Energy meter
Zodiac69
Domoticz version: 3.9319
Energy meter
Post by Zodiac69 »
How do i create a "Sensor" in Domoticz that have sub-sensors? Not sure if this is the correct terminology...
I have a kWh meter that measure the main utility supply to my house.
The same meter also have 15 other CT inputs that you can connect downstream to see what circuit is using how much.
The total of the sub-circuits is the same value at the Main input CT.
Something that show the "Main" value and then all the Sub-values - is this possible - or can i only create 16 individual sensors?
