Blockly and user variables for basic heater
Posted: Tuesday 06 August 2019 15:34
Hi guys
I have a blockly that basically is
If garage temp is <15 then turn on switch 2
and if garage temp is greater than 16 turn off switch 2
This keeps the shed ticking over nicely, but if the shed is occupied for an extended period and I want to increase the temperature to say 20
Could I use a user variable to easily change the temperature elsewhere so I or others dont have to go messing in the blockly, it could be as simple as a retractive switch that overides the current temp for 1hr say or a section on the switches screen or temperature screen you just edit
cheers
cheers
