0)
                                self.serverId =  re.search(r"(?<=SERVERID=).*?(?=;)", str(httpDict[x][y])).group(0)
                                Domoticz.Debug("---> Process Cookie Cookies found "+ str(httpDict[x][y]) )
Now finding out how to use it in the cookie ;-0
def stationDataRequest(self):
            'Verb': 'POST',
            'URL': '/newTwoPlantAPI.do?op=getUserCenterEnertyDataByPlantid',
            'Cookie': "[JSESSIONID="+self.sessionid+" ,SERVERID="+self.serverid+"]",
            'Data': "plantId="+str(self.plantId)+"&language=1",
            'Headers': self.apiRequestHeaders()
    def apiRequestHeaders(self):
            'Content-Type': 'application/x-www-form-urlencoded; charset=utf-8',
            'Host': 'server-api.growatt.com',
            'Accept-Encoding': 'gzip'
At the moment still out of luck.
2019-08-19 21:14:20.488 (Growatt No Basic Auth) Received 305 bytes of data
2019-08-19 21:14:20.488 (Growatt No Basic Auth) 48 54 54 50 2f 31 2e 31 20 33 30 32 20 46 6f 75 6e 64 0d 0a HTTP/1.1.302.Found..
2019-08-19 21:14:20.488 (Growatt No Basic Auth) 44 61 74 65 3a 20 4d 6f 6e 2c 20 31 39 20 41 75 67 20 32 30 Date:.Mon,.19.Aug.20
2019-08-19 21:14:20.489 (Growatt No Basic Auth) 31 39 20 31 39 3a 31 34 3a 32 30 20 47 4d 54 0d 0a 43 6f 6e 19.19:14:20.GMT..Con
2019-08-19 21:14:20.489 (Growatt No Basic Auth) 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 30 0d 0a 43 6f 6e 6e tent-Length:.0..Conn
2019-08-19 21:14:20.489 (Growatt No Basic Auth) 65 63 74 69 6f 6e 3a 20 6b 65 65 70 2d 61 6c 69 76 65 0d 0a ection:.keep-alive..
2019-08-19 21:14:20.489 (Growatt No Basic Auth) 53 65 74 2d 43 6f 6f 6b 69 65 3a 20 4a 53 45 53 53 49 4f 4e Set-Cookie:.JSESSION
2019-08-19 21:14:20.489 (Growatt No Basic Auth) 49 44 3d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ID=AE*************80
2019-08-19 21:14:20.489 (Growatt No Basic Auth) .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 54F40F88DF2A465;.Pat
2019-08-19 21:14:20.489 (Growatt No Basic Auth) 68 3d 2f 3b 20 48 74 74 70 4f 6e 6c 79 0d 0a 4c 6f 63 61 74 h=/;.HttpOnly..Locat
2019-08-19 21:14:20.489 (Growatt No Basic Auth) 69 6f 6e 3a 20 2f 65 72 72 6f 72 2e 64 6f 3f 65 72 72 6f 72 ion:./error.do?error
2019-08-19 21:14:20.489 (Growatt No Basic Auth) 4d 65 73 73 3d 65 72 72 6f 72 4e 6f 4c 6f 67 69 6e 0d 0a 53 Mess=errorNoLogin..S
2019-08-19 21:14:20.489 (Growatt No Basic Auth) 65 74 2d 43 6f 6f 6b 69 65 3a 20 53 45 52 56 45 52 49 44 3d et-Cookie:.SERVERID=
2019-08-19 21:14:20.489 (Growatt No Basic Auth) .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 0e***************300
2019-08-19 21:14:20.489 (Growatt No Basic Auth) .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 77***************242
2019-08-19 21:14:20.489 (Growatt No Basic Auth) .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 060|1566242060;Path=
2019-08-19 21:14:20.489 (Growatt No Basic Auth) .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. /....
2019-08-19 21:14:20.489 (Growatt No Basic Auth) Pushing 'onMessageCallback' on to queue
2019-08-19 21:14:20.489 (Growatt No Basic Auth) Processing 'onMessageCallback' message
2019-08-19 21:14:20.489 (Growatt No Basic Auth) Calling message handler 'onMessage'.
2019-08-19 21:14:20.490 (Growatt No Basic Auth) HTTP Details (2):
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 50 4f 53 54 20 2f 6e 65 77 54 77 6f 50 6c 61 6e 74 41 50 49 POST./newTwoPlantAPI
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 2e 64 6f 3f 6f 70 3d 67 65 74 55 73 65 72 43 65 6e 74 65 72 .do?op=getUserCenter
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 45 6e 65 72 74 79 44 61 74 61 42 79 50 6c 61 6e 74 69 64 20 EnertyDataByPlantid.
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 48 54 54 50 2f 31 2e 31 0d 0a 55 73 65 72 2d 41 67 65 6e 74 HTTP/1.1..User-Agent
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 3a 20 44 6f 6d 6f 74 69 63 7a 2f 31 2e 30 0d 0a 43 6f 6e 6e :.Domoticz/1.0..Conn
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 65 63 74 69 6f 6e 3a 20 6b 65 65 70 2d 61 6c 69 76 65 0d 0a ection:.keep-alive..
