Problem getting GPIO to work
ulfh2018
Post by ulfh2018 »
I have just made a new installation of Domoticz on Raspbian Stretch, but for some reason or another I cannot make GPIO to work.
I have done the standard installation, after doing sudo apt udate and upgrade.
I have edited the /etc/init.d/domoticz.sh and defined the ports needed for my setup
gpio export 4 out
gpio export 14 out
gpio export 17 out
sudo sh -c "echo '1' >> /sys/class/gpio/gpio4/active_low"
sudo sh -c "echo '1' >> /sys/class/gpio/gpio14/active_low"
sudo sh -c "echo '1' >> /sys/class/gpio/gpio17/active_low"
Then I have made script for dzVents
    on = {       timer = { 'every minute'  } },
        execute = function(domoticz)
        local Sensor    = domoticz.devices(5)  -- Temperature
        local SETPOINT  = domoticz.devices(2) -- SetPoint
        SETPOINT.updateSetPoint(SETPOINT.setPoint)  -- This will refresh the setPoint with current value
        if (Sensor.temperature <= (SETPOINT.setPoint - 0.2)) then -- turn on heat
        domoticz.devices(14).switchOn().checkFirst()
        domoticz.devices(18).switchOff().checkFirst()
        elseif (Sensor.temperature >= (SETPOINT.setPoint + 0.2)) then -- turn off heat
        domoticz.devices(14).switchOff()
        domoticz.devices(18).switchOn().checkFirst()
            -- within hysteresis range
14 GPIO 30E0E03 6 VarmeBad Lighting 2 AC On
18 GPIO 30E0E03 12 BadAv Lighting 2 AC Off
This works like a dream on another system, and seems to work on this system, the events will be trapped and the switches change status, but when I check the pins on my RPi, the status is never changed, so I must have done something wrong. Problem is I cannot check the other system, since it is on a location 200 km from where I am now.
The problem must be inside domoticz, since it works like a dream usin Gpio from Node Red.
Shanep
Re: Problem getting GPIO to work
Post by Shanep »
ulfh2018 wrote: Thursday 11 July 2019 16:15 I have just made a new installation of Domoticz on Raspbian gimp freejobalert notepad++ Stretch, but for some reason or another I cannot make GPIO to work.
The problem must be inside domotizc, since it works like a dream usin Gpio from Node Red
Facing similar issues here too. Some help is massively appreciated.
Thanks in advance,
Regards,
Shane
