Problem set activity time.  [Solved]
Re: Problem set activity time.  [Solved]
Mayki wrote: Friday 09 August 2019 20:37 EDIT: So it's not right, the script runs every minute. Or is it normal behavior?..
Is there any other way?
Yes is normal behavior but I don't think you need to check every minute between 19:45 - 23:59. If you check once at 19:45 triggered by a timer and after that only check based on the device change you will have the best of both worlds :)
By combining the logic of the scripts you will get this:
return
    on =
        devices =  {['Samsung TV - Status'] = {'between 19:45 and 23:59'}},   -- <<< --- trigger on device change within time window
        timer =  {'at 19:45'},  -- <<< --- trigger at specific time
    logging =
        level =  domoticz.LOG_DEBUG,
        marker = "Samsung TV Hyperion Wall"
    execute = function(dz )
        local tv = dz.devices('Samsung TV - Status')
        local light = dz.devices('Hyperion Wall - RGB Light')
        if tv.active then
            light.setColor(0, 0, 255, 20, 0, 0, 4, 255)
            light.dimTo(0)