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 41 63 63 65 70 74 2d 45 6e 63 6f 64 69 6e 67 3a 20 67 7a 69 Accept-Encoding:.gzi
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 70 0d 0a 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 61 70 70 p..Content-Type:.app
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 6c 69 63 61 74 69 6f 6e 2f 78 2d 77 77 77 2d 66 6f 72 6d 2d lication/x-www-form-
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 75 72 6c 65 6e 63 6f 64 65 64 3b 20 63 68 61 72 73 65 74 3d urlencoded;.charset=
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 75 74 66 2d 38 0d 0a 48 6f 73 74 3a 20 73 65 72 76 65 72 2d utf-8..Host:.server-
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 61 70 69 2e 67 72 6f 77 61 74 74 2e 63 6f 6d 0d 0a 43 6f 6e api.growatt.com..Con
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 32 35 0d 0a 0d 0a 70 tent-Length:.25....p
2019-08-19 21:19:58.126 (Growatt No Basic Auth) 6c 61 6e 74 49 64 3d 31 35 35 .. .. .. .. .. .. .. .. 75 61 lantId=******&langua
2019-08-19 21:19:58.127 (Growatt No Basic Auth) 67 65 3d 31 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ge=1
Posted: Monday 19 August 2019 21:44
by sincze
            'Verb': 'POST',
            'Cookie': str(self.cookie),
            'plantId': str(self.plantId),
            'language': 1,
Post via Fiddler:
POST http://server-api.growatt.com/newTwoPlantAPI.do?op=getUserCenterEnertyDataByPlantid HTTP/1.1
Cookie: JSESSIONID=**********************************; SERVERID=*******************|************|***************
Content-Type: application/x-www-form-urlencoded;charset=UTF-8
Content-Length: 25
User-Agent: Domoticz/1.0
Host: server-api.growatt.com
Connection: Keep-Alive
Accept-Encoding: gzip
plantId=UUUUUU&language=1
Post via Python Plugin
2019-08-19 21:39:35.372 (Growatt No Basic Auth) Cookie Available StationDataRequest: {'Verb': 'POST', 'URL': '/newTwoPlantAPI.do?op=getUserCenterEnertyDataByPlantid', 'language': 1, 'plantId': 'UUUUUU', 'Headers': {'Content-Type': 'application/x-www-form-urlencoded; charset=utf-8', 'User-Agent': 'Domoticz/1.0', 'Accept-Encoding': 'gzip', 'Host': 'server-api.growatt.com', 'Connection': 'keep-alive'}, 'Cookie': 'JSESSIONID=**********************************; SERVERID=*******************|************|***************'}
mmmm... what did I miss.
Posted: Monday 19 August 2019 22:29
by Dnpwwo
@sincze ,
You aren't creating a proper Python list structure. If you check my sample the [ and ] are not enclosed in quotes.
should be
'Cookie': ["JSESSIONID="+self.sessionid, "SERVERID="+self.serverid],
Posted: Tuesday 20 August 2019 12:22
by sincze
So I created this function:
    def apiRequestHeaders_withcookie(self):
            'Verb': 'POST',
            'Headers' : { 'Content-Type': 'application/x-www-form-urlencoded; charset=utf-8',
                          'Data': "plantId"+str(self.plantId)+"&language=1"
It should represent all data in correct format (checked with separate python program in cli).
I received: {'URL': '/newTwoPlantAPI.do?op=getUserCenterEnertyDataByPlantid', 'Headers': {'Accept-Encoding': 'gzip', 'Data': 'plantId=12345&language=1', 'Host': 'server-api.growatt.com', 'User-Agent': 'Domoticz/1.0', 'Connection': 'keep-alive', 'Cookie': ['JSESSIONID=********9********DEA18A1A049C69A', 'SERVERID=0e6c72164********30********1651c|********|********], 'Content-Type': 'application/x-www-form-urlencoded; charset=utf-8'}, 'Verb': 'POST'}
However while executing debugging in the plugin using:
Domoticz.Debug("Cookie 1 apiURL StationDataRequest: "+str(self.apiRequestHeaders_withcookie() ) )
It stops exactly there.. No entry in the Domoticz log.
If I remove the line the plugin continues... ofcourse the
Connection.Send(self.apiRequestHeaders_withcookie() )
also does not work.. I missed something in the function.. Don't know yet what...
Posted: Tuesday 20 August 2019 12:43
by Dnpwwo
@sincze,
Not sure why the debug statement doesn't work but your 'Data' line is wrong.
