Ready scripts for just plain dimming or rgb?  [Solved]
dandanger
Post by dandanger »
I suck at scripting and don't have much time for this now, but I bet people have made tons of these so I'd be very glad if someone posted scripts for dimming. I've searched all sections and could not find even one script that would be for this simple usage. What I want to accomplish is like:
-Ikea tradfri dimmer(puck) -> dimming level -> Ikea tradfri bulb. And would be of course good if the same script could also control the light within domoticz.
-Same thing, rgb bulb for ikea.
I appreciate your help. Also good to see how different scripts I see for same function :).
dandanger
Re: Ready scripts for just plain dimming or rgb?
Post by dandanger »
Well, no replys, I thought I'd give it a try myself. Heres what I got in two days(wow):
		devices = {
			'IkeaPuck1'
	    local Light = dz.devices('Ikea1000-1')
	    himmennin = dz.variables('Dimmer1')
		domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
		if (device.name == 'IkeaPuck1' and device.level >= 0) then
		    domoticz.himmennin.set('device.level')
		    Light.dimTo('himmennin')
        elseif (device.name == 'IkeaPuck1' and device.level == 0) then
		    Light.switchOff()
And it does not work, I get this:
2019-08-09 15:57:12.151 Status: dzVents: Error (2.4.19): ...ticz/scripts/dzVents/generated_scripts/IkeaDimmTest1.lua:8: attempt to index global 'dz' (a nil value)
Dzvents documentation read many many times and cant get any closer than this..
boum
Domoticz version: 4.10717
Post by boum »
dz should be the first parameter to your execute function
execute = function(dz, device)
(then you should replace all occurrences of domoticz with dz or the other way around)
boum
Post by boum »
I'm not sure what you are trying to do with your "Dimmer1" device, so I would just simplify the script as:
	devices = {
		'IkeaPuck1'
        local light = dz.devices('Ikea1000-1')
	dz.log('Device ' .. device.name .. ' was changed', dz.LOG_INFO)
	if (device.level > 0) then
	    light.dimTo(device.level)
	    light.switchOff()
dandanger
Post by dandanger »
boum wrote: Friday 09 August 2019 15:26 dz should be the first parameter to your execute function
Oh this I didnt know..noobie mistake seems.
dandanger
Re: Ready scripts for just plain dimming or rgb?  [Solved]
Post by dandanger »
boum wrote: Friday 09 August 2019 15:36 I'm not sure what you are trying to do with your "Dimmer1" device, so I would just simplify the script as:
	devices = {
		'IkeaPuck1'
	    light.switchOff()
This works like a dream...thank you very much. I knew this would be a simple task to do, only I suck bad at scripting, more learning needed.
The Dimmer1 is a variable, I thought that I could not perform dimming straight without getting the value to a variable first.
Users browsing this forum: Amazon [Bot] and 1 guest
