Re: Problem set activity time. [Solved]
Posted: Friday 09 August 2019 21:38
Yes is normal behavior but I don't think you need to check every minute between 19:45 - 23:59. If you check once at 19:45 triggered by a timer and after that only check based on the device change you will have the best of both worldsMayki wrote: Friday 09 August 2019 20:37 EDIT: So it's not right, the script runs every minute. Or is it normal behavior?..
Is there any other way?
By combining the logic of the scripts you will get this:
return
on =
devices = {['Samsung TV - Status'] = {'between 19:45 and 23:59'}}, -- <<< --- trigger on device change within time window
timer = {'at 19:45'}, -- <<< --- trigger at specific time
logging =
level = domoticz.LOG_DEBUG,
marker = "Samsung TV Hyperion Wall"
execute = function(dz )
local tv = dz.devices('Samsung TV - Status')
local light = dz.devices('Hyperion Wall - RGB Light')
if tv.active then
light.setColor(0, 0, 255, 20, 0, 0, 4, 255)
light.dimTo(0)
