12-hour clock.
rwperkinsjr
12-hour clock.
Is there a way to display the clock in a 12-hour format instead of the default 24-hour format?
Lokonli
Re: 12-hour clock.
There is a config setting:
timeformat, Configure the TimeFormat, 'DD-MM-YY HH:mm' = default
For 12 hour format you can set in CONFIG.js something like:
There also is the parameter calendarformat
For all formats, see https://momentjs.com/docs/#/parsing/string-format/
config["timeformat"] = "DD-MM-YY hh:mm a"