  • it isn't a header so should be outside the header dictionary (i.e after the "}")
  • "plantId"+str should be "plantId="+str
if you want to debug the structure I made a better logging function recently:
def DumpHTTPResponseToLog(httpResp, level=0):
    if (level==0): Domoticz.Debug("HTTP Details ("+str(len(httpResp))+"):")
    indentStr = ""
    for x in range(level):
        indentStr += "----"
    if isinstance(httpResp, dict):
        for x in httpResp:
            if not isinstance(httpResp[x], dict) and not isinstance(httpResp[x], list):
                Domoticz.Debug(indentStr + ">'" + x + "':'" + str(httpResp[x]) + "'")
            else:
                Domoticz.Debug(indentStr + ">'" + x + "':")
                DumpHTTPResponseToLog(httpResp[x], level+1)
    elif isinstance(httpResp, list):
        for x in httpResp:
            Domoticz.Debug(indentStr + "['" + x + "']")
    else:
don't be put off by the name, it will handle a Request as well, try that.
Posted: Tuesday 20 August 2019 17:40
by sincze
"Not sure why the debug statement doesn't work but your 'Data' line is wrong."
This gives me an output with the dumphttp function, however due to missing cookie a 302 no login.:
            'Verb': 'POST',
#                          'Cookie': ["JSESSIONID="+self.sessionid, "SERVERID="+self.serverid],
This does not (no output just as described earlier).
            'Verb': 'POST',
The offending article is the Cookie line.. but why
Posted: Wednesday 21 August 2019 13:18
by Dnpwwo
When troubleshooting I always keep it simple, its always the assumptions that kill you.
Try replacing your 'cookie' line with mine which is hard coded. It will fail the logon but should at least dump the output and do the send.
Also turn debugging up to the max.
Posted: Wednesday 21 August 2019 18:04
by sincze
Debug is set to all.
using @Dnpwwo excluding technique :D figured out the trick.
'Cookie': ['JSESSIONID='+self.sessionid, 'SERVERID='+self.serverid]
Success.
Posted: Wednesday 21 August 2019 20:46
by sincze
So "DumpHTTPResponseToLog(self.apiRequestHeaders_withcookie())"
Gives me the following, however no usefull data JSON from the server. :(
But at least we are moving forward. :D
2019-08-21 20:40:06.521 (Growatt) HTTP Details (4):
2019-08-21 20:40:06.521 (Growatt) >'Verb':'POST'
2019-08-21 20:40:06.521 (Growatt) >'Headers':
2019-08-21 20:40:06.521 (Growatt) ---->'Host':'server-api.growatt.com'
2019-08-21 20:40:06.521 (Growatt) ---->'Accept-Encoding':'gzip'
2019-08-21 20:40:06.521 (Growatt) ---->'Connection':'keep-alive'
2019-08-21 20:40:06.521 (Growatt) ---->'User-Agent':'Domoticz/1.0'
2019-08-21 20:40:06.521 (Growatt) ---->'Cookie':
2019-08-21 20:40:06.521 (Growatt) --------['JSESSIONID=******']
2019-08-21 20:40:06.521 (Growatt) --------['SERVERID=******']
2019-08-21 20:40:06.521 (Growatt) ---->'Content-Type':'application/x-www-form-urlencoded; charset=utf-8'
2019-08-21 20:40:06.521 (Growatt) >'Data':'plantId=******&language=1'
2019-08-21 20:40:06.521 (Growatt) >'URL':'/newTwoPlantAPI.do?op=getUserCenterEnertyDataByPlantid'
2019-08-21 20:40:06.522 (Growatt) Good Response received from Growatt, Dropping connection.
2019-08-21 20:40:06.839 (Growatt) Connection 'server-api.growatt.com:80' released by Python, reference count is 1.
2019-08-21 20:40:06.839 (Growatt) Pushing 'DisconnectDirective' on to queue
2019-08-21 20:40:06.872 (Growatt) Processing 'DisconnectDirective' message
2019-08-21 20:40:06.872 (Growatt) Disconnect directive received for 'server-api.growatt.com:80'.
2019-08-21 20:40:06.872 (Growatt) Handling TCP disconnect, socket (server-api.growatt.com:80) is connected
2019-08-21 20:40:06.872 (Growatt) Queued asynchronous read aborted (server-api.growatt.com:80), [2] End of file.
2019-08-21 20:40:06.872 (Growatt) Pushing 'DisconnectedEvent' on to queue
2019-08-21 20:40:06.873 (Growatt) Processing 'DisconnectedEvent' message
2019-08-21 20:40:06.873 (Growatt) Disconnect event received for 'server-api.growatt.com:80'.
2019-08-21 20:40:06.873 (Growatt) Pushing 'onDisconnectCallback' on to queue
2019-08-21 20:40:06.873 (Growatt) Processing 'onDisconnectCallback' message
2019-08-21 20:40:06.873 (Growatt) Calling message handler 'onDisconnect'.
2019-08-21 20:40:06.873 (Growatt) onDisconnect called for connection to: server-api.growatt.com:80
2019-08-21 20:40:06.873 (Growatt) Deallocating connection object 'HTTP Test' (server-api.growatt.com:80).
2019-08-21 20:40:15.841 (Growatt) Pushing 'onHeartbeatCallback' on to queue
