Fibaro Walli Switch & Dimmer
Posted: Friday 05 July 2019 21:06
by terrorsource
Received a few Fibaro Walli Switches and Dimmers a couple of days ago.
Connected 1 Switch in the outlet and connected it to Domoticz.
It is not fully recognized.
Description:
Unknown: id=010f Unknown: type=1b01, id=1000+
It's creating 11 devices, which looks good to me.
01 - Switch
02 - Instance 1: System
03 - Instance 1: Power Management
04 - Instance 2: Switch
05 - Instance 3: Switch
06 - kWh Meter
07 - Unknown
08 - kWh Meter
09 - Unknown
10 - kWh Meter
11 - Unknown
Will update this topic when i know more about the Walli Dimmer.
Re: Fibaro Walli Switch & Dimmer
Posted: Friday 05 July 2019 23:54
by Snowtiger
Domoticz uses Open Zwave to communicate with Zwave devices. Devices are added by the Community. To see if your device is available check
https://github.com/OpenZWave/open-zwave ... ng-Devices
Posted: Sunday 07 July 2019 9:40
by terrorsource
Device is not in OpenZwave yet.
Starting to build the config for the Switch but it's not easy and takes some time
Posted: Sunday 07 July 2019 21:36
by terrorsource
Fibaro Walli Double Switch is added to the OpenZWave github PR's.
https://github.com/OpenZWave/open-zwave/pull/1869
Posted: Saturday 13 July 2019 14:15
by Snowtiger
Posted: Saturday 13 July 2019 17:31
by terrorsource
Thanks. Did you merge them yourself?
I've set up a new Pi with Domoticz. Added the Walli Double Switch but not fully working
Switch2 device is missing
Switch3 device is missing
I cannot press "Apply configuration for this device" button
Config 3001 shows up (not in the config xml)
3001. Instance 1: Protection:
- Unprotected
- Protection by Sequence
- No Operation Possible
Protect a device against unintentional control
Posted: Sunday 14 July 2019 13:09
by Snowtiger
I did not merge them - I just wanted to point you to this change
I assume you now run the latest Beta? A code revert has been done in 11005, check this beta to see if helps.
See Github -
https://github.com/domoticz/domoticz/issues/3530
Text - If your node has multiple relays, but only shows one in ozwcp or only one works in Domoticz: the problem has been reported to OpenZWave and is under investigation.
Posted: Sunday 14 July 2019 14:12
by terrorsource
Snowtiger wrote: Sunday 14 July 2019 13:09
See Github -
Saw that after my post. I''m now back on the latest stable and waiting for the issues to be solved before i go to a new beta again.
Posted: Sunday 14 July 2019 16:45
by Snowtiger
I'm on a stable Bèta
