Domoticz overrules Hue
owenclements
Post by owenclements »
I recently started again playing with domoticz. I have almost my whole house filled with Hue lights. Right now i use the wake up routine from the Hue app, which worked fine of course. Yesterday i added a Aeotec Multisensor 6 to my bedroom and applied a simple blocky rule on it (If i enter the room between 15:00 and 22:00 the lights should go on). Which works fine too, however, since i got that rule in place, my Hue wake up routine is not working anymore. Is there a way for me to fix this?
Regards,
Owen.
hoeby
Domoticz version: V2022.1
Re: Domoticz overrules Hue
Post by hoeby »
Are you sure the hue routine is still active in the app?
I also have hue lights. And work with routines out the app, but also control then with domoticz. Don't have probleem with the working from 2 different applications
